 Old 12-08-2010, 12:16 AM   #41
aspiring turbo guru
08_ms3_gt's Avatar
Posts: 1,040   (View Stats)
08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world08_ms3_gt is the leader of the world
Originally Posted by FORZDA 1 View Post
Sounds like your MAF cal is off just a bit.
the 1.06 map hits the command AFR at WOT. i need to calibrate the MAF for WOT without the load cap? i must have missed that part.
01.5 S4 6MT Stage 3
02 S6 6MT swap
93 S4 project
[sold - 90 Miata - summer/project car, turbo w/ goodies, DIYPNP, springs/struts, etc.]
[sold - 08 MS3 GT - intake/downpipe/tuning/fuel pump/TMIC/springs/struts/etc.]
08_ms3_gt is offline   Reply With Quote
The Following User Says Thank You to 08_ms3_gt For This Useful Post:
djuosnteisn (12-08-2010)
 Old 12-08-2010, 08:35 AM   #42
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Originally Posted by 08_ms3_gt View Post
i've been experiencing this. first cold weather with fuel pump and downpipe --> running WOT gave me AFR's around 12.2 when commanded AFR is 11.5.
i may work on fracking around with it (Dano, you've done this?), but for now i flashed a 1.06 map in the hope that it'll keep my AFR's healthy.
Forzda's right and your MAF could just be off, just use your actual AFRs to re-calibrate your maf in the voltage ranges you are lean. get logs with Maf vt and AFR ...its fairly easy to change the % of your MAF UP to meet your fueling targets. you prob don't have to change your entire MAF curve just the upper ranges and smooth out the transitions.
now if you were logging CDFP and you were dropping down to 1200PSI then you have pump issues otherwise its MAF.
08_ms3_gt (12-08-2010), rfinkle2 (03-28-2011)
 Old 12-08-2010, 09:13 AM   #43
aspiring turbo guru
08_ms3_gt's Avatar
thanks for the insight. the 1.06 map gives me the target AFR, but i would assume i could adjust my MAF table with a 1.07 map to hit my AFR's, run w/o load cap, and get more power...? i'll have to try this sometime soon, not yet b/c i'm getting totally hammered @ work :\
funny story with the CDFP - just replaced mine b/c the old one was dropping below 1000 psi (?!!?!) at WOT. warranty replacement on a PTP pump. new one's holding 1600+ psi at WOT. the funny part is that i was hitting target AFR's w/ the old pump for some reason. i'm guessing i was down on power, though, if the ECU was cutting throttle due to the pressure drop. now, with the new pump, my pressure is fine but my AFR's are lean. can anyone explain that? weird shit.
01.5 S4 6MT Stage 3
02 S6 6MT swap
93 S4 project
 Old 12-08-2010, 09:17 AM   #44
Trail of Fail
Dano's Avatar
just copy/paste the good MAF cal into your other map...5 minutes and you are gold.
 Old 12-08-2010, 09:27 AM   #45
aspiring turbo guru
08_ms3_gt's Avatar
really? i didn't even do a MAF cal.
both maps are OTS Stage 2 SF w/ TMIC. just 1.06 versus 1.07. i have a Cobb STS, downpipe, and ETS TMIC (and other stuff).
i figured the MAF tables were the same for both. maybe not?
the only other potential consideration is that i didn't give either map a full 100 miles to break in - i rolled on it WOT at about 50 miles for each map, and the results were 11.4 AFR's (target) for the 1.06 and 12.2 for 1.07. i tried putting a few more miles on 1.07 and cycling the key a few times (results did not change) before switching to 1.06 to see if there was a difference.
i could do a MAF cal for 1.07, assuming the tables are identical. i would have to check them to see, obviously. i have been avoiding tuning bc RealGib told me his blown engine story (we talked @ some g2g's) which kinda freaked me out. altho his was from FFS iirc.
01.5 S4 6MT Stage 3
02 S6 6MT swap
93 S4 project
 Old 12-08-2010, 09:57 AM   #46
Trail of Fail
Dano's Avatar
hum..you could just compare the two by pasting the 107 map MAF A or B into the 106 MAF B table and switch back and forth looking at the graph to see if there is any difference. If there is then you know Cobb made a change in the MAF and you should start with the one that is closest.
