 Old 11-11-2011, 04:50 AM   #1
joey's Avatar
Posts: 63   (View Stats)
joey is a name known to alljoey is a name known to alljoey is a name known to alljoey is a name known to alljoey is a name known to alljoey is a name known to all
Default Downpipe lambda sensor
Hey guys!
So i ripped out that piece of shit uni-q and got Versatune. WOW!!! What a huge diff, and the amount of tuning I can do now is incredible!
Thx to "KMAC" showing me the light to VT!!
Anyhow...
I have x2 lambda foulers installed on top of each other, with the lambda sensor screwed in on top. I had a CEL without it and the exhaust guys installed it like that and the CEL went away.
This was before I had VT. So can I remove the x2 lambda foulers and screw in the lambda sensor directly? I have enabled the "I have a catless dp" under settings and flashed.
Thx in advance
Jo
PS: I have a catless 3" dp and a 2.5" freeflow zorst
Versatune :: FMIC :: 3" SRI :: 3" TIP :: HKS SSQv4 :: 3" Turboback :: Devil's Own WMI Stg2 kit :: Autotech HPFP :: JBR EGR delete :: JBR BSD & Baffle plate :: Racing Logic coilovers :: TRZ TMM :: AWR PMM :: Poly bushes all round :: SURE RMM :: SURE Shortcut&Counter weight :: SURE g/knob :: PG PCV fix :: Aeroforce dual Interceptor gauges :: Apexi TT :: HDI Stg2 Evo boost controller :: VIBE ICE
joey is offline   Reply With Quote
 Old 11-11-2011, 04:52 AM   #2
yes remove the anti foulers.
i really hope you only had it on the bottom O2 as well
joey (11-11-2011)
 Old 11-11-2011, 04:54 AM   #3
joey's Avatar
Great!
Yeah, i only have it on my lambda sensor, not the O2 sensor.
 Old 11-11-2011, 07:03 AM   #4
lambda = O2
laxplayermjd (11-11-2011)
 Old 11-12-2011, 01:21 AM   #5
joey's Avatar
Sorry for the confusion then. I thought i had a O2sensor close to the turbo and further down the downpipe was a lambda sensor.
 Old 11-12-2011, 09:49 AM   #6
brandonms3's Avatar
Posts: 110   (View Stats)
brandonms3 is just really nicebrandonms3 is just really nicebrandonms3 is just really nicebrandonms3 is just really nicebrandonms3 is just really nice
Not trying to steal the post, but im getting CEL with my catless DP, and my AFR is crazy high. I was told to get a new O2
brandonms3 is offline   Reply With Quote
 Old 11-13-2011, 10:45 PM   #7
joey's Avatar
No probs bro!
What software are you running? Have you done a log yet?
 Old 11-14-2011, 04:31 PM   #8
brandonms3's Avatar
yeah im running ots stage 2 91 with intake. but it was fine for like 2 weeks...it needs tuning adjustments but never had a cel. my AFR is like 29.3 at idle and at wot
 Old 11-14-2011, 05:59 PM   #9
Black Metal's Avatar
Posts: 699   (View Stats)
Black Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the world
Groans: 78
Your afr is not at 29.3 at wot or your engine would be scattered. You need a new o2
- 2006 Black Mica MS6 -
- GT3071R - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP -
- Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught -
- GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete -
12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30
12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20
- 2004 Silver Sunlight Metallic RX-8 -
- 6MT - Stock -
Black Metal is offline   Reply With Quote
The Following User Says Thank You to Black Metal For This Useful Post:
Tokay444 (11-14-2011)
 Old 11-14-2011, 10:45 PM   #10
joey's Avatar
Yeah! What he said! After getting new O2 sensor, do a MAF cal according to Abilor's guide.
 Old 11-16-2011, 11:17 AM   #11
brandonms3's Avatar
thanks....i was told to maybe put a spacer between the o2 and the DP??? would that be a good idea for the new o2?
 Old 11-16-2011, 10:56 PM   #12
joey's Avatar
No spacers needed.. Just replace with new O2 sensor and be careful not to damage the thread on the DP. If you do, you'll need to cut new thread with a tap. I think its and M18 1.5pitch tap, if need be.
Good luck bud! I personally won't run a Stage 2 map with only a intake. My .02
 Old 11-17-2011, 01:24 PM   #13
brandonms3's Avatar
Thanks for the help....my mods aren't only an intake...CPe dp, sure aeros, Autotech internals. Lol.
Fucking lambda. ARES28 MazdaSpeed 3/6 - ECU Computer Tuning 2 09-04-2011 06:46 PM
Quick O2 Sensor Downpipe Install Question >>> Alpha MazdaSpeed 6 - Engine, Transmission & Driveline 23 01-13-2011 08:45 AM
Downpipe Install....Stuck O2 Sensor mrjoshyman MazdaSpeed 3/6 - Turbo Induction 52 04-15-2009 07:45 PM
MotorTrend: Next Escalade to go Lambda Haltech Automotive News 0 09-08-2008 11:10 AM
Page generated in 0.32131 seconds with 23 queries
