 Old 01-11-2010, 02:16 PM   #1
sleeper329's Avatar
Posts: 511   (View Stats)
sleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the worldsleeper329 is the leader of the world
Default CPE Standback install
I just got my Standback and went to wire it over the weekend.
Noticed that the wiring diagram in the instructions is backwards to my wiring harness. shows top row is pins 11-20, my harness is numbered 20-11. The colors are correct per pin # but not in the right location. Tried CPE all day with no answer.
I also noticed the instructions give me wire colors for pins 2,3,4. My harness has no wires on those pins.
Can someone with this unit please help.
^^USE THIS LINK AND COUPON CODE SURIOT AT CHECKOUT FOR A DISCOUNT!^^
sleeper329 is offline   Reply With Quote
 Old 01-11-2010, 02:21 PM   #2
socks's Avatar
Posts: 3,250   (View Stats)
Groans: 125
any particular reason you didnt want the plug and play harness? try calling around 5:30 today for some help.
 Old 01-11-2010, 02:29 PM   #3
sleeper329's Avatar
^^I do soldering and splicing at work daily... so i dont mind doing the install. Im trying to find a PNP harness if its cheap since these instructions dont match the harness.
Pics:
This shows the harness. the green dot over the green wire is labeled pin 20 on the harness. The bottom row is labeled 10,9,8,...1 top 20,19,18..11
This is their diagram. It shows the bottom row pinned out in the same order as mine but shows the top row in the opposite orde.
this is a pic of the bottom row. note 3 wires are missing that it says should be their in the instructions.
UPDATE:
I spoke to someone at CPE. They said to ignore the little numbers on the plastic connector that i was looking at. As long as the wire colors match the location on the color chart in the instructions i am good to go, which they do.
Now that i know for sure mine is right im installing this weekend.
Last edited by sleeper329; 01-11-2010 at 04:24 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-09-2010, 08:12 AM   #4
SneakyP86's Avatar
Posts: 1,162   (View Stats)
So how did the install go? was this on a Speed6 or 3?
 Old 04-03-2019, 07:50 AM   #5
Bfroth92's Avatar
Posts: 5   (View Stats)
Bfroth92 can only hope to improve
Default Come standback software
Could anyone tell me how I properly connect the cpe standback up and does anyone have the software still
Bfroth92 is offline   Reply With Quote
 Old 04-03-2019, 08:43 AM   #6
grobeforya's Avatar
grobeforya will become famous soon enough
Hi, toss your standback in the trash and go with Versatune or the Accessport
grobeforya is offline   Reply With Quote
The Following User Says Thank You to grobeforya For This Useful Post:
Db09ms3 (04-03-2019)
 Old 04-03-2019, 08:49 AM   #7
Posts: 2,235   (View Stats)
Since 2010 of this thread there is better options than a piggy back device.
Personally i would sell this to get something with proven results.
Take a look at Versatune if you don't want a Cobb.
There is some other tuning device too but the above are the one with more supports and infos for speeds.
Standback Install Problems bykeryder4life MazdaSpeed 3/6 - ECU Computer Tuning 25 12-26-2010 04:03 PM
Standback PNP install vbt101 MazdaSpeed 3/6 - ECU Computer Tuning 13 09-10-2009 09:51 PM
standback wire in install instructions socks MazdaSpeed 3/6 - ECU Computer Tuning 2 11-24-2008 04:07 PM
cp-e standback install troubles. PLEASE HELP! semperboost MazdaSpeed 3/6 - ECU Computer Tuning 18 06-09-2008 11:14 PM
Page generated in 0.27175 seconds with 25 queries
