 Old 02-03-2011, 08:49 AM   #1
ZeroOX's Avatar
Posts: 35   (View Stats)
ZeroOX is a name known to allZeroOX is a name known to allZeroOX is a name known to allZeroOX is a name known to allZeroOX is a name known to allZeroOX is a name known to all
Default Cobb access port / Tuning info looking to know if i am on the right path.
Hello, I am new to the speed3 modding world
I am not looking for someone to research for me I just want to know if i am thinking the right way. I don't want to mess up my car. I have been just reading the forums for 2 months trying to absorb all the info. There is a ton of it on here.
Current parts i have to install.
Corksport SRI with turbo inlet
CP-E DP catted.
rear motor mount insert (i know nothing to do with tuning.)
From what I have read I need to get an Cobb access port if i want these mods to work correctly with my car?
If I do not do an access port I will not get the power out of the mods. I have not seen another option that would give me the same benifits of the AP? am I missing a better option that provides the easy of plug and play?
I know i can get a custom tune but would rather not do that. I think for the same price the AP could get me where i want and still be able to do monitoring of my car.
I am not looking to do big power on the car. Just some bolt on mods to give it more power but continue to use it as a daily driver.
I guess I am just looking for a "hey noob you are on the right track" or a "do some more reading and learn more before you post!"
Also on a side note. Does anyone know of a shop in the richmond va area that would do a DP instalation? I would even drive to NoVa. Its a little cold out for me to do this in my driveway.
Thank you for the help.
ZeroOX is offline   Reply With Quote
 Old 02-03-2011, 08:52 AM   #2
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
you dont have to get a ap but what you are going to want is a fuel pump upgrade. your pressure will be sure to drop with the mods
2015 Mazda 6
The Following User Says Thank You to IshiKage For This Useful Post:
m4tic (02-03-2011)
 Old 02-03-2011, 12:29 PM   #3
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
While you don't need a tune with the parts you are planning for, you will get the maximum out of the car with one. That doesn't mean you won't gain any power with just the bolt-ons, because you definitely will. You could run it for a while and then, down the road, get a tune. The AP and CPE's standback are the most flexible products for tuning, and the Hypertech is just a plug and play deal with canned tunes (no custom tuning).
The AP has a datalogging feature that is worth the money, alone. The standback and hypertech do not have this functionality. Each have their ups and downs; there are good threads about this.
 Old 02-03-2011, 12:48 PM   #4
m4tic's Avatar
Posts: 4,928   (View Stats)
upgrade your fuel pump and lose the stock top mount intercooler
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
IshiKage (02-03-2011)
 Old 02-03-2011, 01:33 PM   #5
ZeroOX's Avatar
So to add a downpipe and intake i also have to add a tmic and a fuel pump? maybe my question was not clear. i just wanted to know if adding a dp and intake along with a tune will be safe to run and ok for the car.
if i have to do a fuel pump and a top mount intercooler to upgrade my downpipe and air intake.. i might as well sell the car and just get something that is out of the box faster.
 Old 02-03-2011, 01:36 PM   #6
m4tic's Avatar
no it will not... your fuel pump IS going to fail with flow mods as it cant meet higher volume demands
the stock tmic runs the turbo too hard to attain stock boost, let alone upped psi from a tune
spend a little more $$$ to alleviate these issues or drop more money on a new car
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 02-03-2011, 01:39 PM   #7
speedzilla's Avatar
Posts: 271   (View Stats)
speedzilla is the leader of the worldspeedzilla is the leader of the worldspeedzilla is the leader of the worldspeedzilla is the leader of the worldspeedzilla is the leader of the worldspeedzilla is the leader of the worldspeedzilla is the leader of the worldspeedzilla is the leader of the worldspeedzilla is the leader of the worldspeedzilla is the leader of the worldspeedzilla is the leader of the world
not true....you can run these mods without needing a fuel pump......you can monitor your fuel pressure on the cobb ap and if you see that it is not holding then ok, but i have ran the mods in my sig for the last 6 months with no problems with fuel pressure
Mods: DJ E-Tune, Cobb AP, Cobb SRI, RPMC Turbo Inlet, CxRacing FMIC, HKS SSQV, PG Manifold, TurboXS Catless DP, Turbo XS Test pipe, HKS Catback, Twm Short Shifter, Desert Eagle Shift Knob, Denso itv22 plugs, BS Delete mod, H&R Lowering Springs, NextMod spoiler, Kazera Kz-K Wheels, tinted 15%
speedzilla is offline   Reply With Quote
 Old 02-03-2011, 01:45 PM   #8
m4tic's Avatar
yes leave it up to chance and run your car on the stock fuel pump
an upgraded pump is just a strong suggestion
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 02-03-2011, 02:58 PM   #9
IshiKage's Avatar
Groans: 278
yeah but most likely the fp WILL drop. and that money he spent towards the ap could have bought an UPFP and he will still be able to run the car balls to the wall unlike with ap, intake, dp and fuel pressure dropping to 900psi
intake, dp, fp, fmic, ap is the route i would go, in that order.
