| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: May 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
(Thread Starter) | Not Ranked : 0 score Use Boost Based Dynamics (Boost Control) When this box is checked, the ECU will function using several Boost Tables and the MAP sensor readings in order to control boost. This should provide what you are calling "PSI tuning" vs. the “Load Tuning” the factory implements. In other words, the ECU will take the result of the Boost Target table and compare it against the actual Boost measured by the MAP sensor. If Actual Boost is greater than target boost, it will reduce the WGDC (attempt to lower actual boost). The opposite is true if Actual Boost is less than Target; the ECU will then use the authority given to it within the Boost Dynamics table to increase WGDC. The ECU will use the reported “Throttle Position” in the datalogs for looking up the Boost Target values. Since the ECU reports ~74 for WOT, the ECU appears to not be using the 4 final rows from 75-100. This loss in resolution should not hinder your ability to properly calibrate Boost Targets. Without including the last four rows, this ECU still has 15 x-axis RPM break points and 13 y-axis TPS break points for the psi-based Boost Targets table. This is more than sufficient considering that the GTR has a Boost Targets table that is 8x8 in resolution. Depending on how your boost control system is mechanically set up, you may need to modify other tables within the Boost Tables folder in order to allow for appropriate boost control. We will go over this in greater detail below. The following screen shots and logic descriptions explain how the closed-loop boost control system functions using this custom coding. ![]() 1st - The ECM logic will “look-up” what the Boost Targets have been calibrated to based on RPM and Throttle Position look-up values; achieving these Boost Targets is the ECM's primary goal for closed-loop boost control system. ![]() 2nd - The ECM logic will then “look-up” what the WG Duty Cycles have been calibrated to based on RPM and Throttle Position look-up values; the ECU will then drive the boost control solenoid in order to achieve the desired Boost Targets. 3rd - At very fast rates, the ECM take readings from the MAP sensor and measures the Delta Δ (or difference between) the desired Boost Targets and the actual measured Boost for the measured RPM and Throttle Position. ![]() 4th - The ECM logic will then “look-up” compensatory Boost Dynamics values that will modify the WGDC in order to achieve the Boost Targets for the corresponding RPM and Throttle Position. The ECU logic will then cycle over again in this “closed-loop” operation. The values in the Boost Dynamics table give the ECU the authority to modify the WGDC during over boost and under boost conditions. The values on the right hand side of this table give the ECU the authority to reduce WGDC during over boost conditions. The values on the left hand side of this table give the ECU the authority to increase the WGDC during under boost conditions. If you are getting significant boost oscillations, then you may need to fine tune the values in this table or you may need to recalibrate the WG Duty Cycles table. Generally speaking, it is easier to start with less WGDC than you need in order see how the turbo responds. One easy way to help figure out proper WGDC values is to set the WG Duty Cycles tables to 25% and then run the car at WOT with the desired Boost Targets set. The ECU will then try to do everything it can within its authority (Boost Dynamics table settings) to figure out the proper WGDC values to run in order to hit the Boost Targets. Simply observe those values and begin to enter them into your WG Duty Cycles table until you see the ECU is controlling boost very consistently. I've also attached a base calibration that you are welcome to start with. 2007-2008 MS3 = Stage1+SF 93 v107 FMIC BT vF.ptm 2009 MS3 = Stage1+SF 93 v107 FMIC BT vA.ptm 2006-2007 MS6 = Stage1+SF 93 v105 BT vA.ptm XOXO, Christian. Last edited by Christian.; 12-28-2010 at 02:00 PM. Reason: Reorder posted maps in same order as attached maps |
