Go Back   Mazdaspeed Forums > Mazdaspeed Forums Sponsors > FJ Performance
FJ Performance FJ Performance is dedicated to serving the community in the best way possible. We carry everything from OEM mazda parts to built long blocks. We also have our own product line FJBuilt. We have been in the mazda game for several years now and have a great understanding of the mazdaspeed platform as well as a few others. If you have any other questions about who we are or what we do please ask.
Like Tree20Likes
 Old 06-23-2015, 10:59 AM   #1
Matt@FJPerformance's Avatar
Posts: 103   (View Stats)
Matt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the worldMatt@FJPerformance is the leader of the world
Neutral  :  0 score
Default Alky Control Meth kit
We wil finally be testing our Alky control meth kit we had designed for the mazdaspeed platform this week. I hope to get some results up in the next few weeks of how it helped. For those of you not familiar with Alky. They have been making meth kits for almost 30 years. In the Forced induction world of V8/V6, there is no better name. Last December we got a chance to talk with Julio of Alky control and have him design a kit exclusive to FJ for our platform. The kit was designed to give a enough meth safely to 750hp on 2 nozzles, once it's all been tested we will give more info on the kit. I know @Justin@Freektune; is very excited to work with this kit! Can't wait to bring this kit to the market for everyone!
Matt@FJPerformance is offline   Reply With Quote
The Following 19 Users Say Thank You to Matt@FJPerformance For This Useful Post:
AwAfrican (07-08-2015), Castillo817 (06-23-2015), Code Monkey (06-23-2015), DevinS (07-01-2015), Hammology (06-24-2015), ItsNox (06-24-2015), JgamB (07-06-2015), maisonvi (08-03-2015), Mauro_Penguin (06-25-2015), MD1032 (07-05-2015), neganox (06-23-2015), PUGENE (06-26-2015), SpeedRebirth (06-23-2015), Swinger13 (09-03-2015), tparker14 (07-05-2015), TRBLSM (07-22-2015), WetzMS3 (06-23-2015), xorphanx (12-10-2015), [R]usty (06-23-2015)
 Old 06-23-2015, 11:05 AM   #2
Justin@Freektune's Avatar
Posts: 954   (View Stats)
Really excited to be trying this kit out! They are a huge name in the meth business and I have no doubt the kit they designed for the Speeds and power goals will FLOW some mef
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
The Following 5 Users Say Thank You to Justin@Freektune For This Useful Post:
AwAfrican (07-08-2015), DevinS (07-01-2015), Matt@FJPerformance (06-23-2015), MD1032 (07-05-2015), WetzMS3 (06-23-2015)
 Old 07-04-2015, 08:25 PM   #3
tastysi2004's Avatar
Posts: 1,063   (View Stats)
cant wait x2!!!
2008 MS3 gt mica black
EL NATOR DE Virginia/Florida
Update: getting that
Purple drank in my tank.
554whp/546wtq @ 30psi.
another build? maybe soon..
#CATBACKEXHAUST
 Old 07-05-2015, 06:17 AM   #4
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Subbed for details. What kind of controller is it going to be running off of?
2007 Mazdaspeed3 GT
 Old 07-05-2015, 01:00 PM   #5
Alky has its own controller designed by them. Here is a little tech info on the product
Methonal Injection and the Progressive Controller
A bit of history on the progressive controller and its development.
Years ago, injection systems were marketed using a simple pressure switch, relay, nozzle, and pump. This is a very basic system and is still sold by many companies. From the beginning, this design had weaknesses. First, HOW MUCH liquid is needed by the engine to prevent detonation. What is needed in order to achieve a balance of system pressure vs. nozzle orifice sizing? Example: Let's say one needed 600 CC’s/minute at 15 PSI boost, then you would change the nozzle to achieve this setting. The problem is, how do you know you need the 600 CC’s when at 15 PSI boost? Enter the "trial and error" phase of system tuning...lots of guessing and nozzle changes.
The next advancement was the use of a variable voltage controller which could be located in the "cockpit". Now, changes to pump voltage drive could occur. Reducing voltage drive reduced output and determining that 600 CC level could be accomplished in a more rapid fashion without changing “lots” of nozzles/jets.
