Go Back   Mazdaspeed Forums > Mazdaspeed Forums Sponsors > FJ Performance
FJ Performance FJ Performance is dedicated to serving the community in the best way possible. We carry everything from OEM mazda parts to built long blocks. We also have our own product line FJBuilt. We have been in the mazda game for several years now and have a great understanding of the mazdaspeed platform as well as a few others. If you have any other questions about who we are or what we do please ask.
Like Tree20Likes
 Old 10-18-2015, 04:31 PM   #41
zjnspeed3's Avatar
Posts: 1,436   (View Stats)
This is easily the best overall kit to go with for our cars. I like all the safety failsafes it has as well.
 Old 10-18-2015, 07:25 PM   #42
nindoja's Avatar
Posts: 2,395   (View Stats)
What failsafes are you discussing? I don't see anything in the description of the kit about containing a fail safe when the pump fails or meth runs out.
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
 Old 10-18-2015, 07:39 PM   #43
zjnspeed3's Avatar
More so the controllers it comes with. It describes it in the long ass post toward the beginning of this thread.
 Old 11-22-2015, 08:55 PM   #44
zjnspeed3's Avatar
@Matt@FJPerformance; updates?
The Following User Says Thank You to zjnspeed3 For This Useful Post:
ItsNox (11-23-2015)
 Old 12-09-2015, 10:15 PM   #45
Revmatch's Avatar
Posts: 27   (View Stats)
Revmatch is a glorious beacon of lightRevmatch is a glorious beacon of lightRevmatch is a glorious beacon of lightRevmatch is a glorious beacon of lightRevmatch is a glorious beacon of light
I want this...
I'm wondering--where did you place the nozzle(s) and how are they oriented? Or did you use one of the TB spacers?
2008.5 White MS3 Sport
Summer 2016 plan:
FJP Turbo Kit~Borg Warner 7670 SX-E aka S257
SP63 Stage 2 Longblock~Carillo SA~2618
Revmatch is offline   Reply With Quote
 Old 12-09-2015, 10:19 PM   #46
my2k13speed3's Avatar
Posts: 2,325   (View Stats)
What updates are you looking for?
 Old 12-09-2015, 10:24 PM   #47
All of them?
I don't know.
sent from my Nexus 6P
zjnspeed3 (12-09-2015)
 Old 12-09-2015, 10:38 PM   #48
You can buy it for $949.00 and takes 1-2 weeks since these are made to order
http://fjperformanceinc.com/index.ph...oducts_id=1384
 Old 12-09-2015, 11:06 PM   #49
bhigdon101's Avatar
Posts: 37   (View Stats)
bhigdon101 is just really nicebhigdon101 is just really nicebhigdon101 is just really nicebhigdon101 is just really nicebhigdon101 is just really nice
I would like to hear some reviews and in depth how to install..any extra parts needed...need to run a fail safe or not..and power gains with dyno sheets if possible. .
zjnspeed3 likes this.
2012 white ms3|G2 caliper paint|jbr shifter bushings|jbr short shift linkage|jbr shifter weight| matt damond 3some\3 bar map\3 port ebcs\3.5 htp intake\egr delete\coolant bypass\ets tmic\small batterybox\yellow top battery\autotech hpfp/accessport v3\corksport bpv\corksport springs\koini yellows\freektuned on 93\ UR race pipe\jbr com rear swaybar\ebc redstuff pads\
bhigdon101 is offline   Reply With Quote
 Old 12-10-2015, 06:59 AM   #50
Matt@FJPerformance's Avatar
Posts: 103   (View Stats)
Matt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the world
Nozzles are in the cold pipe. I know I need to show you updates and. Dyno graph. A quick update. On the dyno we still had room left at 31psi. Which put us at 608 hp. Once we did some street testing we upped the boost a little bit more. By a little bit more I mean to 38 psi. We still had a little headroom left. If I use redneck math I would say at 38 psi the car was upper 600s lower 700s as far as power. Realistically I think the kit should be able to provide enough meth reliably to 750whp. As far as a daily use, this kit will perform with out issue. I'll try this weekend to get a better write up on the kit we've just been crazy busy.
ItsNox, BLKSTIG, MS3Shadow and 2 others like this.
