  • 1 Post By Vansquish
 Old 11-16-2019, 04:28 PM   #18
Graveshaker's Avatar
Posts: 55   (View Stats)
Graveshaker is a splendid one to beholdGraveshaker is a splendid one to beholdGraveshaker is a splendid one to beholdGraveshaker is a splendid one to beholdGraveshaker is a splendid one to beholdGraveshaker is a splendid one to beholdGraveshaker is a splendid one to behold
Before installing the new HPFP internals, you might want to pull the pump and check what is in it now. It's quite possible that the previous owner installed Autotech or CS internals already. If you open the box on the internals you ordered, you won't be able to return them.
I'm banking on it being returned to stock because of the obvious returned to stock dp evidence and everything else being returned to stock. Especially the oil leak directly beneath hpfp housing. I purchased everything used off a well known Mazdaspeed parts breaker on Facebook.
I'm also thinking the map that's upload could have been made while those hoses was crossed. So a tune is number one priority before something goes boom. I don't think anything is mechanically wrong at this point. When I did the valve cover gasket, the inside was really clean and the chain was tight. No slap marks on the inside cover. Spark plugs looked greet with uniform burn and gap on all four. Compression tested great too.
Bone stock
Graveshaker is offline   Reply With Quote
The Following User Says Thank You to Graveshaker For This Useful Post:
MSMS3 (11-26-2019)
« Cobb Tuning FMIC | - »
other cars that share our fuel system (specifically fuel rail) TWOptSL0W MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1 05-12-2012 09:13 AM
Maintenance on a 1973 I.H. Scout, Dangerous Car Has Exhaust Leak, Fuel Injector Cleaner, Ethanol and Fuel Grade, Is The Haltech Automotive News 0 07-10-2008 11:10 AM
How Much Fuel Is Left When Fuel Indicator Light Comes On, Hard Starting Dodge Caravan, Oil Pan Plug Fell Out, Mixing Coo Haltech Automotive News 0 07-10-2008 11:10 AM
Page generated in 0.41773 seconds with 25 queries