Great new feature with minimal experimentation...now the engine is detonation-free at 600CC's and 15 PSI boost, right? Wait, there's another new hurdle. When the boost needle hits 15 PSI, we realize there is a system "time-delay". When we tell the pump to activate, it's motor needs to spin, lines must fill, liquid passes through the nozzle, past the throttle body, past the intake valves and finally into combustion chambers. Solution? Activate the system at 10 PSI (or even less) to offset the time needed for liquid to reach the combustion chamber. Now, when 15 PSI is reached, the proper amount is being delivered under those conditions. Finally, all bases covered, right? Wrong! Now the issue is during a part throttle condition. When at 10 PSI, the motor will have far too much liquid at the lower boost level and will create surging and bogging at the activation set point.
Ain't evolution fun? Now let's consider a "staged" setup where one small nozzle activates at 8 PSI and another at 13 PSI, so that at 15 PSI we would have the proper volume. Now we have adequate flow at the desired boost level...in a more gradual fashion. But wait! Due to the multiple pressure switches, solenoids, relays and wiring, the "plumbing" will be a nightmare when it comes to troubleshooting and/or service. Another issue...the above setup ONLY provided a specified amount at a specific boost level. In a turbo application it is possible for wastegate malfunctions to create boost levels much higher than the 15 PSI that was set. So, if the boost spiked to 20 PSI, we are only injecting enough to sustain 15 PSI. This could be followed by a “dead band” condition associated with mechanical switches, especially inexpensive types. Example: Let's say it activates at 8 PSI, but does not deactivate until under 3 PSI. Understand that pressure switches are mechanical in nature and each will have it's own characteristics. This is the reason we don’t use mechanical pressure switches to control key functions within the system...like activation.
The fix for tuning issues associated with above systems was relatively simple. We created a way to develop a voltage "curve" based on boost pressure. The higher the boost, the more voltage sent to the pump, which creates higher pressure. This allows the system to activate early on, fill the lines at low pressures, while not affecting performance. This arrangement also provides the ability to continue add volume as manifold pressure is increased. This may sound easy, but here is where it gets a bit complex.
The “curve” MUST be tailored to the engine’s volumetric efficiency. Simply put, having a simple activation/set point and maximum does not allow this to happen in every engine.
Only recently have other companies begun to realize the need for changing the curve of their progressive controllers. Some now have added “Set” and “Max” settings. Recently, some have initiated thoughts about utilizing a microprocessor to control the injection process.
Here is my take on that idea...
As stated above, an injection system is comprised of a tank, pump, nozzle and electronics. The mechanical device in question is a relatively large pump with significant mass, capable of moving a lot of fluid at high pressure. Inherent is a rise and fall in pressure which takes time to achieve. Remember the "time-delay" issue earlier in this article (the system must activate earlier than needed)? The limiting speed factor in the system is the pump. A 64 MHZ processor will not spin the pump any faster or slower than a switch, meaning the system is only as fast as its slowest device. Abrupt changes to voltage will not cause abrupt changes to pressure. Rise and fall times are mechanical. Think of it like a garden hose with the handle open and someone opening and closing the valve abruptly. This is why there is confusion by those who think the systems work like fuel injectors that can be varied instantly. Also remember that the nozzle placement in front of the throttle body produces an additional "time delay". Redundant, important point...abrupt voltage variations CANNOT produce INSTANT delivery of liquid into the engine.
In our case, simplicity was one of the goals. Now, what do we do that is different and why?
Our main controller has three boxes, purposely designed for achieving various goals.
First, the large pump draws considerable current. At 250 PSI on a 15 gallon per hour nozzle. the pump motor draws in excess of 12 amps and spikes will be even higher. Higher currents generate heat and this heat MUST be dissipated. The driver module on our controller is basically a very large heat-sink designed to keep heat away from the main controller PCB and its components and that is the reason it is mounted away from the PCB. It is rated at 45 amps and will sustain a constant high current load for hours without failure. The design is overkill and creates more work for us in building the unit, but the end result is a bullet-proof device. This assures zero heat stress to the main PCB and results in a reliable device. The main PCB and heat-sink are encased in a special polymer to keep parts from moving, similar to aftermarket ignition systems. An encased PCB will not develop bad connections due to vibration issues, such as racing an engine, suspension system, etc. Vibration is an important issue in a hostile environment like an automobile interior where temperatures can range from below freezing to "desert conditions". Controllers should be mounted in the interior...NOT in the engine compartment.