Matt@FJPerformance is offline   Reply With Quote
The Following 5 Users Say Thank You to Matt@FJPerformance For This Useful Post:
Hammology (12-10-2015), Mauro_Penguin (12-10-2015), MS3Shadow (12-10-2015), SpeedRebirth (12-10-2015), zjnspeed3 (12-10-2015)
 Old 12-10-2015, 08:27 AM   #51
Revmatch's Avatar
Thanks for the info!
Are you running an additional fail safe with the kit it or using the built in pre checks and LEDs only?
Summer 2016 plan:
 Old 12-10-2015, 10:48 AM   #52
Honestly just the way the kit does with led. We have never seen a alky kit fail when installed properly. We've used their kits in many many installs for other platforms
 Old 12-10-2015, 11:34 AM   #53
The biggest thing keeping me away from this kit is I don't want s 4 gallon fuel cell mounted in my trunk, any chance to modify this kit and be used with the htp tank that's in development?
 Old 12-10-2015, 11:37 AM   #54
So, the cell is actually fairly small for the size. I can get your measurements. But it's not like a5 gallon tank from aem
 Old 12-10-2015, 11:41 AM   #55
zjnspeed3's Avatar
Is it small enough to fit in the spare tire compartment?
 Old 12-10-2015, 11:49 AM   #56
I could go to a 3 gallon fuel cell that should.
But it's pretty close
Last edited by Matt@FJPerformance; 12-10-2015 at 11:49 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to Matt@FJPerformance For This Useful Post:
 Old 12-10-2015, 11:54 AM   #57
zjnspeed3's Avatar
If it's not too much of a hassle, would you see the fitment difference between the 4 and 3 gallon? Or even a 3.5 gallon maybe?
Also, would you offer your intercooler piping with the meth bungs already tapped?
 Old 12-11-2015, 08:16 AM   #58
What size are those Teflon lined braided hoses? And are these designed to run inside or outside of the car back to the tank?
 Old 12-24-2015, 05:25 PM   #59
bhigdon101's Avatar
will the meth nozzles screw into the tb spacer jbr and Matt Damond make?
or have to go in the cold side piping only?
 Old 12-24-2015, 05:26 PM   #60
They will not, they are pretty big so they will need to be tapped into the cold side piping. They won't leak. alky has been doing it this way for 30 years
 Old 12-24-2015, 05:33 PM   #61
bhigdon101's Avatar
how about instructions on wiring everything up..
or a how to with pics?
 Old 12-24-2015, 05:34 PM   #62
Yes we will include how to on wiring. It's actually pretty simple! You do need a 3-3.5 bar map that's the only requirement. But most people that need this have that already
 Old 12-24-2015, 05:40 PM   #63
zjnspeed3's Avatar
Would it work with a 4 bar or does it have to be a 3-3.5?
 Old 12-24-2015, 05:40 PM   #64
It would work with a 4 bar.
zjnspeed3 (12-24-2015)
 Old 12-24-2015, 06:20 PM   #65
zjnspeed3's Avatar
What if it's not the conventional bar sensor but the Guardian Angel that comes with a 4bar map wire integrated into the wiring harness?
 Old 12-24-2015, 06:21 PM   #66
That I'm not 100% sure on. Let me do some research and I can let you know
The Following 2 Users Say Thank You to Matt@FJPerformance For This Useful Post:
MS3Shadow (12-24-2015), zjnspeed3 (12-24-2015)
 Old 01-27-2016, 10:57 PM   #67
bhigdon101's Avatar
do we have any confirmed number of hp and tq this kit can put out with out pi or 5th or 6th port?
very interested still...
 Old 01-28-2016, 05:41 AM   #68
It made over 600 on our dyno without 5th and 6th port. With still room to go.
bhigdon101 likes this.
The Following 4 Users Say Thank You to Matt@FJPerformance For This Useful Post:
bhigdon101 (01-28-2016), Mauro_Penguin (01-28-2016), Revmatch (05-22-2016), zjnspeed3 (01-28-2016)
Strange launch control interaction with traction control fortressofcomfort Gen2 MS3 General Discussion 47 03-29-2012 08:41 AM
can't stop, ABS/Traction Control lights, no cruise control...vacuum leak? btstarcher MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 06-17-2011 11:06 PM
Wastegate control, Boost spikes, PID control FreeFlyFreak
Cobb ATR Support
83 11-05-2009 12:40 PM
Page generated in 0.46040 seconds with 27 queries
