> TCE Performance
  • 1 Post By Todd@TCE
 Old 08-31-2014, 09:40 AM   #1
Todd@TCE's Avatar
Posts: 159   (View Stats)
Todd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond reputeTodd@TCE has a reputation beyond repute
Default TCE Wilwood kits for 6
I've opted to split off the various platforms to keep discussion on topic. More info per platform coming soon, please stand by!
TCE PERFORMANCE PRODUCTS
Your one stop....for Wilwood Brakes.
* Corvette * Lightning * Impala SS * Focus ST * Marauder * 350/370Z * MINI * Challenger * WRX *Super Duty * SHO * Mustang *...and more!
Todd@TCE is offline   Reply With Quote
 Old 08-31-2014, 09:48 AM   #2
Todd@TCE's Avatar
Originally Posted by Big Dog View Post
This could be promising if produced for the MS6.
Like the first 13" kits I did. Looking back it's hard to find images. 2004
Ten years later I'd like to see whats the same or different. Not only do I see possible new front kits but maybe some rear kit options we didn't offer back then.
Truth is it comes down to what it's going to retail for. Bottom line there is that these "proposed" kit ideas will come in at the same prices as other kits- $15-1800 front and $11-1400 rears.
It really doesn't matter 'what' the parts are bolted to (vehicle) the overall costs are the same. Both the 3 and 6 however I believe still have dual action rear calipers, that means that we'd be doing either a larger rotor kit for stock calipers (been there, done it, pics that can prove on the 3) or doing a combo caliper rear Wilwood set up.
 Old 08-31-2014, 10:42 AM   #3
Todd@TCE's Avatar
MAZDA 6
Kits will include:
1. TCE/Wilwood 13" FNSL6 front kit.
2. TCE/Wilwood 14" FNSL6 front kit.
Years: 2006-2013
Also fits:
2006-2012 Ford Fusion
2006-2011 Mercury Milan
2006-2012 Lincoln MKZ / Lincoln Zephyr (rebadged MKZ after 2006)
 Old 09-01-2014, 09:50 AM   #4
Todd@TCE's Avatar
Dug up only one older image of the 6 kits from years ago. This was quite some years ago: four pot FSL with 13 x 1.10 rotor but on our smaller hats at that time (for 12" discs also) which tells me it's a years ago as today it would be our larger and vented hats.
Doing some further cross fit check and data comparing today. Should be current 2006-12 as I suspect.
 Old 09-04-2014, 01:45 PM   #5
Todd@TCE's Avatar
Good news for 6 owners: your spindles (for brake needs) are the same from 2004 to current. Including all those other platforms noted above. Nice!
 Old 09-06-2014, 09:15 AM   #6
Todd@TCE's Avatar
Finalized drawings for the new radial mount brackets this morning. Should be making some chips late next week.
New 6 kits only a short time away!
 Old 09-08-2014, 05:59 AM   #7
cletusb's Avatar
Posts: 488   (View Stats)
How would these calipers etc compare to evo brembo calipers?
 Old 09-08-2014, 08:31 AM   #8
Todd@TCE's Avatar
Kinda hard to answer that. Which caliper are you talking about? Do you have all the specs of the other? I don't so I'm not sure what I'm going to compare to.
 Old 09-08-2014, 04:44 PM   #9
cletusb's Avatar
Stock evo 7-9 brembo calipers. Not sure of any specs sorry
 Old 09-08-2014, 05:07 PM   #10
Todd@TCE's Avatar
No need to be sorry. But without more info there's no way I can compare things either.
Piston sizes
Piston material
Weight
Body size
Body overhang/wheel fit
Mounting type
Rotor width
Pad options
Pad size
Ease of service
I get your desire to do homework but it's like comparing your favorite football team to mine; You know what you're looking for but none of my players.
 Old 09-18-2014, 07:45 AM   #11
Todd@TCE's Avatar
Mazda 6 kit work continues. Thanks for the pm questions. By all means tho please feel free to post questions or comments openly. I can take it.
spooon likes this.
The Following 2 Users Say Thank You to Todd@TCE For This Useful Post:
cletusb (09-18-2014), Jh8909 (09-18-2014)
 Old 10-07-2014, 07:50 AM   #12
Todd@TCE's Avatar
Should have these kits up and ready on the web page with in a week or so. Anyone wanting in early..let me know and we'll talk about a deal.
 Old 10-07-2014, 02:41 PM   #13
cletusb's Avatar
Do you have a caliper template available to check wheel fitment?
 Old 10-07-2014, 04:52 PM   #14
Todd@TCE's Avatar
Not a full template. But clearance info yes. *Wilwood does not release complete engineering drawings so we can only compute the X/Y coordinates for clearance relative to the "deck" - wheel mount surface.
The required spoke clearance on both kits is .96" or 24.5" (call it 1" for simplification) Add about .100 to that for an air gap.
