| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Jan 2011 Location: Maryland
(Thread Starter) | Not Ranked : 0 score So since i've been "stalking" the forum i've learned alot....but something has been puzzling me for quite some time...If these cars are load tuned...how is it that bolt ons give any additional power if the ecu is always going to stay around a pre-determined load target? Now i know that the AP and HT raise the load values which is fine but its still looking for a "target" and then begins pulling power. It seems that boost tuning is the true way to get more power without having abs load as a factor...is this correct or does the car make more power with the same load value with bolt-ons...sorry for the round-a-bout way of asking... |
![]() Join Date: May 2011 Location: Saint Joseph, MO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
| Not Ranked : 0 score Well I am still new to the MS3 but my guess is that each bolt on has a purpose...most either make the engine breathe better, cool intake air temps down, or raise boost/timing which all creates more power...the only one of those that should actually raise the load on your engine would be the higher boost/timing levels imo...but again I'm no expert this is just an educated guess |
Groans: 136
| Not Ranked : 0 score What the PCM calls "load" is a calculation of the volumetric efficiency of the engine. This is a number that represents the decimalized percentage of the combustion chamber that is filled with clean air at atmospheric pressure. I'm way too lazy to type up a whole explanation of VE on my iPhone, so just google it and read up. Point is, more load = more power. Sent from my iPhone using Tapatalk
__________________ |
| Not Ranked : 0 score Yeah but more load also equals more risk of going boom |
Groans: 136
| Not Ranked : 0 score That's the case with any car that's modified for more power. Sent from my iPhone using Tapatalk
| Not Ranked : 0 score Yep...some hold much better than others though...for example coming from SRT-4s and Evos but at the same power levels I had several issues with the Evos and ZERO with the silly little neon...imagine that |
![]() Join Date: Mar 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 895
| Not Ranked : 0 score yea are reaching the same load levels yes...but you are reaching them more than likely at lower boost levels....more quickly...and more efficiently however as you pointed it out in your posts...you will never be able to FULLY utilize the gains from your mods without a tune |
| The Absolute Worst Gen2 Dyno | nynhex | 2010 MS3 - Dyno Sheets/Discussions | 37 | 05-03-2010 10:24 AM |
| What is the Absolute Load Targets table used for | djuosnteisn | Cobb ATR Support | 9 | 09-02-2009 09:08 PM |
| Absolute Throttle Postion Percentage | Speed3FTW | MazdaSpeed 3/6 - ECU Computer Tuning | 14 | 06-29-2009 01:38 PM |
| Absolute beefyness, you can't get any better than this | steven88 | Custom Performance Engineering (cp-e.com) | 10 | 04-19-2009 08:36 PM |
