  • 1 Post By SPEED6 KILLAH
 Old 11-14-2011, 06:32 PM   #1
RWDAddict's Avatar
Posts: 340   (View Stats)
RWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the worldRWDAddict is the leader of the world
Default Cobb Tuning and engine problems
Long story short my car was throwing a P0012 (overretard code) and was ticking bad from 1500-2500 so I took it to the dealer. They said i was down to 1.5qt and suspected bearing damage. So I had them fix the part that bled the oil out and do an oil change. After that the problem with over-retard went away and so did the 1500-2500 tick.
Now I have it back in my driveway with no codes and only an idle tick. Once I put stage 1 93+ cobb tune on the car the tick got a lot louder and after a short rev the car has some trouble finding a steady idle. Just a bit of idle surge. Knowing the risk I decided to take a 3rd gear pull and see what's going on. Attached are two maps.
1st map is just the car at idle with a rev or two
2nd map is two 3rd gear pulls back to back
Here is a video of the car at idle. Sorry for the fast movements but I wanted to cover the entire engine bay in a short time.
Mazda ticking video by RWDaddict - Photobucket
06 MazdaSpeed6 GT w/Nav. Mods so far: Cobb SRI, RMM, HPFP, ATP 3" catted DP, ETS CBE, Synchronic BOV, AP, CP-E TMIC, SURE TIP, HKS Twin Power, Poly trans mount, PTP fuel injector seals, PCV Fix
RWDAddict is offline   Reply With Quote
 Old 11-14-2011, 06:36 PM   #2
you need to update your AP, your logs are AFU
 Old 11-14-2011, 06:39 PM   #3
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
Mileage? First owner/history of the car?
 Old 11-14-2011, 07:13 PM   #4
RWDAddict's Avatar
? I just updated everything last night and reflashed it tonight. That's the latest everything
95,000 I am the 2nd owner and bought it at 46k
My Mods list in my sig is a wee bit outdated.
Mods list so far.
Mazdaspeed CAI, RMM, HPFP, 3" catted DP, Synchronic BOV, AP, CP-E TMIC, and SURE TIP
Last edited by RWDAddict; 11-14-2011 at 07:13 PM. Reason: MSF Database - Automerged Doublepost
 Old 11-14-2011, 10:48 PM   #5
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
SPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the world
A way you can find out if its a bearing is while you have the car running unplug the coil pack connector and notice the sound changing while you are do that if you does change in that clyinder it will be that clyinder bearing is bad.. I also have seen the cam buckets worn out cause a crazy ticking noise with that kind of miles also check you timing chain too..
SPEED6 KILLAH is offline   Reply With Quote
The Following User Says Thank You to SPEED6 KILLAH For This Useful Post:
rfinkle2 (11-15-2011)
 Old 11-15-2011, 04:50 AM   #6
you need to re-save your map in an updated version of ATR then, your logs are unreadable.
 Old 11-15-2011, 06:50 AM   #7
Besides the excellent advice above, I think you are logging in non-standard units.
Most of the 2nd log seems to show a gigantic vacuum leak somewhere.
A quick search netted me some info on the possibility that your egr valve could be stuck if you cannot find a vac leak.
 Old 11-15-2011, 07:33 AM   #8
amoosenamedhank's Avatar
Posts: 1,368   (View Stats)
Groans: 53
I think the title of this thread is extremely mis-leading. It very clearly makes it seem as if you're attributing your AP to your issue. If you had a unknown problem before the AP (which you admitted to), you should have never installed the AP for anything other than a monitoring device.
You know.... Moose stuff
The Following User Says Thank You to amoosenamedhank For This Useful Post:
 Old 11-15-2011, 08:09 AM   #9
If his EGR was stuck it will cause a misfire ..
 Old 11-15-2011, 08:49 PM   #10
RWDAddict's Avatar
I've had the AP for a while. I uninstalled it before I dropped it off at the dealers. I've been running an AP since about 75k. This is my first log. I had the beta version installed so that may have thrown off the logs. I do pull an EGR valve code and i'm sure it's stuck open. I didn't think that it would become a boost leak so it looks like that is jumping to a higher priority. After I fix the EGR I will run a new map. Hopefully my buddy and I can take her off and clean it out this weekend.
 Old 11-16-2011, 08:07 AM   #11
Mizzle's Avatar
Groans: 324
fyi: to fix EGR - run 3 gal E85. Fuck taking that thing off lol
rfinkle2 (11-16-2011)
 Old 11-16-2011, 01:53 PM   #12
RWDAddict's Avatar
Tempting but with my miles and the problems i've had lately i'd rather not risk it.
 Old 11-16-2011, 01:59 PM   #13
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
But you'll rip a 3rd gear pull?
All of the posts above are good starts, try one at a time and report back with some legible logs (not "maps")
 Old 11-17-2011, 07:41 AM   #14
RWDAddict's Avatar
Just pulled a P2187 code so i'm hoping that EGR valve is the source. I'll have it fixed this weekend and then i'll run another log. What parameters should I log? Last time I just selected all.
 Old 11-17-2011, 02:41 PM   #15
COCKSTRONG
Groans: 890
- Accel Pedal Position
- RPM
- Knock Retard
- Calculated Load
- Mass Airflow (g/s)
- Throttle Position
- Actual AFR
- DI Fuel Pressure
- Boost
- Boosted Air Temp
- Spark Advance
- Wastegate Duty Cycle
- Long Term Fuel Trim
- Closed Loop (2010's only)
- Intake Valve Advance
- Injector Pulse Width
- Injector Duty Cycle
rfinkle2 (11-17-2011)
COBB Tuning AccessPORT Update Features Boost Tuning, Faster Datalogging and LC/FFS Cobb Tuning MazdaSpeed 3/6 - ECU Computer Tuning 177 12-03-2011 12:53 PM
COBB Tuning AccessPORT Update Features Boost Tuning, Faster Datalogging and LC/FFS Cobb Tuning Cobb Tuning 1 08-31-2011 07:43 PM
COBB Tuning AccessPORT Update Features Boost Tuning, Faster Datalogging and LC/FFS Cobb Tuning 2010 MS3 - ECU Computer Tuning 0 08-31-2011 07:32 PM
The fix to all MS3/6 engine problems! Fobio Mazdaspeed3/6 General Discussion 8 05-13-2009 08:59 PM
Page generated in 0.36360 seconds with 27 queries
