Go Back   Mazdaspeed Forums > MSF News And Event Info > Site News & Events > Hot Deals Section
Hot Deals Section Share your hot deals from around the web here!!
  • 1 Post By navyspeed3
 Old 08-06-2014, 03:20 PM   #1
navyspeed3's Avatar
Posts: 115   (View Stats)
navyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond reputenavyspeed3 has a reputation beyond repute
Default Cobb Military Discount
Cobb still does a military discount but they do require validation of the status though. So if you plan on getting anything from them make sure you let them know so they can hook you up with that 15% off. So a big thanks to Cobb for offering one of the best military discounts!
tbcota25 likes this.
navyspeed3 is offline   Reply With Quote
The Following 3 Users Say Thank You to navyspeed3 For This Useful Post:
Anthony1982 (08-07-2014), LED_Vera (09-22-2014), tbcota25 (08-06-2014)
 Old 09-22-2014, 05:54 PM   #2
LED_Vera's Avatar
Posts: 105   (View Stats)
LED_Vera is a splendid one to beholdLED_Vera is a splendid one to beholdLED_Vera is a splendid one to beholdLED_Vera is a splendid one to beholdLED_Vera is a splendid one to beholdLED_Vera is a splendid one to beholdLED_Vera is a splendid one to beholdLED_Vera is a splendid one to behold
Bump
I didnt know about this until today when i saw it on their site. I am not sure if they grant veterans the discount but that would be awesome!
I just emailed them to see what info is needed to get the discount.
Spread the word and save some money!
2012 Mazdaspeed3-
// Cobb SRI // CNT 3" Stainless Catback // Cobb Air box // Cobb AP // Autotech HPFP Internals // Cobb RMM // Eibach Lowering Springs // Cobb Shift Weight // Cobb Exhaust Hangers // Cork Sport TMIC // CorkSport F/R Brake Pads // SS Brake lines // SURE TIP (I know... its junk) // CorkSport CF Hood Scoop // Cobb Catted Downpipe // One Resonator Delete // JBR Rear Sway Bar // Track Wheels & Tires // 17x7.5 +45 Offset Sparco Assetto Gara Rims // 225/45ZR-17 BFGoodrich G-Force Rival Tires //
LED_Vera is offline   Reply With Quote
 Old 09-23-2014, 12:35 PM   #3
LED_Vera's Avatar
Quick response from Cobb Tuning!
I would like to note that is available to Active/Reserve and Vets.
What you will need to do is email Cobb from .mil email address (Currently Serving)
If you do not have a .mil email, a veterans ID will work, you will have have to scan it and email it to Cobb.
Within ten minutes they sent me the code.
Saved $105 on a Cobb down pipe for my 2012 Mazdaspeed 3
2012 Mazdaspeed3-
Last edited by LED_Vera; 09-23-2014 at 12:37 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-30-2014, 09:54 AM   #4
kvg823's Avatar
Posts: 58   (View Stats)
kvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant futurekvg823 has a brilliant future
Bumping this because of all the monies I could have saved had I known!
2006 "GTMO Green" Speed 6
{ Corksport TBE w/ resonator }{ COBB AP }{ Corksport Max-Flow internals }
{ TWM STS Stg 2 w/ bushings }{ Primary/Secondary EGR Deletes }{ JBR Motor Mount Trilogy}
{TurboSmart BPV }{ COBB TIP }{ SS Brake/Clutch Lines }{ ARP Head Studs }
HTP 4" intake w/ 51R }{ FMIC }{ Enkei PF01 Rims }{ Stoptech Slotted rotors }{ AEM Wide-band AFR gauge }
AEM TRU-Boost Controller }{ Gauge pod (Block8head) }{ Bnoon Bolt }
{ Turbo-timer (yeah...) }{ PERM Plate }{ JBR Intake/TB TIGs }
{ Coming Soon: install GT3071r EWG setup, CPE Seals, tune, and re-paint }
kvg823 is offline   Reply With Quote
Cobb Tuning Military Discount Through EdgeAutosport EdgeAutosport.com EdgeAutosport.com 26 05-03-2015 10:12 PM
military discount? bombdotcom EdgeAutosport.com 62 04-26-2013 07:40 AM
military discount? bombdotcom JAMES BARONE RACING 12 04-19-2013 10:52 AM
COBB military discount bombdotcom Gen2 MS3 General Discussion 7 04-16-2013 10:34 AM
GM Military Discount Haltech Automotive News 0 06-30-2008 09:20 AM
Page generated in 0.25685 seconds with 22 queries
