 Old 09-22-2008, 02:41 PM   #1
booya620's Avatar
Posts: 697   (View Stats)
booya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the worldbooya620 is the leader of the world
Default Closed and open loop
I guess I'm missing something when reading some of the posts on this site. There are several instances where people have referred to open and closed loop in posts. From what I remember open and closed loops refer to oxygen sensors. Closed loop is what your ecu runs while your o2 sensors are heating up and open loop is what your o2 sensors run at once they are full heated. At least this is what i remember. In several posts people have refered to closed loop has running under 3-3.5k and open loop above. I haven't heard these terms used in this fashion before can somebody please explain this to me. Is this in reference to wot only?
booya620 is offline   Reply With Quote
 Old 09-22-2008, 02:42 PM   #2
Moving this to ECU Tuning
 Old 09-22-2008, 04:36 PM   #3
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
I may be wrong don't hold me too this but on the dash hawk at the bottom right hand corner doesn't that little box that goes C,O and L on a 4 box pid screen tell you if your in open or closed loop? if so im closed loop most of the time with blips of open near or between 2k and 3.5 k while im accelerating slowly im all open loop if coasting OUT of gear. coasting in gear is mainly C and L. Now don't hold me to this just yet I could be completely off.
Carry on citizens....
10.7 @ 133 auto 1G DSM
 Old 09-22-2008, 09:20 PM   #4
the car is ALWAYS in closed loop unless you are WOT or you are decelerating with your foot off the gas completely. this is a widely talked about topic so just do some googling....
Sasuke-kun (01-12-2019)
 Old 09-22-2008, 09:23 PM   #5
kingpin748's Avatar
Posts: 2,611   (View Stats)
kingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the worldkingpin748 is the leader of the world
Groans: 78
Groaned at 48 Times in 31 Posts
I've seen a few threads now with people claiming it's in open loop above 3000-4000RPM regardless of WOT.
Any truth to that?
In reality I love lenny
kingpin748 is offline   Reply With Quote
 Old 09-22-2008, 09:25 PM   #6
NYpest's Avatar
Posts: 1,889   (View Stats)
NYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the world
the second o2 sensor feed back triggers closed loop and open loop it is this that tries to keep the car stoich AFR while in closed loop keeping the MPG up
Piasini Tuned
power mods=SRI/Autoexe TMIC
312whp/336 tq
NYpest is offline   Reply With Quote
 Old 09-22-2008, 09:35 PM   #7
jweller's Avatar
Posts: 426   (View Stats)
jweller has a brilliant futurejweller has a brilliant futurejweller has a brilliant futurejweller has a brilliant futurejweller has a brilliant futurejweller has a brilliant futurejweller has a brilliant futurejweller has a brilliant futurejweller has a brilliant futurejweller has a brilliant futurejweller has a brilliant future
Open loop does NOT use the O2. Closed loop does use the O2.
you use open loop until the car reaches normal operation temps, is in WOT or a high throttle postion, or under decel with the throttle plate closed. there is great benefit in fuel economy and emissions to running in Closed loop, so car makers try to stay in it as much as is reasonable
jweller is offline   Reply With Quote
 Old 09-22-2008, 10:01 PM   #8
NYpest's Avatar
thats what i ment
Piasini Tuned
312whp/336 tq
 Old 09-22-2008, 11:04 PM   #9
Fux Wit It
Darksun280's Avatar
Groans: 175
That means I'm right Dash hawk tells you what loop your in cause when I started the car tonight it was at "O" and after I let it warm up and started driving normal it goes to "C". Under WOT I start at C then its goes to "L". On deccel out of gear its in open loop and deccel in gear its in closed loop
 Old 09-23-2008, 08:46 AM   #10
AutoXRacer's Avatar
Posts: 1,590   (View Stats)
So what the hell does the "L" stand for? I've seen that too...
2008 Stage 3 Roush Mustang
AutoXRacer is offline   Reply With Quote
 Old 09-23-2008, 08:56 AM   #11
Fux Wit It
Darksun280's Avatar
Groans: 175
No Idea but when I'm wot I'm mainly in L
 Old 09-23-2008, 09:00 AM   #12
NYpest's Avatar
Here you go fockers
Fuel System Status (C = Closed Loop, O = Open Loop, L = Open Loop due to Engine Load, F = Open Loop due to a Failure/Trouble
Code, P = Closed Loop with Problems, - = Data not available, U = unknown status)
When this value is displayed on the screen or on the PC from a data log, the following values are used:
0 = Unknown
1 = Open Loop
2 = Closed Loop
4 = Open Loop due to Engine Load
8 = Open Loop with Fault
16 = Closed Loop with Fault
http://www.dashhawk.com/downloads/Da...er%20Guide.pdf
Piasini Tuned
312whp/336 tq
The Following 8 Users Say Thank You to NYpest For This Useful Post:
booya620 (09-23-2008), Colonel Speed (09-23-2008), Darksun280 (09-23-2008), Fobio (09-23-2008), gsrtype1 (09-23-2008), kingpin748 (09-23-2008), SLS MS3 (09-23-2008), thejake (09-26-2008)
 Old 09-23-2008, 09:01 AM   #13
Fux Wit It
Darksun280's Avatar
Groans: 175
Originally Posted by NYpest View Post
Here you go fockers
Thank you Tim
 Old 09-23-2008, 09:05 AM   #14
AutoXRacer's Avatar
Thank you Tim
Sweet!!!!
