| Website Help/Feedback If you have problems or suggestions for the forum, post here. |
(Thread Starter) | Saw quite a few errors with tapatalk this morning so I just disabled it. I'll investigate this and see if any updates fix these issues.
![]() Join Date: Feb 2012 Location: Houston, Tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,441
Groans: 88
| Not Ranked : 0 score @Haltech; did you disable it again because Tapatalk hasn't been able to connect since yesterday afternoon.
__________________ 2012 LSM Mazdaspeed 3 -- sold 06/2015 ![]() Cobb AP -- 3" SRI + TIP -- gutted mid-pipe -- CX Racing FMIC -- JBR 88duro Mount Trilogy -- GrimmSpeed EBCS -- 3 Bar Map Sensor -- Kozmic vented OCC -- Synapse DV -- Magnaflow CBE -- DDM 55w 5000K low beams 4 gallon E85 mix self tune 314/370 Dynojet 2005 Black Mica Mazdaspeed MX-5 ![]() Bone stock so far |
![]() Join Date: May 2013 Location: CO
Rep Power: 2406 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,487
| Not Ranked : 0 score I logged out and logged back in and I've had no issues since using Tapatalk. |
Groans: 88
| Not Ranked : 0 score Logged in and out of the forum on Tapatalk or your Tapatalk account itself? Cause I signed in and out of the app, but I can't get past the "Connecting to server" to put my forum credentials back in, which was why I asked.
Groans: 88
| Not Ranked : 0 score Hmmm looks to be a local problem, reinstalling the app fixed it for me. Nothing to see here I guess. Sent from my SCH-I605 using Tapatalk
| Not Ranked : 0 score I logged out of the forum not the app. Just in case anyone else was having issues. |
![]() Join Date: Jun 2012 Location: Mesa, Arizona
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,244
| Not Ranked : 0 score What version (on Android) are you guys using? For some damn stupid reason, if I use my 4g it takes forever to load tapatalk forums.. If I use wifi it works perfectly. I know its not my connection because I can view MSF in my mobile browser instantly. It's pretty damn annoying.
__________________ Fastest GTX3076r, T3 twinscroll, built block, D14 meth spraying gen1 on the internet! |
![]() Join Date: Dec 2012 Location: Richmond, TX
| Not Ranked : 0 score Tapatalk works fine when at the house on wifi But can barely surf on Verizon 4g, this forum only. Other forums are fine.
__________________ ΜΟΛΩΝ ΛΑΒΕ 2014 Honda Grom 125cc's of FURY! now more furious w/ 181cc's 2015 F150 Platinum 2012 MS3 Liquid Silver Autotech HPFP Cobb AP & CBE Corksport FTB Enkei Raijin 18x8 et45 JBR 3.0WP, RSB, RMM & SSP II Stratified Tune TrackMasters hood prop and ecu reloc. TurboSmart BOV |
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
![]() Sent via Tapafail
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() | |
| The Following User Says Thank You to ItsNox For This Useful Post: | ASHMS3 (12-06-2014) |
![]() Join Date: May 2011 Location: Valdosta GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,861
Groans: 126
Using bad grammar from my cell phone.
__________________ '09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE | |
| Not Ranked : 0 score Just got a new phone, installed Tapatalk, and it says the forum doesn't have Tapatalk enabled. Phone issue or MSF issue? LG G3 with 4.4.2
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. |
![]() Join Date: Sep 2012 Location: Roanoke, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,408
Groans: 39
Mine is working fine, HTC M8.
__________________ 2008 MS3 | |
| Approved MSF Vendor ![]() Join Date: Jan 2012 Location: Maryland, USA
Rep Power: 884 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,286
| Not Ranked : 0 score I'm using a G3 with Tapatalk and have no problems, but in the thread I'm about to post below someone else is having the same issue as phate. But my question is why do some threads have several blank pages at teh end of them in Tapatalk. At the time I made this post, it was the last post in the thread: http://www.mazdaspeedforum.org/forum/foru...ml#post2761424 There are other threads that do something similar, only with Tapatalk.
