 Old 08-02-2013, 04:47 PM   #1
GlennMPS's Avatar
Posts: 16   (View Stats)
GlennMPS will become famous soon enoughGlennMPS will become famous soon enough
Default ATR Fuel Tables??? (AFR / Lambda?)
I am currently following Abilors Guide, in Chapter 6: Fuelling Targets, he shows a table (Fuel CL Commanded EQ base) that shows the values...
RPM Read Only
Calculated Load Read Only
Commanded Fueling (AFR)
When I select the same table in my ATR I get the values
Engine RPM
Scalable Calc. Load B (Load)
Commanded Fuelling (Lambda)
Basically i have spent the past 2 weeks doing MAF Cals to hit a brick wall as the Values i see on my table are completely different to what is being described.
Please Help!
Thanks
Glenn.
GlennMPS is offline   Reply With Quote
 Old 08-02-2013, 04:49 PM   #2
LumberJack's Avatar
Groans: 57
Post screen shots of what you are trying to change and accomplish. What afr's are you trying to actually command? OL or CL
10.36@148 Fastest Gen 2
 Old 08-02-2013, 04:57 PM   #3
GlennMPS's Avatar
Here we go...
Firstly Abilors screen shot in part 5 of his guide,
Now my screen shot of my ATR, with different units???
 Old 08-02-2013, 05:06 PM   #4
LumberJack's Avatar
Groans: 57
Originally Posted by GlennMPS View Post
Here we go...
There in lambda not afr. You need to change your settings to read in afr
Sent from my SPH-L900 using Tapatalk 2
 Old 08-02-2013, 05:28 PM   #5
Pointless's Avatar
Posts: 171   (View Stats)
Pointless is the leader of the worldPointless is the leader of the worldPointless is the leader of the worldPointless is the leader of the worldPointless is the leader of the worldPointless is the leader of the worldPointless is the leader of the worldPointless is the leader of the worldPointless is the leader of the worldPointless is the leader of the worldPointless is the leader of the world
Groans: 104
Click -edit
-Configure option
Tab -Display
use standard unit
rejoice
MS3 2012 CWP
• Cobb AP • HTP 3" INTAKE • CorkSport RP - TMIC - TMM • Autotech HPFP • GFB BPV • CP-E RMM • MishiMoto OCC
• Denso ITV22 • Devil's Own WMI DVC-30 Stage 2
Pointless is offline   Reply With Quote
The Following 4 Users Say Thank You to Pointless For This Useful Post:
bob^3 (08-02-2013), GlennMPS (08-02-2013), jm211 (08-02-2013), LumberJack (08-02-2013)
 Old 08-05-2013, 10:37 AM   #6
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Lambda is an excess air ratio with a value of 1.0 being the stoichiometric ratio for the fuel you are using.
When you change the settings in ATR to display "Standard Units", the software will convert all the Lambda values to AFR Gasoline with 1.0 Lambda being 14.7.
A 12.0 AFR will be displayed as 0.816 Lambda (12.0/14.7) and so forth..
www.tunedbynishan.com
Fuel Tables Problems, wtf is going on? BlewisMSF11' 2010 MS3 - ECU Computer Tuning 4 04-08-2012 06:13 PM
Why do my fuel tables display like this? stratman MazdaSpeed 3/6 - ECU Computer Tuning 2 10-22-2011 08:47 PM
Help Needed - Can't see some fuel tables listed in ATR Helpfile MEE MazdaSpeed 3/6 - ECU Computer Tuning 1 02-16-2011 08:55 PM
Missing fuel tables in ATR? evidence
Cobb ATR Support
35 06-08-2010 06:34 PM
2 ATR Fuel Tables Missing... I want them dougefresh_
Cobb ATR Support
1 03-29-2010 07:06 AM
Page generated in 0.27035 seconds with 23 queries
