 Old 12-04-2010, 09:04 PM   #1
speed23's Avatar
Posts: 1,480   (View Stats)
Thanks for helping us get started Christian. I dont mean to push our luck, but any chance that the ecu could do a final check of the boost compensation tables to determine boost, so that we could limit boost in 1st and 2nd for the ms3 guys?
 Old 12-04-2010, 09:58 PM   #2
Christian.'s Avatar
Posts: 274   (View Stats)
Christian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the world
I have not checked if the existing boost comp. tables per gear are still functional.
It seems that the first and second steps should be reversed.
It makes sense that the ECU starts by command a certain WG duty cycle since it controls that directly.
Then, it uses the load dynamics table to achieve the target in the boost targets table.
I debated that, but I wanted to explain things in an easy to understand manner so I thought stating boost before WGDC was best. It would not matter if WGDC or Boost was first...this system is pretty damn fast with boost control and it operates in a closed-loop manner with MAP delta feedback.
Christian.
Christian. is offline   Reply With Quote
The Following User Says Thank You to Christian. For This Useful Post:
rfinkle2 (03-28-2011)
 Old 12-05-2010, 12:52 AM   #3
Christian.
If you've played around with this, how much do initial conditions matter? In other words if I start with 100% in the WGDC table, how much does the boost overshoot for example?
Also, say there is a MAP sensor failure, does the ECU revert to using the WGDC table only?
djuosnteisn (12-05-2010), FreeFlyFreak (12-06-2010)
 Old 12-05-2010, 09:47 AM   #4
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Originally Posted by bmorrisj View Post
how does this boost based switch affect ignition timing? since the ecu doesn't use full set timing if not necessary with achieved load. (or is that even correct?)
With constant boost, you'll have varying load. For instance 15psi in 100 degree weather would result in much lower load (air flow) than in 30 degree weather (and 100 degree weather would be quite a bit slower). The ign advance will be calculated as normally for that given rpm and load point.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
dougefresh_ (05-03-2011), jwilkins88 (12-05-2010), m4tic (12-05-2010), Micha (01-04-2015), rfinkle2 (03-19-2011)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/initial-details-into-how-boost-based-tuning-66400/
Does Boost Dynamics (Boost Based Tuning) do anything? - Page 2 - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Pingback 04-12-2011 06:14 PM
Volkswagen releases initial pics, details on all-new Caddy Haltech Automotive News 0 07-22-2010 04:50 PM
Initial Impressions of Grimmspeed Boost Solenoid tbot MazdaSpeed 3/6 - ECU Computer Tuning 44 04-14-2010 04:45 PM
Please educate me on a few details of how the turbo on this car works... Smokehouse MazdaSpeed 3 - Engine, Transmission & Driveline 28 01-02-2009 04:05 PM
Page generated in 0.29324 seconds with 25 queries
