![]() | | #41 | ![]() |
![]() Join Date: Aug 2013 Location: Manitowoc, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,312
| Not Ranked : 0 score
And having one person in charge of each section would relieve the workload. Sent from my iPhone using Tapatalk
__________________ https://www.youtube.com/user/JustinBieberVEVO | |
![]() | | #42 | ![]() |
| Not Ranked : 0 score @Enki; If you want I could get started on the build paths. I think that section should be split into two sections: Power and Handling. Or should things like RSB, Motor Mounts, etc. just be left out? Or possibly added in with notation that they are optional? You will have your typical build path of Intake, TIP, HPFP, AP, TP/DP, IC. But there are also some others that could be added as suggestions. Also, I think it would be worthwhile to include information on available parts and link to respective reviews of said parts.
| The Following User Says Thank You to Gr8Speed For This Useful Post: | Enki (03-20-2014) |
![]() | | #43 | ![]() |
| Not Ranked : 0 score Once you guys have the structure finished, I'll start adding. I feel it's a bit premature right now.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. |
| The Following 3 Users Say Thank You to phate For This Useful Post: |
![]() | | #44 | ![]() |
Groans: 189
__________________ | |
| The Following User Says Thank You to Enki For This Useful Post: | ItsNox (04-01-2014) |
![]() | | #45 | ![]() |
![]() Join Date: Nov 2010 Location: Irvine, CA
Rep Power: 3369 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,566
Groans: 1,143
| Not Ranked : 0 score I have some info I could fill in for the MS6... I guess I should create an account.
__________________ Past Mazdas & Speeds '04 MSM: Ohlins DFV//15x9 TRM C3M//FM FMIC//AEM SRI//Custom 3" TBE//BossFrog Clearview//Bride Gias II//Autokonexion CF Trunk v2 '94 M Edition MX5: R-package Bilsteins//15x6.5 Konig Helium//Torsen LSD//Roadstersport Race NC exhaust//MSM RSB//OEM Hardtop '06 MS6: COBB SRI/TIP//18x8 Enkei Imola//TooLateTuning Springs//SPC Balljoints//JBR RMM//Techna-Fit SS Clutch line Bimmer Challenge & Global Time Attack Project '99 BMW 328is: KW Variant3 w/ Vorshlag plates//AKG M3 Adj. Endlinks w/ 95 M3 FSB//18x9.5 +35 Advanti Optimo w/ 245/35 Hankook Z214 (C51)//E46 330i Front w/ Hawk DTC60 & E46 328i Rear w/ Hawk DTC50 & Hard Motorsport Ducting//Turner CTSCC Camber Arms//SLR Adjustable Lollipops//3 clutch 3.73 LSD//Welded 4 Point Gusseted X Brace Rollbar + Harness Bar//Sparco Ergo II w/ 6 point Schroth Clubman//Garagistic Delrin Motor & Trans Mounts, Rear Subframe, & Differential Bushings//OEM M3 Rear Subframe Reinforcement & Rear Trailing Arm Pocket Reinforcement//Z3 Steering Rack & Garagistic DSSR SSK//UUC Stage 2 Flywheel & M5 Clutch//S52 Camshafts w/ 7100 redline//M50 Intake Manifold//S50 Oilpan w/ VAC Baffle & Oil Filter Housing//CSF Radiator & Expansion Tank w/ Spal fan//3.5" MAF & Dinan CAI//#24 lb Injectors//VAC Fuel Starvation Kit//Active Autowerke GenII Header-back//OBD1 M52B28 w/ 230+whp ![]() |
| The Following User Says Thank You to Neverlift For This Useful Post: | Enki (03-20-2014) |
![]() | | #46 | ![]() |
![]() | | #47 | ![]() |
Rep Power: 3748 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,745
The mod path page is a perfectly reasonable way to go, but perhaps the information that's there so far really belongs in the intake page, no?
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
![]() | | #48 | ![]() |
That's true. Maybe I should leave out the options on the market and just go over what the mod does, and some options as far as specs (ex. 3" and 3.5" intake) Sent from my iPhone using Tapatalk
![]() | | #49 | ![]() |
| I think it's perfectly reasonable to have the options out there, but the information should probably get ported over to the "Intakes" page. I've added a bunch (I'm bored at work). Take a look and see what you think thus far.
![]() | | #50 | ![]() |
I'm liking it so far. I agree though that that info should get moved to the intakes page. Leave this for a description of each mod. Sent from my iPhone using Tapatalk
| The Following User Says Thank You to Gr8Speed For This Useful Post: | Vansquish (03-21-2014) |
![]() | | #51 | ![]() |
| SURE thing...har har. I'll port it over and leave some intro material.
| The Following User Says Thank You to Vansquish For This Useful Post: | Gr8Speed (03-21-2014) |
![]() | | #52 | ![]() |
| Not Ranked : 0 score Added a bunch to the build path section. What am I forgetting?
![]() | | #53 | ![]() |
![]() Join Date: Jun 2012 Location: San Jose, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,963
Groans: 47
| Not Ranked : 0 score Is it possible to show the content links on the main page under the section title? Rather than clicking "The Cars" and then getting that list up at the top. Maybe make it hidden by default with an expand button. Like this:
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() | ||
![]() | | #54 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Probably, but you might have to look it up in the cheat sheet.
![]() | | #55 | ![]() |
| Have you guys noticed that under "recent changes" we're getting a ludicrous number of spam-bots?
