 Old 12-05-2010, 01:03 PM   #1
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
Default 3.5 Bar Map Sensor Upgrade help
I was installing my new 3.5 Bar map sensor and i cut the wiring harness connector for my stock map. Then i Noticed oh shit 2 of the wires are the same color. I connected it all to the best of my ability to take a 50/50 chance on which goes where.
I decided to break out my ohm meter and trade the lines to the pcm connector, NONE of the 4 wires i can get to make a connection to the PCM connector and this is testing directly at the wiring harness wire, not the new connector so I know for sure I am making contact on the wires.
Has anyone else had any trouble testing this to make sure its wired correctly. I want to make sure its right.
I know the meter works because when i touch the two leads together it works.
 Old 12-05-2010, 01:08 PM   #2
mtnrunner's Avatar
Posts: 864   (View Stats)
mtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the worldmtnrunner is the leader of the world
we messed this up on turd's car. those damn brown wires have polarity too. if you hook them up backwards you will get a cel and crazy map readings. all you have to do to get it to go back to normal is switch those two wires.
Murdered out 2007 speed3 GT with navi.
mtnrunner is offline   Reply With Quote
 Old 12-05-2010, 02:20 PM   #3
Jarods7920's Avatar
Posts: 1,415   (View Stats)
What 3.5 bar map did you get? I was looking to get one instead of a 3 bar, but not sure if the one i found will work or not.
 Old 12-05-2010, 02:37 PM   #4
Daily Driver
Nitr0EngiE's Avatar
3.5 Bar Bosch map sensor
Home » Shop » Sensors » Pressure Sensors » Bosch 3.5 Bar TMap Map Sensor with IAT
Pigtail BSK Connector needed
Home » Shop » Connectors / Harnesses » Bosch » 4-way sealed Plug Bosch BSK Connector Pigtail for Bosch MAP Sensor
 Old 12-05-2010, 02:53 PM   #5
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
MAP/boost air temperature sensor terminal A and PCM terminal 2AV
MAP/boost air temperature sensor terminal B and PCM terminal 2N
MAP/boost air temperature sensor terminal C and PCM terminal 2AU
MAP/boost air temperature sensor terminal D and PCM terminal 2AG
 Old 12-05-2010, 04:02 PM   #6
Daily Driver
Nitr0EngiE's Avatar
ss i have the same diagram from the manual, but when i try to test connection between the harness and pcm connector i cannot get an ohm/continuity reading. I tried both pcm connectors in the 3 mentioned pins.
i stuck a piece of wiring down the holes in pcm connector to make contact and its not working.
 Old 12-05-2010, 04:29 PM   #7
Groans: 60
If the MAP was working properly before you cut the connector off, there has to be continuity like the diagram shows. Even with the SB wired in you would still get continuity between three of the four wires?
Is your meter working right? Your probably just not making contact in the ECM connectors.
The proper connections for your new map are...
MAP/boost air temperature sensor terminal A and PCM terminal 2AV-- sensor ground reference--this wire will also meter continuity to chassy ground
MAP/boost air temperature sensor terminal B and PCM terminal 2N-- BAT output to ECM
MAP/boost air temperature sensor terminal C and PCM terminal 2AU-- +5v from ECM to sensor
MAP/boost air temperature sensor terminal D and PCM terminal 2AG-- MAP output to ECM
 Old 12-05-2010, 09:47 PM   #8
Daily Driver
Nitr0EngiE's Avatar
well i dont know if i should even stress it so much, if its wrong simply switch them up
The Following User Says Thank You to Nitr0EngiE For This Useful Post:
mtnrunner (12-06-2010)
 Old 12-05-2012, 10:34 AM   #9
bcmurphy87's Avatar
Posts: 1,435   (View Stats)
Sorry to dig up an old thread but what values did you use for the 3.5 in ATR?
06 Speed6 GT- Sold
 Old 12-05-2012, 11:11 AM   #10
chris this is the wrong thread haha
keep searching under the same OP
bcmurphy87 (12-05-2012)
Stock Fitment 3 Bar Map Sensor Upgrade JumpingJackson MazdaSpeed 3/6 - ECU Computer Tuning 529 02-23-2017 05:15 PM
Upgrade Help laverass22 Appearance - METRO GREY 11 07-02-2010 07:11 AM
Does Homelink Mirror rain sensor replace OEM rain sensor? Chinsel MazdaSpeed 3/6 - Car Audio & Electronics 5 02-25-2010 11:36 AM
endlink upgrade needed w/ ASB upgrade? red07 MazdaSpeed 3/6 - Suspension & Brakes 12 11-26-2008 01:34 AM
Eee PC gets an upgrade Haltech Computers & Technology News 0 04-15-2008 02:00 PM
Page generated in 0.31114 seconds with 26 queries