| The Following 41 Users Say Thank You to Christian. For This Useful Post: | -cj- (12-04-2010), aaronc7 (12-04-2010), acidbbg (12-06-2010), Addikted To Boost (12-04-2010), AJ713 (12-06-2010), Arnie1229 (01-23-2015), Atticaz (12-29-2015), BrianB6 (12-06-2010), Cataphract_40 (12-04-2010), cld12pk2go (12-05-2010), Dano (12-07-2010), djuosnteisn (12-04-2010), dougefresh_ (12-08-2010), DSIT995 (12-06-2010), evidence (12-05-2010), Familyguy427 (01-10-2013), Fobio (12-08-2010), FORZDA 1 (12-05-2010), FreeFlyFreak (12-12-2010), Haltech (12-05-2010), JacksonMS30 (12-15-2010), jax ms3gt (01-06-2011), JmkC (12-04-2010), jwilkins88 (12-05-2010), KeysMS3 (12-05-2010), kgb (12-06-2010), Lama (12-08-2010), Lex (12-04-2010), m4tic (12-04-2010), manelscout4life (12-04-2010), Micha (01-04-2015), R.MS3 (12-04-2010), rfinkle2 (03-28-2011), Sacrilicious (12-05-2010), sellers (12-05-2010), skeeter149 (12-04-2010), speed23 (12-04-2010), superskaterxes (12-05-2010), Twofer (03-06-2013), xfeejayx (04-20-2011), XLT_66 (01-25-2011) |
![]() Join Date: Oct 2008 Location: Las Vegas, NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,548
Groans: 30
![]() on a more serious note, I just wanted to make sure that this stuff is correct for our car's ATR and not just the GT-R. As always...thanks for the info Christian, it will come in very handy
__________________ 2008 GT MS3 - 307 WHP/338 WTQ ATP GTX2867R - HTP 3" Intake - Cobb FMIC pipes + Treadstone TR8L - Cobb Catted Turboback - Cobb XLE BPV - Denso ITV22 plugs - Corksport Injector Seals - KMD HPFP - Cobb AP - CP-E RMM - Southbend Stage 3 Enduro Clutch/Flywheel - Bilstein B8s + Swift Springs - SPC Rear Camber Arms - Hotchkis RSB - MD OCC Kit - Enkei RPF1 - Bridgestone Potenza S-04 235/40/18 1995 Miata Dunlop Direzza Star Specs 185/60/14 - Koyo 37mm radiator - NAPA blank rotors - StopTech Street Performance pads - 949 Racing XIDA CS Coilovers - IL Motorsports suspension bushings - Racing Beat FSB - 949 Endlinks | |
![]() Join Date: Nov 2008 Location: Edmonton, Alberta
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,648
| Not Ranked : 0 score Thanks for helping us get started Christian. I dont mean to push our luck, but any chance that the ecu could do a final check of the boost compensation tables to determine boost, so that we could limit boost in 1st and 2nd for the ms3 guys? |
| Not Ranked : 0 score It seems that the first and second steps should be reversed. It makes sense that the ECU starts by command a certain WG duty cycle since it controls that directly. Then, it uses the load dynamics table to achieve the target in the boost targets table. Last edited by Lex; 12-04-2010 at 09:16 PM. Reason: MSF Database - Automerged Doublepost |
Christian. | ||
| The Following User Says Thank You to Christian. For This Useful Post: | rfinkle2 (03-28-2011) |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
| Not Ranked : 0 score how does this boost based switch affect ignition timing? since the ecu doesn't use full set timing if not necessary with achieved load. (or is that even correct?)
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
Also, say there is a MAP sensor failure, does the ECU revert to using the WGDC table only? | |
| The Following 2 Users Say Thank You to Lex For This Useful Post: | djuosnteisn (12-05-2010), FreeFlyFreak (12-06-2010) |
| Not Ranked : 0 score With constant boost, you'll have varying load. For instance 15psi in 100 degree weather would result in much lower load (air flow) than in 30 degree weather (and 100 degree weather would be quite a bit slower). The ign advance will be calculated as normally for that given rpm and load point.
| The Following 5 Users Say Thank You to djuosnteisn For This Useful Post: | dougefresh_ (05-03-2011), jwilkins88 (12-05-2010), m4tic (12-05-2010), Micha (01-04-2015), rfinkle2 (03-19-2011) |
| Not Ranked : 0 score would the tune need to be modified occasionally for temperature swings while using the boost target switch?
| The Following User Says Thank You to m4tic For This Useful Post: | rfinkle2 (03-19-2011) |
![]() Join Date: Jul 2008 Location: Imperial MO
Rep Power: 582 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
| Not Ranked : 0 score Would this table function correctly when using an external gate and a grimspeed solenoid given the correct adjustments are made? Also with this checked, do we still have the ability to do boost by gear?
