 Old 07-06-2012, 09:14 PM   #1
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
Default DL & UL issues on AP
Ok, so I downloaded the Stage 2 SF+TIH+IC with upgraded CDFP map and put it in my docs on my harddrive.
Then I go to bring the map over to my AP and it's giving me tons of shit. I go into the AP Mgr to Import maps to library and it tells me to "convert these maps into the new format".... I just DL'd from COBB. It's a PTM file and never had issues before. This is the same OTS that is on my car as it stands and I just need to delete the EGR BS.
I've had ATR forever and it started to give me shit a couple months ago (not sure why).
Anyone have insight on this?
I've updated AP Mgr and Updater already.
WT...........F
Thanks guys
 Old 07-08-2012, 06:27 PM   #2
pzr2874's Avatar
Groans: 146
BUMP....
 Old 07-08-2012, 06:41 PM   #3
Boost_creep's Avatar
Posts: 829   (View Stats)
Do you have the "beta" box unchecked on each?
www.dizzytuning.com
www.facebook.com/dizzytuning
The Following User Says Thank You to Boost_creep For This Useful Post:
pzr2874 (07-09-2012)
 Old 07-08-2012, 08:50 PM   #4
fcbrandon's Avatar
Posts: 30   (View Stats)
fcbrandon is a glorious beacon of lightfcbrandon is a glorious beacon of lightfcbrandon is a glorious beacon of lightfcbrandon is a glorious beacon of lightfcbrandon is a glorious beacon of lightfcbrandon is a glorious beacon of light
Check the pins in the connector. A couple times, mine had a few pins that would get push in just a little bit and would cause some weird problems. I jus pulled them out with tweezers...don't expect a lot of support on Cobb with this, they told me to pull them out or send in to be repaired...for a fee
Sent from my HTC_Flyer_P512_NA using Tapatalk 2
[SIGPIC][/SIGPIC]'06 Mazdaspeed6
Fully bolted, stock turbo, stock manifold.
fcbrandon is offline   Reply With Quote
The Following User Says Thank You to fcbrandon For This Useful Post:
 Old 07-09-2012, 04:33 AM   #5
pzr2874's Avatar
Groans: 146
Not sure, unless it comes dl'd like that. I'll check when I get home. Thanks.
 Old 07-09-2012, 03:01 PM   #6
pzr2874's Avatar
Groans: 146
Ok, it was unchecked. But I try to save it to my library and it's giving me the same error (even after I checked the Beta box) and resaved the Map to my drive
 Old 07-09-2012, 03:50 PM   #7
pzr2874's Avatar
Groans: 146
Fuckin BS.... Apparently I had the older version of the AP Mgr... WTF. Thanks guys
DO Stg 1 kit issues Chimmike MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 32 01-16-2012 11:20 AM
issues with maf g/s dooderek MazdaSpeed 3/6 - Turbo Induction 4 11-15-2011 10:34 PM
AP issues Navy_Mech2 MazdaSpeed 3/6 - ECU Computer Tuning 10 11-03-2011 05:40 PM
Having some issues... 2010Speed3 Gen2 MS3 General Discussion 2 05-14-2011 03:47 AM
some issues with the car johnac08 MazdaSpeed 3/6 - ECU Computer Tuning 19 09-15-2009 09:42 AM
Page generated in 0.27831 seconds with 22 queries