Lastly, the 3rd box of our system allows for custom placement of the controls into flat panel surfaces or be mounted as is (installation flexibility).
The aftermarket now pushes for smaller controllers (at the expense of reduced or eliminated heat sinking). You simply cannot transfer heat without an adequate heat sink. Designs from certain competitors mount the pump driver right on the PCB. Obviously, this makes for a smaller controller, but one subjected to tons of heat cycling. This is NOT an area where size should be reduced. Solder breaks down after repeated heating, cooling, heating, cooling, etc. Some systems don’t allow the ability to be switched on/off. In others, one cannot “test” the system. These are basic, important details lost in an effort to reduce costs. Rest assured, regardless of production costs, we strive to cover all areas, including surge suppression, reverse polarity protection, charging system malfunctions, wiring shorts, etc.
The Following 10 Users Say Thank You to Matt@FJPerformance For This Useful Post:
BLKSTIG (07-07-2015), dan7225 (10-07-2015), dinoxor (07-30-2015), JgamB (07-06-2015), littleloogy (07-29-2015), Mauro_Penguin (07-18-2015), neganox (07-06-2015), Poohster (07-18-2015), speed23 (07-20-2015), Tifosi42 (07-06-2015)
 Old 07-06-2015, 05:24 AM   #6
Feline Führer
neganox's Avatar
Posts: 1,790   (View Stats)
Soooooooooo
Matt@FJPerformance (07-06-2015)
 Old 07-07-2015, 08:50 PM   #7
Here is a little teaser of everything but the fuel cell included in the kit. It comes with 4 gallon fuel cell as well. We expect to have the kit ready for sale by August 1st.
ItsNox likes this.
The Following 7 Users Say Thank You to Matt@FJPerformance For This Useful Post:
Cyclops (07-18-2015), Jansi (07-28-2015), Mauro_Penguin (07-08-2015), neganox (07-08-2015), Poohster (07-08-2015), SofaKingAwesome (08-03-2015), Zdraveca (07-08-2015)
 Old 07-08-2015, 05:21 AM   #8
Feline Führer
neganox's Avatar
I spy braided lines. I'm assuming fuel cell is for the hatch area?
 Old 07-08-2015, 05:50 AM   #9
Yes, the fuel cell will be for the hatch area and yes braided lines through out!
 Old 07-17-2015, 05:56 PM   #10
some pics of the meth lines used
Mauro_Penguin and ItsNox like this.
The Following 5 Users Say Thank You to Matt@FJPerformance For This Useful Post:
Mauro_Penguin (07-18-2015), neganox (07-17-2015), nindoja (07-17-2015), Poohster (07-18-2015), taf0422 (07-29-2015)
 Old 07-17-2015, 06:47 PM   #11
nindoja's Avatar
Posts: 2,395   (View Stats)
Will the lines be available separate from the kit?
True Red 2009 MS3
Tune: hypnotic tuned
Critical Stats:
// 305whp/352tq
Matt@FJPerformance (07-17-2015)
 Old 07-17-2015, 06:52 PM   #12
No they are designed to work with this kit only
 Old 07-20-2015, 06:15 PM   #13
my2k13speed3's Avatar
Posts: 2,325   (View Stats)
Any rough pricing on this kit? I'm getting ready to pick up a meth kit, this one looks very nice...
lolwrx likes this.
The Following 2 Users Say Thank You to my2k13speed3 For This Useful Post:
sho (07-22-2015), Zoom66 (07-27-2015)
 Old 07-29-2015, 10:30 AM   #14
ItsNox's Avatar
Posts: 3,076   (View Stats)
I'm loving how this kit looks. We need prices!! And details!
'06 Mazdaspeed 6 GT
- Miltuned
Georgia Motherfucking Nator
 Old 07-29-2015, 11:35 AM   #15
Agreed we need pricing and details!
