 Old 02-07-2010, 11:38 AM   #1
super_pablo_'s Avatar
Posts: 1,648   (View Stats)
Default first attempt at datalogging and graphing
so I drove to phoenix yesterday, and in my attempts to making a data log, I did a couple runs except I didnt go WOT...
its kinda crazy considering I was going really deep into the pedal... I think it had to do with me not being used to such hard pulls (the AP gets u crazy gains!! )... but other than that... would these data logs mean anything if I wasnt WOT?...
its my first time making these, so if you dont have constructive comments, please dont bother.
.. my LTFTs were around 8 the first day... so im pretty happy with these (3 days after reflash)
the map i currently have is stage 2 +91 and MSCAI, with turboback... which fits perfectly with my mods...
you'll probably see why i didnt go wot... I was going 100 mph in a few seconds... and the road was considerably busy...
how can I attach a file? like a *.csv file?
 Old 02-07-2010, 11:44 AM   #2
heres the csv file
 Old 02-07-2010, 11:53 AM   #3
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
kiinda hard to tell what's going on, but it looks ok...
best way to analyze is get a solid "full gear" pull... 3rd or 4th is best. Start around 3k or whatever, and go WOT and log thru the whole gear.
 Old 02-07-2010, 11:56 AM   #4
yeah... i kinda knew i needed to do that... hahaha but i think the power is still a bit over my head... i went hard, and next thing i know... im going 100 in 5th gear... ooops!
I know these are not ideal... and too busy... just wanted to upload them since I had them...
thanks for the input
 Old 02-07-2010, 05:17 PM   #5
heres a new run in 3rd gear
sorry ... its still busy
... i only got knock at 1 datapoint (.3)
... LTFT was hovering around .6 and up to 3 when i let go off the gas
most everything else is here...
 Old 02-07-2010, 07:57 PM   #6
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
You're better off posting the csv file. This graphs nearly give me a seizure.
The Following User Says Thank You to Frequentflyer For This Useful Post:
kgb (02-08-2010)
 Old 02-08-2010, 02:18 PM   #7
fjames's Avatar
Posts: 1,058   (View Stats)
^ What he said.
 Old 02-12-2010, 07:53 AM   #8
ill upload it later tonite when i get a chance.. sorry...
ill try another 3rd gear run and see if I get anything better or worse.. ill be calibrating my maf cause my ltfts are still around 5 at idle after a few hundred miles after reflash...
 Old 02-14-2010, 10:17 PM   #9
heres the csv
The Following User Says Thank You to super_pablo_ For This Useful Post:
Frequentflyer (02-15-2010)
 Old 02-15-2010, 08:02 PM   #10
My tips for you are to try to do a log from about 2500-3000 RPM to 6500 in 3rd or 4th gear. Your AFR's look decent, but you're a little rich. Safe, but a little rich. You could safely bump them up to 11.8-12.0:1.
Datalogging aftermarket wideband and egt johnac08 MazdaSpeed 3/6 - ECU Computer Tuning 5 08-17-2009 09:55 AM
Correctly Datalogging on the dashhawk SLOMS3 MazdaSpeed 3/6 - ECU Computer Tuning 3 07-10-2009 04:42 PM
Datalogging with ATR stormin84
Cobb ATR Support
2 04-26-2009 02:29 PM
Shall I build a Graphing tool? martin_nj
Cobb Access Port/Maps
29 04-02-2009 11:44 AM
MS3 & MS6 AP datalogging is released! SharkDiver MazdaSpeed 3/6 - ECU Computer Tuning 0 12-03-2008 05:22 PM
Page generated in 0.31552 seconds with 24 queries
