 Old 06-26-2010, 01:48 PM   #1
Qtip's Avatar
Posts: 410   (View Stats)
Qtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond repute
Default How do I tune out this knock?
I updated my timing table to the Cobb Stage 1 91 Octane OTS map and am getting some knock in 3rd gear around 3500rpm. How can I tune this out using ATR?
Also, I noticed that the timing number in the map don't seem to line up with what the engine is doing or at least I can't figure out how it's doing its look up. So I have no idea where to start.
Weirdly enough 4th gear doesn't knock. I did two runs in 3rd and both had the same exact behavior.
Help!
Mods include:
1 step colder plugs, 93 octane gas, K&N Drop-In filter, Airbox modified with hole, Cobb Inlet pipe
Qtip is offline   Reply With Quote
what is the knock???? Ftaz1 MazdaSpeed 3/6 - Suspension & Brakes 17 04-29-2010 02:00 PM
Can I use ATR to tune out this knock? Speedn3
Cobb ATR Support
12 05-25-2009 07:09 PM
Persistent Knock Retard on stock tune Ploppity Drown MazdaSpeed 3/6 - ECU Computer Tuning 26 04-23-2009 01:37 PM
Tune day. knock retard after 5000rpm johnac08 MazdaSpeed 3/6 - ECU Computer Tuning 11 12-23-2008 10:57 AM
Page generated in 0.22541 seconds with 21 queries