At any rate, if you haven't done a real MAF calibration, that is the place to start with any tuning.
PM me if you have any more ??
08_ms3_gt (12-08-2010), Christian. (12-08-2010), djuosnteisn (12-08-2010), rfinkle2 (03-28-2011)
 Old 12-08-2010, 11:25 AM   #47
Christian.'s Avatar
Posts: 274   (View Stats)
Christian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the worldChristian. is the leader of the world
Please allow or use the AutoUpdater function to get the newly updated Ign Table - Max A-B tables.
Christian.
Christian. is offline   Reply With Quote
The Following 5 Users Say Thank You to Christian. For This Useful Post:
djuosnteisn (12-08-2010), evidence (12-08-2010), m4tic (12-08-2010), rfinkle2 (03-28-2011), triplejumper18 (12-08-2010)
 Old 12-08-2010, 11:26 AM   #48
Trail of Fail
Dano's Avatar
Nice!!
 Old 12-08-2010, 11:37 AM   #49
triplejumper18's Avatar
Posts: 2,569   (View Stats)
Groans: 196
Thanks Christian!
 Old 12-08-2010, 11:38 AM   #50
m4tic's Avatar
Posts: 4,928   (View Stats)
we are getting somewhere!
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 12-08-2010, 11:39 AM   #51
Trail of Fail
Dano's Avatar
The new updater is awesome! 1 minute and I now have the new IGN tbls!
 Old 12-08-2010, 12:24 PM   #52
m4tic's Avatar
now i can use that 24h biting my nails for something else
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 12-08-2010, 12:35 PM   #53
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
What version is the new version?
I ran the update last night around 12am and I'm now on 1.8.6.0 build 854
I don't see any Ignition tables called Max anything...? I see 9 Ignition tables.. am I looking in the wrong spot?
Edit - Just tried the updater again and it says no updates...
 Old 12-08-2010, 01:08 PM   #54
Trail of Fail
Dano's Avatar
you updater = Fail
current version: 1.8.6.0-867
 Old 12-08-2010, 01:24 PM   #55
hnda etr's Avatar
Groans: 90
you updater = Fail
WTF! FML!
Christian, another bug to fix please!
EDIT - I unchecked the "Beta Software" check box and now it's updating.... Not sure if that's the intended behavior...
 Old 12-08-2010, 01:26 PM   #56
Trail of Fail
Dano's Avatar
try closeing ATR and try again?
 Old 12-08-2010, 01:30 PM   #57
m4tic's Avatar
well at least you dont have to unmarry or wait another 24
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 12-08-2010, 01:36 PM   #58
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
WTF! FML!
haha it seems that they have their checkboxes backwards, if you also refer to how you turn off cel codes.
 Old 12-08-2010, 01:40 PM   #59
Christian.'s Avatar
WTF! FML!
That is the intended behavior. ATR software is different than AP firmware. The firmware is still in Beta. The ATR software automatically updates or you can roll it back...no Beta option there.
No, if the MIL is checked, then the ECU looks for that code, if unchecked, it does not.
you updater = Fail
No, things are working as expected. ATR software and AP firmware are two different things that are updated separately.
You are welcome to review our release notes here.
Christian.
The Following 4 Users Say Thank You to Christian. For This Useful Post:
djuosnteisn (12-08-2010), hnda etr (12-08-2010), jax ms3gt (01-06-2011), rfinkle2 (03-28-2011)
 Old 12-08-2010, 01:44 PM   #60
Trail of Fail
Dano's Avatar
Christian FWIW,
as far as your updater programming. If you select to allow for beta updates the program should check for general + beta and not exclude general when you have beta checked.
ya know a cumulative result not an either or.
 Old 12-08-2010, 01:45 PM   #61
hnda etr's Avatar
Groans: 90
Originally Posted by Christian. View Post
That is the intended behavior. This was made as a general release, not Beta.
lol... ok thanks Christian!
I assumed that since ATR for the Mazdaspeeds is still listed as "Beta" that all releases would be too lol...
 Old 12-08-2010, 02:02 PM   #62
Christian.'s Avatar
Christian FWIW,
Understood, but we don't want it to work that way so we can toggle between the two and help users in a bind.
