 Old 10-14-2012, 09:55 PM   #1
shawn.'s Avatar
Posts: 541   (View Stats)
shawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the worldshawn. is the leader of the world
Groaned at 22 Times in 16 Posts
Default Base map for BT
hey guys i am gonna be finishing installing my ATP GTX3071r this week and i was hoping someone could hook me up with a base map for the turbo so i can get it up and running? or even help me out a little with where i can find some info or something. thanks
ATP GTX3071r// Cobb 3 Port EBCS // 3 Bar MAP // Cobb Accessport Freek Tuned // E85 Mix // JBR 3.5" Intake/TIP // Treadstone TR8C FMIC // Autotech HPFP Internals // Ported IM //C-pe Catted Downpipe // TRZ RMM // Corksport CBE // ISC Coilovers // EBC Slotted Rotors--Redstuff Pads // TWM shifter bushings // Dashhawk v2 // 6000k HIDs
Built engine--Manley H Beam Rods--Wiseco Pistons
shawn. is offline   Reply With Quote
 Old 10-14-2012, 09:57 PM   #2
lilred's Avatar
Posts: 5,792   (View Stats)
Who will be tuning you? I'm sure they can provide a base map.
tapafuck
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
 Old 10-14-2012, 10:15 PM   #3
shawn.'s Avatar
gonna be self tuning. i tuned myself on the stock turbo and feel confident i can tackle this as well.
 Old 10-14-2012, 10:17 PM   #4
speeed's Avatar
Posts: 2,999   (View Stats)
speeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the worldspeeed is the leader of the world
Groaned at 50 Times in 17 Posts
So, make your own base map....
2012 LSM MS3
Some mods, No list, too much "zapos".
speeed is offline   Reply With Quote
The Following 13 Users Say Thank You to speeed For This Useful Post:
86AmishMs3 (10-15-2012), Black Metal (10-15-2012), breakfstincluded (10-14-2012), dantes5823 (10-15-2012), DONOTBUGME (10-14-2012), Easter Bunny (10-15-2012), J'sSpeed3 (10-16-2012), lilred (10-15-2012), madspd6 (10-14-2012), ms6mil (10-14-2012), RichieRichness (10-15-2012), SarcasticOne (10-15-2012), snailD (10-15-2012)
 Old 10-15-2012, 01:49 AM   #5
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
Do maf resize, set wgdc to 0...
The Following User Says Thank You to SarcasticOne For This Useful Post:
 Old 10-15-2012, 02:20 AM   #6
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Biggest thing is changing scaling the maf if you've upgraded to a big maf as stated. Then depending on ebc or mbc, set it low, set timing low, set AFR low. And start fresh and slow.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following 2 Users Say Thank You to 86AmishMs3 For This Useful Post:
helmetface (10-15-2012), shawn. (10-15-2012)
 Old 10-15-2012, 04:26 AM   #7
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
Area of new maf/area of old maf
RichieRichness is offline   Reply With Quote
The Following User Says Thank You to RichieRichness For This Useful Post:
shawn. (10-15-2012)
 Old 10-15-2012, 11:53 PM   #8
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Like Richie said, take the cross-sectional area (pi x radius^2) of the new larger MAF housing and divide it by the cross-sectional area of the MAF housing you currently tuned your car with. Multiply the result by entire MAF curve. Then perform MAF calibartion.
Set your entire WGDC table to 0 and zero out the underboost side of the Boost error comp and load error comp. This will allow you to run on spring pressure and not allow the ecu to add any WGDC to achieve targets.
This is the best way to start a BT base map. It will allow you to run as little boost as mechanically possible while you get all the basic things dialed in. Also, you may want to run a richer AFR until you get things dialed for safety. Then later you can lean things back out and work your way up on boost. Take your time.
www.tunedbynishan.com
The Following 3 Users Say Thank You to ms3blackmica For This Useful Post:
Boost_creep (10-16-2012), RichieRichness (10-16-2012), shawn. (10-16-2012)
 Old 10-15-2012, 11:57 PM   #9
dantes5823's Avatar
Posts: 6,576   (View Stats)
dantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the world
Groaned at 52 Times in 48 Posts
Ok so 3 inch just take go with 25 percent. 3.5 use 66 percent. That'll get you running. From their you do the same shit as before.
But the simple math is (new maf id/old maf id) ^2
Also depending on how you installed things you may get boost creep. Don't freak out and panic. Just keep tuning and it'll go away.
dantes5823 is offline   Reply With Quote
The Following 3 Users Say Thank You to dantes5823 For This Useful Post:
ms3blackmica (10-16-2012), RichieRichness (10-16-2012), shawn. (10-16-2012)
 Old 10-16-2012, 06:53 AM   #10
Groans: 35
so when are you gonna join RichTune
The Following 3 Users Say Thank You to RichieRichness For This Useful Post:
2eatV8everyday (10-21-2012), Boost_creep (10-16-2012), ms3blackmica (10-16-2012)
CP-E Base map for Big Turbo 1sik3 MazdaSpeed 3/6 - ECU Computer Tuning 12 04-01-2011 10:51 AM
right base map for me trioskater
Cobb ATR Support
4 05-08-2010 04:05 PM
What should I use as my base map GQ_WhiteMS3
Cobb ATR Support
32 05-16-2009 05:25 PM
Page generated in 0.30160 seconds with 27 queries