__________________ 2008 MazdaSpeed 3 AWD big turbo...blah blah blah Last edited by Jarods7920; 12-05-2010 at 10:40 AM. |
| The Following User Says Thank You to Jarods7920 For This Useful Post: | rfinkle2 (03-28-2011) |
![]() Join Date: Jan 2009 Location: Newark, NJ
Rep Power: 1040 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,110
Groans: 661
| Not Ranked : 0 score |
![]() Join Date: Sep 2008 Location: Phoenix, AZ
Rep Power: 1352 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 813
I suppose the only reason to run a boost setup like this is if you can't get your per gear set up properly, or don't want to bother with it? Configuring with the boost setup seems simpler. Losing unique configs for gears 1 and 2 make this even more a deal breaker for me also.
__________________ Some things. | |
| The Following 5 Users Say Thank You to evidence For This Useful Post: | Dano (12-07-2010), djuosnteisn (12-06-2010), Fobio (12-08-2010), FreeFlyFreak (12-06-2010), speed23 (12-05-2010) |
| Damn, i wont be able to play with this until thur, but i def want to modify one of my maps based off psi value. What should the load cap tables be set, to, 5.0 still?
| The Following 2 Users Say Thank You to Haltech For This Useful Post: | djuosnteisn (12-06-2010), rfinkle2 (03-19-2011) |
Rep Power: 414 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 105
I'm trying the boost toggle today and loving it (ambient 28F.) I have enough experience to know what boost my car can run year round so no problems there. With my max boost at max summer setting, I get 20x load reported, so no problems there. The huge thing for me is it's much, much smoother to drive. Christian or Trey mentioned in passing that this might happen, but didn't offer an explanation. On a pair of 4-5 shifts I got no, and just a smidge of spike, so that's interesting. Just preliminary, but so far it's looking very promising for a DD.
__________________ ![]() | |
| The Following 5 Users Say Thank You to fjames For This Useful Post: | 08_ms3_gt (12-07-2010), evidence (12-05-2010), Fobio (12-08-2010), FreeFlyFreak (12-06-2010), rfinkle2 (03-19-2011) |
Groans: 661
Heres my log: http://www.mazdaspeedforum.org/forum/foru...-fmic-bt-e.csv | |
| Not Ranked : 0 score You can't really compare loads car to car because the MAF cal will be different. I just go by what the 2871 guys see, and what fully bolted guys see, compared to me. My conclusion is anything that starts with "2" is probably okay if boost is in line. In other words, if you were running 22 psi to get that load, you should be worried, but at 18 psi, you're in the safe zone for performance tuning (which is inherently unsafe.) Your AFR is pretty erratic and you know your pressure is fucked. I wouldn't be doing anymore logging or aggressive driving until you get that fixed.
| The Following 2 Users Say Thank You to fjames For This Useful Post: | manelscout4life (12-06-2010), rfinkle2 (03-19-2011) |
Groans: 661
| Not Ranked : 0 score Yea I know I'm waiting to get a fuel pump the tune is done for now |
| The Following User Says Thank You to manelscout4life For This Useful Post: | rfinkle2 (03-19-2011) |
I have not created a failure scenario for the MAP sensor in order to see how the ECU will respond...although, I do believe that you should be able to zero out the Boost Dynamics table and then the ECU should operate with a open-loop boost control system and just run what is in the tables.
Christian. | |||||||
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
I guess I just want a bit of caution thrown in here. When we first got started on this platform people "tuned" by installing MBCs and map clamps (ie. mechanical boost targeting) and I remember well all the blown engine threads when winter and cold temperatures rolled around.
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk | |
| Not Ranked : 0 score I think a fair amount of those blown motors resulted from load cap fueling issues. Colder weather = higher calc loads. Higher calc loads + calc load cap = lean afr's and propensity for deto...