__________________ --- 2011 Black Mica MS3 Tech --- ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following 3 Users Say Thank You to Mike@Stratified For This Useful Post: |
| Not Ranked : 0 score Weird. What version of the phone and Android OS are you using? I have a VS985 running 4.4.2 (build 10b). I haven't updated due to 4.4.4/11c being unrootable. I know Tapatalk Red works on 11c with MSF. If it's a version issue, I'll suffer until I can root.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 203
| Not Ranked : 0 score I have the same thing, multiple blank pages at the end of a thread, or theres new comments and you go to the thread and it will be just another blank page after the stuff that ive already read, no new comments.
__________________ ....Because Canada |
| Not Ranked : 0 score ![]() Sent while Stratified.
| The Following User Says Thank You to Mike@Stratified For This Useful Post: | phate (11-28-2014) |
| Not Ranked : 0 score I got the Xparent version working on 10b. Regular Tapatalk still doesn't work :/
Groans: 88
| Not Ranked : 0 score I'm pretty sure the blank pages come from deleted posts. if you have some sort of elevated mod permissions you see the little placeholder where a post used to be. I don't think Tapatalk handles those properly and it throws off the post count vs. post display leading to the blank pages. That's been my operating theory so far at least. Sent from my SCH-I605 using Tapatalk
| The Following User Says Thank You to Darth_Nuruodo For This Useful Post: | Mike@Stratified (11-28-2014) |
![]() Join Date: Apr 2014 Location: The Netherlands
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 512
| Not Ranked : 0 score I have the same blank pages every now and then. I know it's not about deleted posts, because a thread where I know posts were deleted, shows no blank pages, so it must be something else if you ask me...
__________________ MazdaSpeed3 GT '07 CP-e Xcel Nano 3" Air Intake - CP-e Nviscid 3" TIP - CP-e HPFP - CP-e DeltaCore FMIC - CP-e Stage 1 RMM - ACT clutch kit - ATP Race Pipe - SU DualPort Turbosmart BPV - COBB anti swaybars - COBB Sport Springs - Goodridge Brakelines - Whiteline Swaybar endlinks - JBR SSP - Damond Motorsport OCC AccessPort V2 Self tuned |
Groans: 189
| Not Ranked : 0 score I hate the fact that the site spams the fuck out of you if you don't use it on mobile.
__________________ |
![]() Join Date: Jan 2014 Location: Kissimmee FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 191
| Not Ranked : 0 score I cant even find msf on my nexus 10 tablets tapatalk!! Ever since the update to 5.0 msf doent exist on the free version but asks me to down load the pro version... wierd :/ |
| Not Ranked : 0 score We have a local NATOR member who couldn't find MSF in Tapatalk. That got me and a couple others looking for it and we couldn't find it either. Weird. Tapatalk sucks but is better than viewing in browser. @laocas01; How did you find MSF in tapatalk? Sent via Tapafail
![]() | | #24 | ![]() |
| Not Ranked : 0 score I have it on my phone, and used to have it on tablet till I reset it and installed Android 5.0. Now the only thing that shows up is mazda247 and a few others. It is weird. . lol |
![]() | | #25 | ![]() |
![]() Join Date: May 2009 Location: Memphis, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,249
| Not Ranked : 0 score Tapatalk has always sucked for me on vzw. If I connect via a VPN my experience is improved but not perfect. Weird, vzw doesn't like MSF.org or Tapatalk idk
__________________ 2006 MS6 Titanium Grey BSD, Custom 3" SRI, 3" HTP TIP, Custom 2.5" Single Exit Exhaust, Nator Sytle Downpipe, E40 Selftune, AutoTechs, Ghetto Mod'ed Stock BPV, VTCS Delete, IM PnP & AWR RMM3 Tuned with |
![]() | | #26 | ![]() |
![]() Join Date: Nov 2010 Location: Columbus, GA
Rep Power: 4253 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,493
Groans: 307
| Not Ranked : 0 score @ItsNox; Just typed in Mazda and it came up.
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() |
![]() | | #27 | ![]() |
| Not Ranked : 0 score Oddly enough I typed Mazda in again on my tablet and low and behold the forums show up again! I'm happy now.. Lol |
| MSF & Tapatalk | trancehead | Website Help/Feedback | 24 | 12-04-2014 09:56 AM |
| TapaTalk | wakeboarddude | Website Help/Feedback | 20 | 03-11-2010 07:25 AM |
