 Old 03-25-2013, 07:34 PM   #1
alphasaur's Avatar
Posts: 2,847   (View Stats)
Groans: 235
Default check my logs please
So I've been messing around with ethanol and I've gone through several threads along with buckers checklist and abilor's guide. For some reason I seem to have a lean spot for 1-2 cells around 3.8~ volts. I've tried OL maf cal in this voltage range for about 4 revisions and I've narrowed it down but still there. Any tips? Also, seems like I'm not making the power others are with ethanol. My timing seems to be pretty aggressive but I dunno, the ring thread scares me.
Here are the last two logs and a pic (1.0 cf Log 3 is a newer map than log 79.)
@phate; @Boost_creep;
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/lol nator.
 Old 03-25-2013, 07:54 PM   #2
jseams's Avatar
Posts: 1,414   (View Stats)
jseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the world
I wouldn't call your timing very aggressive. I'm running about 18* at 6K and 19* at 6.3K and I've seen folks running several degrees more than this.
I did check some of my older logs on my earlier e85 maps that had comparable timing - and yes, compared to them you seem to be short a few HP... but I'm not sure that it's an apples to apples comparison.
What's your mix?
CRMetallic 2019 Mercedes C43 AMG
SOLD MNBlue 2012 S4 Prestige... a few mods
SOLD IB 2015 3.8 Gencoupe Ultimate
BLOWED UP DIB 2014 Mustang 5.0... a few mods
SOLD - LS 2012 MS3
Cobb AP//SF//CAB
Autotech HPFP
Corksport TMIC//BPV//TIP//BTbs
JBR 88a RMM
Sure M3 TP
OBX CBE
Tanabe NF210's
ADVAN RG-D 18x8 +38
Freektuned 50/50 E85
jseams is offline   Reply With Quote
The Following User Says Thank You to jseams For This Useful Post:
alphasaur (03-25-2013)
 Old 03-25-2013, 07:58 PM   #3
alphasaur's Avatar
Groans: 235
What's your mix?
40%. Adding timing in the later log didn't seem to add any power either.
/speed 3- bye
/lol nator.
 Old 03-26-2013, 05:43 AM   #4
Boost_creep's Avatar
Posts: 829   (View Stats)
Chris, I can not view the logs on my phone. Can you email them to me?
If your worried about possible ring failure, a compression test may be in order.
www.dizzytuning.com
www.facebook.com/dizzytuning
The Following User Says Thank You to Boost_creep For This Useful Post:
alphasaur (03-26-2013)
 Old 03-26-2013, 12:34 PM   #5
fivefingerdeathpunch's Avatar
Posts: 437   (View Stats)
you dont happen to have a random spike/dip in your maf table at that point do you?
 Old 03-26-2013, 03:40 PM   #6
alphasaur's Avatar
Groans: 235
@Boost_creep;
180 180 150 180
shet.
/speed 3- bye
/lol nator.
 Old 03-26-2013, 08:04 PM   #7
udntknw's Avatar
Posts: 1,062   (View Stats)
Groaned at 9 Times in 7 Posts
Did you happen to try and put a couple drops of oil in that cylinder and recheck? That'll tell you for sure it's the rings if the compression comes back.
just tap it in...
**Old Motor**
Best trap speed - 112mph
**New Motor**
Best trap speed - 112.5
The Following User Says Thank You to udntknw For This Useful Post:
Another 'check my logs please' speed d3mon 2010 MS3 - ECU Computer Tuning 3 03-18-2012 10:06 PM
Check my logs please kabobulate MazdaSpeed 3/6 - ECU Computer Tuning 11 05-01-2011 02:01 PM
Check out my logs pls arielmalespin MazdaSpeed 3/6 - ECU Computer Tuning 8 03-28-2011 10:22 PM
Yo! check my logs plz. mr_mazda329 MazdaSpeed 3/6 - ECU Computer Tuning 22 02-26-2011 09:57 AM
Can someone please check my logs? ColoradoMS6
Cobb ATR Support
5 07-18-2010 09:53 PM
Page generated in 0.27758 seconds with 25 queries