In the drawing above you'd need a minimum of 1" for Dim A. To check this place a straight edge onto the hub face of the wheel, then measure 'down' into the back side of a spoke at an radius of 7"+ for a 13" kit and 7.5"+ for a 14" kit. (obviously the caliper is just farther from center on the larger rotor)
Another sort of back door way to do this is to search various Wilwood factory kits that show the required 1 1/8" (incl the air gap) and use it on your wheel. Time consuming and their templates are not a lot better as you have to try and blow up the pdf to spec before you can even cut it out. You could actually use the Mazda 3 kit HERE and fudge the clearance a tad. See page 3. Probably just as easy to do the ruler thing I've found.
 Old 10-09-2014, 03:03 PM   #15
Todd@TCE's Avatar
Mazda 6 brackets ready for a test fit then out to anodize!
All taking a bit painfully longer than hoped...between custom stuff and some SEMA projects for guys it's been a busy few months.
 Old 10-09-2014, 06:14 PM   #16
Todd@TCE's Avatar
Mock ups complete.
13" and 14" money.
The Following 7 Users Say Thank You to Todd@TCE For This Useful Post:
BLKSTIG (10-14-2014), Funkster777 (10-13-2014), Ingle (10-16-2014), MarineMazda (10-10-2014), Mauro_Penguin (10-16-2014), Micha (10-16-2014), Poohster (10-16-2014)
 Old 10-16-2014, 10:40 AM   #17
Micha's Avatar
Posts: 3,436   (View Stats)
OMG. Do want BBK for the 6. She is such a pig.
I am slow again.
I modded it a little.
The Following User Says NO Thank You to Micha For This Un-useful Post:
Neverlift (11-07-2014)
 Old 10-16-2014, 11:52 AM   #18
Funkster777's Avatar
Posts: 1,254   (View Stats)
Funkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the worldFunkster777 is the leader of the world
We all WANT but lots of $$$ for it.
Funkster777
2010 Black Cherry Metallic Mazda 6 DD (well as needed)
2006 Black Mica Mazdaspeed6 Sport
Originally fixed by IL NATOR. Rear Diff, TC, & PS cooler replaced due to MI NATOR. Rebuilding a MS6 one part at a time.
Performance: GTX3076r~Molnar rods~Wiseco pistons~Grimm EBCS~3-bar MAP~Autotech Internals~HTP 3.5" intake~GFB BPV~TR8 intercooler w/2.5" piping~Cobb AP v3~Freak Tune in progress (need to quit breaking things)~eBay catless DP~CS CBE~JBR RMM~ACT HD 6 puck sprung w/prolite~JBR SSP & weight~TWM Stage 2 SS w/BB & boot~Maisonvi Shift Knob~AE Tower Strut Bar~Rear Interior Brace~CP-e Rear Diff mount~Replacement Rear Diff & TC, MD PS cooler, CS Front & Rear Sway Bar~H&R Springs~Bilstein HD shocks~SS brake lines~FI Grounding Kit~EBC Yellows~Potenza RE970AS
Exterior: 6000k HIDs low beams~8000k HIDs fog lights~Luminics Ultra White Bulb high beams~HD lip~Speedline Emblemless Grill~Blacked out rear emblems~Smoked Rear & Side Markers with LEDs~15% back & windshield top tint~35% front~Sharkfin Antenna~Tower II LEDs for parking lights~CAR-LED tails
Interior: UV & purple LEDs~Blackvue DR400G-HD~Escort Redline up high w/mute~NeoPro Link iPod Connection~ProSport Premium Boost Gauge w/Vent Dual gauge pod
Waiting to Install/ Buy: SS clutch, oil pressure gauge, CP-e EWG setup/ Wheels (likely)?, Summer tires?, EVO Brembos?, Meth setup-5/6th port?
Funkster777 is offline   Reply With Quote
The Following User Says Thank You to Funkster777 For This Useful Post:
Micha (10-17-2014)
 Old 11-02-2014, 09:01 AM   #19
Todd@TCE's Avatar
Brackets for the 6 will be back from anodizing the next couple of days.
Look for more info and maybe an intro price deal on them....
The Following User Says Thank You to Todd@TCE For This Useful Post:
BLKSTIG (11-15-2014)
 Old 11-15-2014, 12:31 PM   #20
Todd@TCE's Avatar
Always trying to go one step beyond the conventional supply, TCE includes these dedicated hose anchors with the Mazda 6 kits.
TCE Wilwood Kits for 3 Todd@TCE TCE Performance 131 05-25-2016 09:45 AM
TCE brings Wilwood and TCE/Wilwood to MSF Todd@TCE TCE Performance 12 07-10-2015 08:55 AM
Wilwood Brake Kits at EdgeAutosport! EdgeAutosport.com EdgeAutosport.com 280 02-13-2015 02:26 PM
Fastbrakes Wilwood Brake Caliper Upgrade Kits @ therpmstore.com Chimmike Revolution Performance Motorsports 46 02-11-2015 10:08 PM
New Wilwood 6 Piston kit 1LapMS3 2010 MS3 - Suspension & Brakes 43 11-30-2014 08:24 PM
Page generated in 0.38599 seconds with 24 queries