The Following User Says Thank You to Christian. For This Useful Post:
 Old 12-08-2010, 02:08 PM   #63
Trail of Fail
Dano's Avatar
very well...I see this causing confusion though...leave beta checked and users will not recieve general auto updates...Hnda is a perfect example.
perhaps have the software, after checking for a beta update, auto toggle back so it doesn't check for beta until the user selects it again?
 Old 12-08-2010, 02:36 PM   #64
Christian.'s Avatar
Beta AP firmware updates usually contain the general updates + Beta stuff.
Some of the ATR tables are in Beta, but the software has been stable for some time. Although, we may still call it Beta just to absolve us of any unknown mistake that we may make. This is a pretty common practice now. I would make sure that the Beta Software box is unchecked unless you are instructed by one of our technical support team members to check this box. This function is only to be used for advanced technical support needs. We do not use this box for anything that is to be released to the general public. I believe the default installation has this box unchecked and it should be left that way unless instructed by a technical support member otherwise.
We push out Beta firmware stuff more frequently because we may update a general aspect of the firmware that is applicable to all models and we will need immediate feedback. We do not do this with ATR since the platform is stable.
I apologize for the confusion and hopefully this explanation helps. Please let me know if you guys have any questions or concerns.
Christian.
The Following 6 Users Say Thank You to Christian. For This Useful Post:
Dano (12-08-2010), djuosnteisn (12-08-2010), DSIT995 (12-08-2010), evidence (12-08-2010), FORZDA 1 (12-08-2010), hnda etr (12-08-2010)
 Old 12-08-2010, 04:59 PM   #65
fjames's Avatar
Posts: 1,058   (View Stats)
I've tried half a dozen times in the last several hours and always the same result. Am I missing a step? It's now 19:00.
 Old 12-08-2010, 05:21 PM   #66
Christian.'s Avatar
I've reported this to our engineering team...I've never seen this before. I doubt that we will be able to look into this tonight. Until then, I've hosted the latest MS Tuning Guide and Tuning Guide Worksheets here.
Christian.
The Following 2 Users Say Thank You to Christian. For This Useful Post:
fjames (12-08-2010), FreeFlyFreak (12-08-2010)
 Old 12-08-2010, 06:20 PM   #67
fjames's Avatar
That thread is showing last update on 12/02, and the help file I have I downloaded 12/03 and it includes the new stuff, so I'm assuming that's up to date? I dropped it in the ATR folder so I could access it from ATR - i.e. I don't know how it checks for updates to the help file, but it seems it may be wrong in this case.
 Old 12-08-2010, 06:23 PM   #68
evidence's Avatar
Posts: 1,033   (View Stats)
I did the same and also received the update. The new version I got matched the 1.10 I had tossed in, but didnt confirm file sizes or anything. It's likely just a simple date check though and the downloaded one had the date of your download..
Edit: It actually appears to simply look for new unseen items from the server.. it ignores the local files completely in my tests.
Some things.
 Old 12-08-2010, 08:20 PM   #69
fjames's Avatar
That makes sense, it would be the easiest for them.
I got it to work - it was my AV (Avira.) Wasted time trying to find the problem, but the newest bad file I found was from 12/04. If it matters to anyone, disabling the web guard didn't help, had to disable all of it, then the update zipped right in.
 Old 12-11-2010, 03:44 PM   #70
triple_threat's Avatar
Posts: 98   (View Stats)
triple_threat is a splendid one to beholdtriple_threat is a splendid one to beholdtriple_threat is a splendid one to beholdtriple_threat is a splendid one to beholdtriple_threat is a splendid one to beholdtriple_threat is a splendid one to behold
I Love the boost toggle feature! I finally got my boost to hold, with absolutely no spikes! I do have a question about calculated load though, is it normal for load to slowly taper off? I hit a high point and then it slowy drops even though boost holds steady? afr's and fuel pressure all look great with 0 knock. Finally getting my tune dialed in just wanted to see if this is normal cuz i seen some peoples load holds steady. maybe everyones car is different.