 Old 07-29-2015, 12:14 PM   #16
acidplant's Avatar
Posts: 60   (View Stats)
acidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant futureacidplant has a brilliant future
Good day ALL...I'm about to do major upgrade to my Speed6 in November and wall looking for a Kit...Just in time..I hope.....Help and assistance would be great from everyone here as well...I'm new to this.
acidplant is offline   Reply With Quote
 Old 07-29-2015, 01:09 PM   #17
$949 will be the retail. We will be launching specifics about the kit next week. We are done with tuning and testing now! Can't wait to have it officially on the market to everyone
The Following 8 Users Say Thank You to Matt@FJPerformance For This Useful Post:
BLKSTIG (07-29-2015), ItsNox (07-29-2015), Justin@Freektune (07-30-2015), littleloogy (07-29-2015), Mauro_Penguin (07-29-2015), Poohster (07-29-2015), sho (07-31-2015), Thepedigree13 (07-30-2015)
 Old 07-29-2015, 06:10 PM   #18
Feline Führer
neganox's Avatar
My body. Is ready.
ItsNox likes this.
 Old 07-29-2015, 11:34 PM   #19
BLKSTIG's Avatar
Posts: 507   (View Stats)
with 1st ten buyer special pricing right hehe
 Old 07-30-2015, 10:30 AM   #20
Poohster's Avatar
Posts: 353   (View Stats)
Poohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the worldPoohster is the leader of the world
Alky- control meth was recommended as the WMI kit to get by a good friend. Unfortunately, I purchased but haven't installed yet, a Snow Performance Stage 2 WMI kit. ARRGGGHHH Should have waited!!!!!!!
06 MS6, Blk Mica, MS wheels 18x7.5, Conti DWS P225/45-18, Magnaflow CB, Autometer Boost gauge, CS Strut bar, Bilstein shocks, Redline Tuning QuickLIFT, TT Diff Frt mount, SP slotted rotors, Hawk pads, Whiteline RSB, JBR Thermal Gaskets. Cobb AP, GTX2867r, Snow Stage2 WMI, Southbend Stage 3 Enduro clutch. HTP 3 in TIP
RPM: Sport Springs, Shark Fin, LED side markers
CP-e: HPFpump, Xcel CAI, DP, Tial w/ BOV Flange, gauge pod, TMIC, Safeseals, MZRevolved Stage 2 block, RMM, LTRmani, xFlex diff mount
Poohster is offline   Reply With Quote
 Old 08-03-2015, 06:53 AM   #21
Feline Führer
neganox's Avatar
Will the kit have an option for those of us wanting to run multiple nozzles?
Matt@FJPerformance (08-16-2015)
 Old 08-16-2015, 06:21 AM   #22
It comes with Dual nozzles standard! It will be able to run single if you choose to
The Following User Says Thank You to Matt@FJPerformance For This Useful Post:
neganox (08-16-2015)
 Old 08-16-2015, 06:27 AM   #23
Amnesiac's Avatar
Posts: 315   (View Stats)
Groaned at 6 Times in 4 Posts
Were there plans for a MS6 option, or did you need a car at your shop for fitment on that?
Amnesiac is offline   Reply With Quote
 Old 08-16-2015, 06:33 AM   #24
It works the same with the MS6
The Following 4 Users Say Thank You to Matt@FJPerformance For This Useful Post:
Amnesiac (08-16-2015), BLKSTIG (08-16-2015), Poohster (08-16-2015), Speedling6 (12-10-2015)
 Old 08-16-2015, 08:35 AM   #25
Djohns's Avatar
Posts: 3,944   (View Stats)
Now I'm pretty new to meth so please bare with me here lol but I plan on running meth next summer and doing a ton of research over the winter months. But if I'm understanding correctly, this kit cost quite a bit more than a DO or SP correct? Why is that?
2010 black mica speed3
Soon:built motor
 Old 08-16-2015, 08:45 AM   #26
taf0422's Avatar
Posts: 4,689   (View Stats)
Groans: 192
Probably due to more advanced controller, braided lines, better pump.
Also, i probably wouldn't be looking at this kit if you're a lower HP though. Now if you were having a hard time deciding between PI and meth then its a toss up. Also, lots of research needs to be done by you prior to running meth. The system also needs to be checked on a regular basis and/or failsafe added
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
Djohns (08-16-2015)
 Old 08-16-2015, 08:45 AM   #27
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
Looks like a really nice kit. I'll have to weight the pros and cons of this vs 5th/6th port.
