 Old 09-01-2017, 07:20 PM   #1
mike000g's Avatar
Posts: 241   (View Stats)
mike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond reputemike000g has a reputation beyond repute
Groaned at 7 Times in 5 Posts
Yes sir. Looking at the cams it slipped under timing
Sent from my SM-G955U using Tapatalk
Wiseco 10:6.1 compression, Corillo Rods Pro, Sure BSD, JBR oil pan Windage, DCR VVT, NGK 2 step colder, CPE Head Gasket, ARP Studs, Garrett GTR25, Steed Speed Manifold, 38mm Tial WG Dumped to Atmosphere, Garret Catless Full DP, HKS CB, HTP 4" Full Intake, Garrett IC, Turbo Smart Dual Port BOV 50/50, Spec Stage 3+ Clutch and Flywheel, JBR Thermal Gasket Intake Manifold and Throttle Body, Grimspeed EBC 3 port, CPE RMM
mike000g is offline   Reply With Quote
Mazda crank pulley tool vs Ford crank pulley tool SPEED6 KILLAH MazdaSpeed 6 - Engine, Transmission & Driveline 52 03-11-2017 09:46 AM
MS3 LW Crank Pulley Alpha CorkSport 3 04-22-2011 12:07 PM
Page generated in 0.24093 seconds with 21 queries