 Old 09-23-2008, 09:09 AM   #15
Laloosh's Avatar
Posts: 5,166   (View Stats)
Laloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the world
Groans: 57
I said the rear o2 has significant change over the a/f ratio almost a year ago....
Our car doenst work liek traditional cars....that rear o2 is there for more reasons then just to monitor the cat.
You don't beleive me? Install a diode in your 2nd o2, watch your commanded a/f ratios go from 14.7 to 14.2....yes its not good for gass mileage to have a 14.2 af ratio at idle and cruising, but lets think about partial throttle/transition parts of the rpm band.....could be the very reason my car is still alive today
Laloosh is offline   Reply With Quote
 Old 09-23-2008, 09:12 AM   #16
Fux Wit It
Darksun280's Avatar
Groans: 175
same here im at 14.2-14.4 like chris and my LTFT are at +5.5 at idle and 10.9 at wot
 Old 09-23-2008, 09:13 AM   #17
SgtP's Avatar
Posts: 2,130   (View Stats)
SgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the worldSgtP is the leader of the world
Groans: 106
you have a diode on your 2nd o2 chris? or are you saying dont do it.
13.2@111
CP-E Nano, CP-E Inlet, CP-E catless DP, CP-E Standback V2, CPE FullThrottle/No Cut Flash, CP-E FMIC, CP-E CDFP, CP-E HKS BPV, TRZ Poly MM, E4P Shifter, Denso Iridium ITV22 plugs, CP-E Towplate, PG V3 Manifold w/EGT bung, Saikou Michi OCC, EGR delete, BSD w/oil baffle, BC Coilovers w/front camber adjustment, SPC rear arms, 17x8 Anthracite O.Z. Alleggerita's wrapped in Nitto NT01's
Originally Posted by rodrigo View Post
damn josh u are pretty.... i swear if tina hadnt taken you id so rail u
Certified Personal Trainer/Nutritional Consultant - I can cure Skinny, Fat and Weak
http://jpnutritionandfitness.blogspot.com/
Sponsored By: CP-E
SgtP is offline   Reply With Quote
 Old 09-23-2008, 09:14 AM   #18
Fux Wit It
Darksun280's Avatar
Groans: 175
don't do it
 Old 09-23-2008, 09:16 AM   #19
NYpest's Avatar
Phil we talked about this at the meet remmeber with out that rear o2 sensor feed back your cars is all confused on what its suposed to be doing
Piasini Tuned
312whp/336 tq
 Old 09-23-2008, 09:17 AM   #20
Laloosh's Avatar
Groans: 57
actually i have installed it 3 days ago. With the cold weather i finally started getting the p0139 code. I was running 14.7 the second i installed the diode, 14.2
with my last tbe, the way they had the o2 positioned also commanded 14.2, then i switched to cpe's tbe and it went up to 14.7, now its back at 14.2 with the diode
 Old 09-23-2008, 09:20 AM   #21
NYpest's Avatar
Im sure with the standback you can fix that but maybe your trying to say its something you found to be productive ?
Piasini Tuned
312whp/336 tq
 Old 09-23-2008, 09:23 AM   #22
Laloosh's Avatar
Groans: 57
its something i find helpfull.
the car commands 14.2 not 14.7, meaning partial throttle its 14.2 then dips to the 12s the second you touch the gas. No partial boost and 14.7 a/f ratios. Why does it work? Who knows, i dont know the exact role of the 2nd o2, but like i said, it sure as hell isnt just to monitor the cat
 Old 09-23-2008, 09:24 AM   #23
Fux Wit It
Darksun280's Avatar
Groans: 175
well mine reads 14.2 with the 02 extender. Chris you whore your suppose to let me know when you do things to your car...
 Old 09-23-2008, 09:25 AM   #24
SgtP's Avatar
Groans: 106
im at 14.7 now. maybe ill throw on a diode when i install the SB.
13.2@111
Sponsored By: CP-E
 Old 09-23-2008, 09:27 AM   #25
Fux Wit It
Darksun280's Avatar
Groans: 175
but you WANT to be at 14.7 lol
 Old 09-23-2008, 09:30 AM   #26
SgtP's Avatar
Groans: 106
damnit stop confusing me! lol so 14.7 is the goal here?
13.2@111
Sponsored By: CP-E
 Old 09-23-2008, 09:30 AM   #27
NYpest's Avatar
maybe its the diode calc of by a bit?
