| FJ Performance FJ Performance is dedicated to serving the community in the best way possible. We carry everything from OEM mazda parts to built long blocks. We also have our own product line FJBuilt. We have been in the mazda game for several years now and have a great understanding of the mazdaspeed platform as well as a few others. If you have any other questions about who we are or what we do please ask. |
| Banned ![]() Join Date: Jun 2015
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 136
(Thread Starter) | Not Ranked : 0 score FJBuilt Under the motor pipe kit! [FJBUTM] - $549.00 : FJ Performance, Yeah its a SPEED thing! Last edited by MS3Shadow; 07-25-2016 at 09:24 AM. Reason: fixed url |
| The Following User Says Thank You to Matt@FJPerformance For This Useful Post: | impossible (07-24-2016) |
![]() Join Date: Jan 2015 Location: Lincoln, NE
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 93
| Not Ranked : 0 score How do the Boost Air Temps of this kit compare to a normal intercooler kit? Say for a gen 1 with no hood scoop?
__________________ 07 Black Mica MS3: Built motor- SP63 Pro Series 88mm 9.5CR pistons, Manley H-beam rods, Clevite Main/Rod bearings, ARP main studs, L19 head studs, ACT 6-puck sprung clutch w/ Prolite Flywheel, AP V3, Stratified E85 tune/EBCS, NGK plugs, Autotech internals, Corksport injector seals/short shift plate/shifter bushings/LED kit, Cp-e FMIC/catless down pipe, Damond RMM/TMM, Mazdaspeed CBE, JBR SRI/TIP/recirc hose/BSD/oil pan baffle/EGR delete/51r battery box, Forge V2 BPV, Koni yellows, and Cobb springs, Gold Enkei RPF1 w/ 245/45/17 sport comp 2's |
(Thread Starter) | Not Ranked : 0 score When we tested on our shop speed we were down about 10-15% BATs. Sent from my iPhone using Tapatalk |
| The Following 2 Users Say Thank You to Matt@FJPerformance For This Useful Post: | impossible (05-01-2016), zjnspeed3 (10-21-2015) |
![]() Join Date: Nov 2010 Location: Reading, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,158
Groans: 731
| Not Ranked : 0 score Oh Matt, how I wish this kit was available 18 months ago. Good to see you guys have come a long way.
__________________ Mods: stock Eventually I'll pay for how I am....but it won't be by the hand of any of you faggot fucks here. |
| The Following User Says Thank You to faeker For This Useful Post: | Matt@FJPerformance (10-21-2015) |
(Thread Starter) | Not Ranked : 0 score We've actually had the kit available for quite sometime. But we've recently released it to be an in stock item vs Made to order. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to Matt@FJPerformance For This Useful Post: | faeker (10-21-2015) |
![]() Join Date: Jul 2014 Location: Waukesha, WI
Rep Power: 161 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 113
| Not Ranked : 0 score I have the JBR undermount kit and would like to replace it with yours. I am currently running a K04 but will be upgrading to the BNR S3 sooner before later. What problem will I run into trying to run this on both of those turbos?
__________________ "RACING IS AN ADDICTION CURED ONLY BY POVERTY" |
![]() Join Date: May 2014 Location: Tucson, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 183
| Not Ranked : 0 score Would it be possible to order just the cold side?
__________________ "Keep your head clear and suffer like a man" |
(Thread Starter) | Not Ranked : 0 score You should not run into any problems with the turbo. And let us know before you order he BNR! We are a BNR dealer. We have the new site up and we're still transferring over all of our products! Sent from my iPhone using Tapatalk Yes, shoot me a PM Sent from my iPhone using Tapatalk Last edited by Matt@FJPerformance; 12-22-2015 at 11:32 AM. Reason: MSF Database - Automerged Doublepost |
| The Following 2 Users Say Thank You to Matt@FJPerformance For This Useful Post: | impossible (07-24-2016), RusianKid (12-22-2015) |
| Not Ranked : 0 score Matt, Does this kit fit with the under tray?
(Thread Starter) | Not Ranked : 0 score It should, it hugs pretty tight but, I've never installed one with an under tray. So I don't want to tell you 100% yes for sure Sent from my iPhone using Tapatalk |
![]() Join Date: May 2014 Location: Coopersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 186
| Not Ranked : 0 score Just a heads up that the link is broken since you changed your site. |
| Not Ranked : 0 score @Matt@FJPerformance; what makes the kit you sell different from the kit for an IWG setup? Your website states they are different.
| The Following User Says Thank You to zjnspeed3 For This Useful Post: | impossible (07-24-2016) |
![]() Join Date: Aug 2008 Location: Birmingham, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
| Not Ranked : 0 score Does this fit a BNR S4 and corksport large core FMIC?
__________________ 2013 CWP Mazdaspeed 3 |
| Official: Ram 1500 Motor Trend's first back-to-back Truck Of The Year | Haltech | Automotive News | 0 | 12-04-2013 11:30 AM |
| Report: Tokyo Motor Show downsizes again, moving back into city | Haltech | Automotive News | 0 | 05-26-2010 08:40 AM |
