 Old 04-11-2019, 01:35 PM   #1
06Speed6GT's Avatar
Posts: 2   (View Stats)
06Speed6GT is an unknown quantity at this point
Default Help with KR and rich AFR
I have a tune from stratified and I am running very rich with up to 5.25 KR. My mods are high pressure fuel pump, corksport TMIC, 3 inch intake, ATP catless downpipe, and cobb BPV. Please help with some possible solutions to my knock and rich AFR. I am going to do one step colder plugs this upcoming weekend. Thanks!
https://datazap.me/u/connor-schlag/l...og=0&data=4-22
this is another log I took the next day and the Knock is a little better, still running rich on WOT.
06Speed6GT is offline   Reply With Quote
 Old 04-11-2019, 02:42 PM   #2
Police - Grammarhead
Vansquish's Avatar
So...uh...if you're having significant consistent knock at WOT, you should probably stop going WOT.
Basically, when the knock sensor reports knock to the ECU, the car dumps extra fuel into the mixture to try and cool the cylinders and reduce or eliminate the knock that is being sensed. Accordingly, datalogs of a WOT run where you have consistent knock throughout the pull will show extra fuel being dumped into the mixture and high/rich AFRs.
You might want to try putting a couple of gallons of E85 in the tank to see if you've just got a tank of bad gas.
 Old 04-11-2019, 03:00 PM   #3
06Speed6GT's Avatar
Okay, I will try putting a few gallons of E in the car. Do i need a tune for 2 gallons? Or can i dump it in with the rest of 91 and run it on my current stratified tune? Thanks in advance.
 Old 04-11-2019, 03:13 PM   #4
Vansquish's Avatar
You should be fine with a couple of gallons.
 Old 04-16-2019, 08:15 AM   #5
Vansquish's Avatar
Any updates?
86AmishMs3 (04-18-2019)
 Old 04-18-2019, 01:23 PM   #6
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Have you talked to stratified? What type of fuel are you running. Timing doesn't look aggressive nor does boost. Boost temps weren't too bad.
Like others have said try a couple gallons of e85 and see if that eliminates the knock.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
Rich AFR's gotovato Gen2 MS3 General Discussion 21 07-31-2018 01:56 PM
Rich idle, Rich on throttle tip in MSP6 MazdaSpeed 6 - Engine, Transmission & Driveline 39 02-17-2013 06:49 PM
Rich AFR help boyer MazdaSpeed 3/6 - ECU Computer Tuning 1 05-19-2010 11:19 AM
What is to rich? Matrix311 MazdaSpeed 3/6 - ECU Computer Tuning 13 07-31-2009 11:41 PM
Page generated in 0.26648 seconds with 22 queries
