| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
Groans: 433
(Thread Starter) | Not Ranked : 0 score This is on a windows 8 laptop. I've tried "compatibility" settings, etc. I'm getting ridiculously frustrated trying to connect to this motherfucking AIC. WHO STILL FUCKING USES SERIAL PORT TECHNOLOGY IN 2014.
| The Following User Says Thank You to Chimmike For This Useful Post: | MarineMazda (03-30-2014) |
Groans: 433
(Thread Starter) | Not Ranked : 0 score I think I figured it out: Windows 8 BLOWS GOAT NUTS. Managed to get R4 on an old netbook I have (WinXP), and connected right to the split second. Fuck windows 8. I'm fixin to buy Win7 to put on that new laptop.
![]() Join Date: Mar 2011 Location: Bethlehem, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,167
Groans: 70
| Not Ranked : 0 score 2 of our 3 products still do (I know, its stupid). If anyone needs a USB to Serial adapter, use the IOGear branded one. The biggest problems with these adapters are the drivers, IOGear seems to be the only one who has drivers all the OS versions.
__________________ 07' Speed6 Velocity Red Mica Go Faster: CorkSport SRI/TIP, SU Test Pipe, SU TMIC, Autotech Internals, ITV22's, Cobb AP Anti break stuff: Upper Rear Diff Brace, RMM Appearence: STRI DSD Boost Guage/Blockhead 60mm Guage Pod |
Groans: 433
(Thread Starter) | Not Ranked : 0 score I tried FTDI drivers, cuz most of these products are made by the same manufacturer and just rebadged. I had to search Amazon to find ones that actually look different, too.
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
| Not Ranked : 0 score Yeah. Windows 8 can suck it lol
__________________ www.tunedbynishan.com |
![]() Join Date: Aug 2011 Location: Barrie, ON
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 924
| Not Ranked : 0 score @gingermike I am having this same issue right now with Windows Vista. I tried using R4 on my MAC with XP in Parallels and I can't even open Customers on that without getting error msgs.... I thought it was MAC fail so i tried with my Work IBM which runs XP as well and get the same errors. I am with you who the FUCK uses Serial connectors anymore!!! I have an email in to SS right now.... Can you confirm this works with Windows 7? |
Groans: 433
(Thread Starter) | Not Ranked : 0 score I had to finally use an old netbook I have with XP on it to get it working. I know it's finicky regarding the serial/usb connectors that it works with. Would be optimal to find an old lappy with a serial port on it.
| Not Ranked : 0 score Most aftermarket standalones and ECUs are archaic this way. For our Megasquirt builds we use an adapter that I've tested to be compatible across all Windows versions.
| Not Ranked : 0 score Surprisingly I got it to work on Windows 8.... It must not like Vista.... |
![]() Join Date: Jun 2010 Location: Cedar Rapids, IA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score I work in industrial controls where there is still a lot of (picky) serial stuff around. I've been using a Tripp-Lite branded usb to serial adapter on my Win 7 laptop with good results. I'll see if I can find what the model number is. |
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
| Not Ranked : 0 score I tried two cables and three computers before I could connect. pita
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
| The Following User Says Thank You to mxlplx71 For This Useful Post: | Chimmike (04-30-2014) |
| Not Ranked : 0 score Yeah, the one I have is a Tripplite USA-19HS. So far it's worked with every oddball device I've tried to connect to. |
| dashhawk software interfering with other software? | builthatch | Mazdaspeed3/6 General Discussion | 3 | 07-09-2012 06:26 AM |
| Standback Tuning Software, Drivers, and Logging Software | www.cp-e.com | Custom Performance Engineering (cp-e.com) | 24 | 04-24-2011 11:49 AM |
| ap connecting | mouse6933 | MazdaSpeed 3/6 - ECU Computer Tuning | 10 | 02-18-2010 07:31 PM |
| AP not connecting | Tomas | Cobb ATR Support | 7 | 08-04-2009 10:31 AM |
