 Old 09-01-2017, 07:05 PM   #1
SpoolinSpeed3..757's Avatar
Posts: 48   (View Stats)
SpoolinSpeed3..757 is a glorious beacon of lightSpoolinSpeed3..757 is a glorious beacon of lightSpoolinSpeed3..757 is a glorious beacon of lightSpoolinSpeed3..757 is a glorious beacon of lightSpoolinSpeed3..757 is a glorious beacon of lightSpoolinSpeed3..757 is a glorious beacon of light
Hole in crank pulley should line up with a threaded hole on the timing cover. Slide a bolt in it and hit the crank bolt with an impact
Sent from my SM-G930P using Tapatalk
SpoolinSpeed3..757 is offline   Reply With Quote
 Old 09-01-2017, 07:09 PM   #2
mike000g's Avatar
Posts: 241   (View Stats)
mike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond repute
Groaned at 7 Times in 5 Posts
I already went through a timing cover ,when I tried to torque
Sent from my SM-G955U using Tapatalk
Looking for something like this
Wiseco 10:6.1 compression, Corillo Rods Pro, Sure BSD, JBR oil pan Windage, DCR VVT, NGK 2 step colder, CPE Head Gasket, ARP Studs, Garrett GTR25, Steed Speed Manifold, 38mm Tial WG Dumped to Atmosphere, Garret Catless Full DP, HKS CB, HTP 4" Full Intake, Garrett IC, Turbo Smart Dual Port BOV 50/50, Spec Stage 3+ Clutch and Flywheel, JBR Thermal Gasket Intake Manifold and Throttle Body, Grimspeed EBC 3 port, CPE RMM
Last edited by mike000g; 09-01-2017 at 07:09 PM. Reason: MSF Database - Automerged Doublepost
mike000g is offline   Reply With Quote
 Old 09-01-2017, 07:18 PM   #3
Torquing puts a different kind of stress on the bolt. Good enough impact is just a quick bang. But I can respect better safe than sorry
Mazda crank pulley tool vs Ford crank pulley tool SPEED6 KILLAH MazdaSpeed 6 - Engine, Transmission & Driveline 52 03-11-2017 09:46 AM
MS3 LW Crank Pulley Alpha CorkSport 3 04-22-2011 12:07 PM
Page generated in 0.23842 seconds with 22 queries