2009 Mazdaspeed 3
Cobb AP (ATR Tuned by me), HKS Intake, CX Racing FMIC, Cobb TIP, Turbo XS Hybrid BPV, Turbo XS Testpipe, Grimmspeed EBCS (3 port mode), SURE TIG, PnP intake Mani+vtcs delete, coolant bypass, TRZ RMM, JBARONE Stage 2 Short shift kit, Denso itv-22's,MSD Dashhawk, HKS turbo timer, ResonatorDelete, 18x8 Motegi MR116+ Toyo proxes 235/40/18, Prosport Boost Gauge, Blacked out side markers and badges, Tint
triple_threat is offline   Reply With Quote
 Old 12-11-2010, 03:51 PM   #71
manelscout4life's Avatar
Posts: 1,781   (View Stats)
Groans: 661
thats how mine was looking too I'm pretty sure its fine
http://www.mazdaspeedforum.org/forum/foru...-fmic-bt-e.csv
manelscout4life is offline   Reply With Quote
The Following User Says Thank You to manelscout4life For This Useful Post:
triple_threat (12-11-2010)
 Old 12-11-2010, 06:00 PM   #72
Trail of Fail
Dano's Avatar
Load will drop as RPMs increase after peak load which is completely expected.
You can roughly think of load as torque and a load curve will closely follow a torque curve.
Christian. (12-13-2010), djuosnteisn (12-12-2010), manelscout4life (12-12-2010), triple_threat (12-11-2010)
 Old 12-11-2010, 07:37 PM   #73
ok thank you, that clears things up!
2009 Mazdaspeed 3
 Old 12-12-2010, 03:44 PM   #74
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
I cant open the psi tuning, maps that you posted Christian.
I get a message about "invalid Base Map"
I am guessing it is related to the fact that you cannot open the map i sent you either.
I have a 2008 MS3 Cali.
Suspension:
 Old 12-13-2010, 09:29 AM   #75
Christian.'s Avatar
Have you uninstalled your AP from your vehicle yet? The AP should not recognize a CA model vehicle, they models should be consolidated.
Look at calculated load as torque...some hardware combinations perform better (breath) than others.
Christian.
rfinkle2 (03-28-2011), triple_threat (12-13-2010)
 Old 12-13-2010, 12:10 PM   #76
The Kamikaze King!
Groans: 754
Christian.
I am saying I cant open the map you posted in ATR, I havent even got to the point of trying to put anything on the AP or the car yet.
I wanted to look at the 08 MS3 map you posted, but my newest version ATR wont open it, I get:
"Unable to load map file.
Invalid Base map file. Please verify vehicle and vendor of map file.
(5:384)"
Suspension:
 Old 12-13-2010, 12:28 PM   #77
Ziggo's Avatar
Posts: 3,843   (View Stats)
I had trouble with that once when trying to open a map I downloaded from cobb's site. I redownloaded it and it worked fine.
Ask Me About My:
FreeFlyFreak (12-13-2010)
 Old 12-13-2010, 01:00 PM   #78
The Kamikaze King!
Groans: 754
Actually I found the problem, I had downloaded the MS6 map by mistake because the order listed in the post was not the same as the order of the attachments.
I just edited Christians OP to have the order they are listed in his post be the same as the order they are attached, that should avoid anyone else having the same confusion.
Suspension:
 Old 12-13-2010, 02:27 PM   #79
Christian.'s Avatar
Gotcha, I apologize about that. I know that I had the titles correct, but I did not look at the order. Thanks for addressing that.
Christian.
 Old 12-14-2010, 05:07 PM   #80
Jarods7920's Avatar
Posts: 1,415   (View Stats)
Christian,
I tried that map you had posted and the boost based tables do not seem to match what you have in your first post screen shot. This is what i show, am i missing something?
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/initial-details-into-how-boost-based-tuning-66400/
Does Boost Dynamics (Boost Based Tuning) do anything? - Page 2 - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum This thread Pingback 04-12-2011 06:14 PM
Volkswagen releases initial pics, details on all-new Caddy Haltech Automotive News 0 07-22-2010 04:50 PM
Initial Impressions of Grimmspeed Boost Solenoid tbot MazdaSpeed 3/6 - ECU Computer Tuning 44 04-14-2010 04:45 PM
Please educate me on a few details of how the turbo on this car works... Smokehouse MazdaSpeed 3 - Engine, Transmission & Driveline 28 01-02-2009 04:05 PM
Page generated in 0.59996 seconds with 34 queries