Anyway cool
Piasini Tuned
312whp/336 tq
 Old 09-23-2008, 09:32 AM   #28
NYpest's Avatar
I think hes saying that the 14.2 is helping him with the "lean" area @ onset of boost
Piasini Tuned
312whp/336 tq
 Old 09-23-2008, 09:33 AM   #29
Laloosh's Avatar
Groans: 57
its your call in the end.
Personally until cpe cracks this open close loop bullshit, the richer at partial throttle the better
 Old 09-23-2008, 09:35 AM   #30
NYpest's Avatar
Originally Posted by mordant80 View Post
Good info, but while we're on the topic. What exactly does open and closed loop mean? What is the purpose?
MPG /NO2 !! Closed loop is supposed to keep you at 100% clean burn (14.7 afr) while crusing and at idel your in closed loop saving gas and being GREEN
Piasini Tuned
312whp/336 tq
The Following User Says Thank You to NYpest For This Useful Post:
mordant80 (09-23-2008)
 Old 09-23-2008, 09:35 AM   #31
Laloosh's Avatar
Groans: 57
Anyway cool
it probably is, cause what a diode does is change whatever voltage goes through it to roughly .45-.50. That drop from whatever the original voltage was might make the ecu change what it thinks ti stoich.....once again this is all theory and i have no proof nor the tech know how to explain this in detail lol
as for as beeing green lol, im an enviornmental scientist...i also run no cats
 Old 09-23-2008, 09:41 AM   #32
NYpest's Avatar
The flashes Cobb/Piasini both adjust the part throttle maping and WOT maps Have you messed with the part throttle tables with the SB i know 0 about the SB so...
Piasini Tuned
312whp/336 tq
 Old 09-23-2008, 09:44 AM   #33
SLS MS3's Avatar
Posts: 1,254   (View Stats)
SLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the worldSLS MS3 is the leader of the world
Closed Loop - Input from the O2 sensors is being used in a feedback loop to keep your A/F ratio at 14.7:1 (stoich) for maximum fuel economy and minimum emissions. The feedback loop is connected, i.e. "closed."
Open Loop - Input from the O2 sensors is ignored. The engine gets its fuel ratios from lookup tables designed to richen the fuel mixture for maximum power. The feedback loop is disconnected, i.e. "open."
2007 Sunlight Silver MS3
Graphite RX8 Rims · 235/40R18 Kumho SPTs
BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM
Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust
mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
Stock is just plain, gay.
SLS MS3 is offline   Reply With Quote
The Following User Says Thank You to SLS MS3 For This Useful Post:
 Old 09-23-2008, 09:44 AM   #34
Laloosh's Avatar
Groans: 57
never messed with part throttle stuff on the standback yet
 Old 09-23-2008, 09:54 AM   #35
whoosh@Realtune's Avatar
Posts: 1,459   (View Stats)
whoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the world
Groaned at 39 Times in 23 Posts
I'm at 14.2 at idle through MAF xfer changes via the standback
2006 Mazdaspeed 6 / 386awhp/376awtq (Aug 2008)
2008 Caliber SRT4 / 11.8 @ 120
whoosh@Realtune is offline   Reply With Quote
 Old 09-23-2008, 09:56 AM   #36
NYpest's Avatar
nice
Piasini Tuned
312whp/336 tq
 Old 09-23-2008, 09:57 AM   #37
Laloosh's Avatar
Groans: 57
what were you at before. my maf xfer are 5 for the first row and 8 for half the 2nd row
 Old 09-23-2008, 09:59 AM   #38
I need to call you tonight to go over some SB stuff
getting really interesting.....
 Old 09-23-2008, 10:01 AM   #39
SgtP's Avatar
Groans: 106
yay! you guys do the hard work and ill just reap the benefits!
13.2@111
Sponsored By: CP-E
 Old 09-23-2008, 03:06 PM   #40
oskinosmee's Avatar
Posts: 743   (View Stats)
oskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant futureoskinosmee has a brilliant future
yea with my first o2 out i stayed in open loop, with it in its closed at idle and so on
Gotta Love The Turbocharged Wagon
oskinosmee is offline   Reply With Quote
How ECUs Use Closed-Loop Controls to Make Fueling Corrections v1.02 94jedi MazdaSpeed 3/6 - ECU Computer Tuning 22 05-13-2014 08:45 PM
Open/Closed Loop Transition, Some New Observations superskaterxes MazdaSpeed 3/6 - ECU Computer Tuning 1 07-18-2008 11:35 AM
Open Arms in Open Wheels: reunited IndyCar season kicks off at Homestead Haltech Automotive News 0 04-01-2008 09:20 AM
Alfa may buy closed factory from Big 3 for U.S. production Haltech Automotive News 0 03-31-2008 02:10 PM
Expiring Creative HN-700 Closed-Back Circumaural Headphones w/ Active Noise Reduction $24.99AR Haltech Hot Deals Section 0 03-31-2008 01:00 PM
Page generated in 0.58628 seconds with 32 queries