 Old 08-27-2015, 10:57 AM   #28
onetechyguy's Avatar
onetechyguy has a reputation beyond reputeonetechyguy has a reputation beyond reputeonetechyguy has a reputation beyond reputeonetechyguy has a reputation beyond reputeonetechyguy has a reputation beyond reputeonetechyguy has a reputation beyond reputeonetechyguy has a reputation beyond reputeonetechyguy has a reputation beyond reputeonetechyguy has a reputation beyond reputeonetechyguy has a reputation beyond reputeonetechyguy has a reputation beyond repute
How would this compare to the aquamist kit?
onetechyguy is offline   Reply With Quote
The Following 2 Users Say Thank You to onetechyguy For This Useful Post:
Mauro_Penguin (08-27-2015), torquemaniac (08-28-2015)
 Old 09-16-2015, 10:51 PM   #29
bhigdon101's Avatar
Posts: 37   (View Stats)
bhigdon101 is just really nicebhigdon101 is just really nicebhigdon101 is just really nicebhigdon101 is just really nicebhigdon101 is just really nice
any updates on this kit yet?...
2012 white ms3|G2 caliper paint|jbr shifter bushings|jbr short shift linkage|jbr shifter weight| matt damond 3some\3 bar map\3 port ebcs\3.5 htp intake\egr delete\coolant bypass\ets tmic\small batterybox\yellow top battery\autotech hpfp/accessport v3\corksport bpv\corksport springs\koini yellows\freektuned on 93\ UR race pipe\jbr com rear swaybar\ebc redstuff pads\
bhigdon101 is offline   Reply With Quote
 Old 09-17-2015, 05:59 AM   #30
Yes, it's it launched last month. It's available for sale on our site. It's $949.00.
jack_hammer (09-17-2015)
 Old 09-17-2015, 06:01 AM   #31
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
it's been for sale since the 16th...
09 MGM MS3
 Old 09-17-2015, 11:09 AM   #32
bhigdon101's Avatar
seen it was for sale.. was looking for some feedback on it.. reviews or numbers... just little more info from people running it....just got done tuning my car with justin... and he did say he tuned matts car with this kit....even a write up or how to...looks and sounds like the kit i have been looking for with out having to put one together myself...
 Old 09-17-2015, 12:10 PM   #33
Feline Führer
neganox's Avatar
Alky Control is the real deal. Saving up for one of these myself. No more of this 50/50 mix shenanigans.
 Old 10-06-2015, 10:34 PM   #34
Hammology's Avatar
Posts: 540   (View Stats)
Groans: 36
@Matt@FJPerformance; just curious, would you guys be able to provide a bigger tank with this kit upon request?
Built motor
GTX3071
Meth
6th Port
 Old 10-06-2015, 10:34 PM   #35
Yes, 4 gallon is a pretty good size
Hammology (10-06-2015)
 Old 10-06-2015, 10:35 PM   #36
Hammology's Avatar
Groans: 36
God damn your muthafucken ninja fast lol
Built motor
GTX3071
Meth
6th Port
The Following User Says Thank You to Hammology For This Useful Post:
Finchee (10-07-2015)
 Old 10-18-2015, 03:09 PM   #37
zjnspeed3's Avatar
Posts: 1,436   (View Stats)
I'm really considering this kit for next year!! Any word on numbers and data? With I a price this kit carries, I need some solid info!
 Old 10-18-2015, 03:43 PM   #38
Scroll up! Lol. $949 is the price on this kit. And I'm preparing a write up of all the testing. The kit has performed amazing
The Following 2 Users Say Thank You to Matt@FJPerformance For This Useful Post:
FittedMazda (12-11-2015), zjnspeed3 (10-18-2015)
 Old 10-18-2015, 03:52 PM   #39
zjnspeed3's Avatar
I saw the price the day this was released. Lol it's a doozy! But the numbers this kit makes and the data you and Justin have collected will be the deciding factor for me. The price was never really a factor.
 Old 10-18-2015, 04:29 PM   #40
Hammology's Avatar
Groans: 36
With everything it comes with this kit is priced well.
Built motor
GTX3071
Meth
6th Port
Strange launch control interaction with traction control fortressofcomfort Gen2 MS3 General Discussion 47 03-29-2012 08:41 AM
can't stop, ABS/Traction Control lights, no cruise control...vacuum leak? btstarcher MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 06-17-2011 11:06 PM
Wastegate control, Boost spikes, PID control FreeFlyFreak
Cobb ATR Support
83 11-05-2009 12:40 PM
Page generated in 0.56330 seconds with 40 queries
