Go Back   Mazdaspeed Forums > MSF News And Event Info > Site News & Events > Website Help/Feedback
Website Help/Feedback If you have problems or suggestions for the forum, post here.
  • 1 Post By tegxsi
 Old 01-31-2020, 05:02 PM   #1
GenpuMike's Avatar
Posts: 3   (View Stats)
GenpuMike is an unknown quantity at this point
Default Boost help
I recently put a new CST4 turbo in my car with all supporting mods, the car ran fine for the first month it was in. Now a few weeks later, my wonderful car is stuck between 11-14 psi. The log i provided is from the Wastegate spring pressure map that Nishan provided me. I originally though it was the wastegate but now the duty cycle is at 0 leaving me lost. (Log provided) Any tips would be greatly appreciated
2013 genpu, CST4 Turbo, JBR 3.5 aluminum intake, cs hpfp, cs injector seals, cs small battery box, JBR 3-port ebcs, TR8L with CXracing piping, JBR pmm, Cobb rmm, Damond tmm, GFB BOV, 3 inch catless downpipe
GenpuMike is offline   Reply With Quote
 Old 01-31-2020, 05:05 PM   #2
GenpuMike's Avatar
Originally Posted by GenpuMike View Post
I recently put a new CST4 turbo in my car with all supporting mods, the car ran fine for the first month it was in. Now a few weeks later, my wonderful car is stuck between 11-14 psi. (Log provided) Any tips would be greatly appreciated
datalog102.csv
 Old 01-31-2020, 07:05 PM   #3
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
I'm not sure what's wrong. You can't make more boost above the spring pressure without any wastegate duty.
Vansquish likes this.
2018 Audi RS3
2007 Acura TSX 6MT
Vansquish (01-31-2020)
 Old 01-31-2020, 08:30 PM   #4
Police - Grammarhead
Vansquish's Avatar
What @tegxsi; said. ^^^
If you've got a "wastegate spring pressure map" that means that Nishan set the commanded WGDC values to zero throughout the map. Accordingly, you've got no wastegate control other than the spring on that map, and any datalogs you take should show your car hitting maximum boost at whatever the spring pressure on the CST4 is (around 12-14psi, usually).
If you're having trouble hitting boost targets on some other map, then you might have a problem. But, from the log you posted, on the map you're running, your car is doing precisely what it is supposed to do.
 Old 02-02-2020, 02:38 PM   #5
GenpuMike's Avatar
Thanks guys, I think i found the problem. I recently checked my 3 port ebcs and found that a couple of the wires going into it have disconnected. New one is on the way, Ill keep both of you updated!
 Old 02-02-2020, 07:36 PM   #6
55suarod's Avatar
Posts: 36   (View Stats)
55suarod is a jewel in the rough55suarod is a jewel in the rough55suarod is a jewel in the rough
My CST4 is en route, will keep an eye on this thread in case your issue is turbo related
55suarod is offline   Reply With Quote
Snow maf/boost controller boost Line question speed3gen1 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1 10-29-2012 07:29 PM
Not hitting Stage 2 boost targets (boost leak?) Bubba Ho-Tep 2010 MS3 - ECU Computer Tuning 15 04-26-2012 08:25 PM
Smooth Boost or boost jump. What is causing this, I am baffled. FreeFlyFreak
Cobb ATR Support
9 10-31-2009 01:38 PM
ideally whats the best boost targets for custom tune from full boost to redline? Wenis Prinkle
Cobb ATR Support
26 08-24-2009 06:36 PM
Page generated in 0.27381 seconds with 24 queries