![]() | | #56 | ![]() |
![]() Join Date: Sep 2011 Location: Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 213
__________________ - 2010 Mazdaspeed 3 Black Mica - - Cobb AP - Self Tuned - cpe HPFP - cpe DP - CS 3" SRI - cpe TMIC - Forge BPV v2 - Grimmspeed EBCS - Denso ITV22 - - SouthBend Stage 3 Daily Clutch - cpe RMM - CS TMM Insert - TWM SB - CS SSP & SW - CS RSB & Mid Chassis Brace - - CS Brake Pads - Michelin Pilot Super Sport - CS Boost Tubes - CS Fog, DRL and Interior LEDs - Horns - Grounds - 20% Tint - |
![]() | | #57 | ![]() |
| I disabled new accounts. I saw it happen yest. Had over 1500 email for account confirmation stuck in the email que. Thats when i put two and two together. We can copy what we need and wipe it out, then start over or edit what was done. I had no idea this shit would become an invasion for them.
![]() | | #58 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score I'll take a full text source backup of what we have now a bit later today and let you know so you can wipe it out, Hal.
![]() | | #59 | ![]() |
Groans: 47
| Not Ranked : 0 score Damn lol why would spam bots even attack a random wiki?
![]() | | #60 | ![]() |
| Not Ranked : 0 score I think bots are pretty much going after anything all the time. Just IP/port scanning and looking for opportunities anywhere.
__________________ 2006 MS6 WWP Sport - 340whp/350wtq JBR 3"- BNRS3V2 - GS EBCS - CUSTOM FMIC - CS IM - LTR7IX - CMGS WMI & D07 GA - TURBOXS HEADER - FIDANZA FW - CP-E CATTED DP - 3" CATBACK BILSTEIN - H&R SPRINGS - 18x8.5 +48 ROTA SVN - 265/35R18 HTR ZIII MINI H1 6.0 - CAR LED TAILS SEE MORE USING !SHOUTTAG.COM - ENTER: !6SPEED6 |
![]() | | #61 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score OK CUNTS Wiki is back up and cleaned up/restored. I've not restored the pages which only had 1-2 words and I've also not restored the pages "tires" and "struts" since they appeared to be orphaned (I have manual backups though). PM me for user account creation; ONLY FOR PEOPLE THAT WILL ACTIVELY CONTRIBUTE! If you only want an account to fuck around with the wiki, this is NOT FOR YOU!
| The Following User Says Thank You to Enki For This Useful Post: | someguy (03-29-2014) |
![]() | | #62 | ![]() |
Groans: 47
| Not Ranked : 0 score Apparently wikispeedia is already used as a name for other shit, not that it really matters. https://www.google.com/search?q=wikispeedia Also, @Haltech;, can you add a link to wikispeedia somewhere on the main forum page?
| The Following User Says Thank You to sidekick For This Useful Post: | dale_gribble (04-01-2014) |
![]() | | #63 | ![]() |
Groans: 47
| The Following User Says Thank You to sidekick For This Useful Post: | Enki (04-01-2014) |
![]() | | #64 | ![]() |
| ill see what i can do with the module. It requires a template modification it looks like and ill have to hunt down some documentation on installation. Some of it is very vague.
![]() | | #65 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score Lemme know if you run into issues, Hal; I can help get it figured out.
![]() | | #66 | ![]() |
Groans: 47
| Not Ranked : 0 score It's not really a big deal, I just think it will make navigation a little easier. If someone is looking for a specific page, they can just get straight there from the main page.
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() Last edited by sidekick; 04-02-2014 at 02:48 PM. |
![]() | | #67 | ![]() |
Groans: 47
![]() | | #68 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score I don't have direct access to the source. I'm just a wiki admin until everything is updated/running how it should be and then I'm getting removed as admin. Truth is we need more people entering data...been almost two weeks since anyone's done anything.
__________________ Last edited by Enki; 04-13-2014 at 04:25 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #69 | ![]() |
Groans: 47
| Not Ranked : 0 score I've been pretty busy with work/school lately, but I will try to get some info added on my days off. I don't want this to die, because it's already come in handy for me personally. I searched for something on google and the wiki popped up with an answer. Lol.
| The Following User Says Thank You to sidekick For This Useful Post: | Enki (04-23-2014) |
![]() | | #70 | ![]() |
Groans: 189
(Thread Starter) | Not Ranked : 0 score I'm personally working on what I guess would be Albior's V2... Hopefully I'll get some time today to start putting in the first section or even further.
| The Following 2 Users Say Thank You to Enki For This Useful Post: | 86AmishMs3 (04-28-2014), WetzMS3 (04-23-2014) |
![]() | | #71 | ![]() |
![]() Join Date: Oct 2014
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score I'm 73. I've had British sports cars all my life: MG's, Triumphs, and A-Hs. I'm thinking of buying a 2008 MazdaSpeed3. I was blown away by the quickness and handling of the car on my test drive. Is there a place on this forum where I can read an introduction to this car? What is the difference between Gen 1 and Gen 2? |
![]() | | #72 | ![]() |
![]() Join Date: Jul 2012 Location: Ventura County, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 593
You want to start here: http://www.mazdaspeedforum.org/forum/foru...st-read-99499/ | |
| It's time for Abilors Tooning guide to become a WIKI page | dale_gribble | Wiki General Discussion | 85 | 06-01-2014 10:52 AM |
| Format's MS3 | Format | 2010 MS3 - Build Diaries | 17 | 10-11-2013 04:08 PM |
| Wiki Section on the forum. | Constantin | Website Help/Feedback | 32 | 08-06-2012 09:04 PM |
| MotoGP to return to 1000cc format, MotoCzysz back in the mix? | Haltech | Automotive News | 0 | 12-17-2009 06:10 AM |
| Dead format rises from the grave | Haltech | Computers & Technology News | 0 | 04-11-2008 08:30 AM |