my fuel pressure dropped with intake, tp and ap. so his pump will drop pressure with intake and dp, so UPFP should be next then FMIC to keep the bats cooler thus not losing power b.c of the shitty tmic
2015 Mazda 6
The Following 2 Users Say Thank You to IshiKage For This Useful Post:
m4tic (02-04-2011), Vanilla Gorilla (02-09-2011)
 Old 02-04-2011, 11:08 AM   #10
Orphen's Avatar
Posts: 24   (View Stats)
Orphen is just really niceOrphen is just really niceOrphen is just really niceOrphen is just really nice
Groaned at 17 Times in 2 Posts
Wheres a good place to buy a upgraded FP for a speed 6? Ive looked o streetunit and they dont carry one.
Orphen is offline   Reply With Quote
 Old 02-04-2011, 11:34 AM   #11
m4tic's Avatar
KMDtuning.com or cp-e.com
you can also order internals from goapr.com or awe-tuning.com ... everything is catered to AUDI/VW except for cp-e
2017 Daytona 392
2007 MS6 w/ Cheez
IshiKage (02-05-2011)
 Old 02-08-2011, 08:41 AM   #12
ZeroOX's Avatar
Thank you for the information.. but I think I need a little more help. I do not want to have to rebuild my FP. I would rather just buy one that I can instal. what would be the best bet.
I know cp-e makes one but $700 might be a little high on the price for me.
 Old 02-09-2011, 01:54 PM   #13
Vanilla Gorilla's Avatar
Posts: 95   (View Stats)
Vanilla Gorilla is a splendid one to beholdVanilla Gorilla is a splendid one to beholdVanilla Gorilla is a splendid one to beholdVanilla Gorilla is a splendid one to beholdVanilla Gorilla is a splendid one to beholdVanilla Gorilla is a splendid one to beholdVanilla Gorilla is a splendid one to behold
$700 now will save you 4 times that when failure comes into the playing field. Better to be safe than sorry my man...
Vanilla Gorilla is offline   Reply With Quote
 Old 02-09-2011, 02:20 PM   #14
char181's Avatar
Posts: 167   (View Stats)
char181 has a reputation beyond reputechar181 has a reputation beyond reputechar181 has a reputation beyond reputechar181 has a reputation beyond reputechar181 has a reputation beyond reputechar181 has a reputation beyond reputechar181 has a reputation beyond reputechar181 has a reputation beyond reputechar181 has a reputation beyond reputechar181 has a reputation beyond reputechar181 has a reputation beyond repute
I got a $380 quote from PTuning in Manassas to install a CP-e catted downpipe on my 2010 speed3.
Black Mica 2010 Speed3; Xcel Nano SRI; JBarone short shifter, bushings, shift knob and rear sway bar; Corksport RMM inserts; Ptp HPFP internals; Cobb AP; Corksport TMIC; Denzo ITV22;
CP-e CDP; Tuned by Ptuning
char181 is offline   Reply With Quote
 Old 02-10-2011, 07:08 AM   #15
ZeroOX's Avatar
So there is no other option for a drop in FP for this car? CP-E and everything else has to be rebuilt by me?
 Old 02-10-2011, 09:16 AM   #16
Eth Fiend
phate's Avatar
The only other option would be to send your pump out and have them do the rebuild. That would still require you to unhook the lines, pull the pump, and re-install. Check with KMD to see if they would do it. BUT, once you have it out of the car, its not much more to pull it apart and do it yourself. The hardest part is getting the damn thing out.
Cobb Access Port....Canadian! MPS MazdaSpeed 3/6 - ECU Computer Tuning 4 10-13-2008 03:57 PM
Surgeline Tuning to offer custom tunes for Access Port customers PDXImportRacer MazdaSpeed 3/6 - ECU Computer Tuning 54 09-07-2008 06:02 PM
Page generated in 0.35316 seconds with 27 queries