Varying load can introduce a thousand problems, most of them we probably have not discovered yet, thats probably why OEMs switched to using load.
| The Following 4 Users Say Thank You to Ziggo For This Useful Post: |
| POWERED BY POLSKA ![]() Join Date: Apr 2010 Location: Eagle, WI
Rep Power: 389 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 948
Groans: 38
| Not Ranked : 0 score just subbin yo
__________________ BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB 25%E85FREEKPERMED |
| [MSF STIG] ![]() Join Date: Apr 2008 Location: Gloucester, VA
Rep Power: 2121 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,476
| Not Ranked : 0 score [quote]
__________________ `07 Speed6 Sport Tit Gray Sleeper Express... SOLD `11 Ducati 1198SP SBK Duc Red w/Termi exh; Redline flash-tune + PC-5; Sargent; Shift-tech, CDT, & EVR Carbon; 14F/39R gear w/FBF QC; Speedymoto; R&G; ProGrip; Custom LED; Antigravity; Ducabike; Duc Perf, etc... a 182whp/105wtq The BIG DOG `12 Ducati 1100SP EVO Hyper Duc CORSE w/Termi exh; Redline flash-tune + PC-5; Ducshop Hyperstacks; 14F/41R gear w/FBF QC; Shift-tech, CDT, & BST(wheels) Carbon; R&G; ProGrip; Antigravity; Ducabike; Duc Perf, etc... a 95whp/75wtq The Hooligan `12 Aprilia RSV4 "Factory" SBK w/Akra Tit exh & race map; 15/42 gear; R&G; ProGrip; Gilles; CompWerkes; LightWerkes; Lightech; LSL Pegs; Antigravity; Zero Gravity; AF1 Flat Carbon, etc... the 181whp/83wtq The Land Rocket `17 Ford Focus RS Nitrous Blue w/Cobb V3/AT; OZ Ultraleggera; Schroth harness The Super Fun Toy | ||
![]() | | #24 | ![]() |
I've also updated additional base calibrations for the different MS platforms. I apologize about only showing love to the 2007-2008 MS3 owners ![]()
Christian. | ||
![]() | | #25 | ![]() |
If it were true all the time, then I wouldn't be able to run over a 1.6 load as this is the value at the 75% row in my TRL A&C tables (gear values are 1.84.) So, hypothesizing here, it may be a technically correct "fact" in isolation, but when added to a system, the result will vary according to the many other variables involved? Most particularly I'd guess would be the DBW table, where most have max throttle at say a 1.5 load or even lower. I tested again today a bit (not logging, just eye-balling) and no to little spike. It's almost thrilling to see the boost simply climb and hold at maybe +.25 psi from target on a shift - this in 19F ambient. Looks like you did what I figured you'd do on the IAT table - I'm going to try that to see what happens, but I run Boost Dynamics at a 30% reduction both sides, and have max values at higher rpm in WGDC at maybe 40, so it may not apply to my setup. I have a feeling some of these options for tuning boost response may be redundant - different path to the same result. Trying to figure now what the "best" path might be, or if it really matters. Again and still, just loving the boost toggle.
![]() | | #26 | ![]() |
| This thread is now stickied and should be a good resource for future reference.
| The Following 3 Users Say Thank You to Haltech For This Useful Post: |
![]() | | #27 | ![]() |
![]() | | #28 | ![]() |
| Not Ranked : 0 score Fjames, have you checked to see if the boost by gear is still functioning?
__________________ 2008 MazdaSpeed 3 AWD big turbo...blah blah blah |
![]() | | #29 | ![]() |
I wouldn't want to start tuning with boost though - the reason it's easy for me is I'm so familiar with load tuning on this car. I can verify boost levels against load in previous logs. In other words, it would be pretty stupid to run more boost than you need at high rpm, and you won't know those limits until you fine tune load first. I think that makes sense Now thanks to Cobb, you can do both.
![]() | | #30 | ![]() |
| Not Ranked : 0 score WTF? Is there such a thing? LOL At high rpms WOT, I'm thinking that boost is ALL that matters, until the head pops off, or the rods exit. The Load is a calculation of efficiency which does not matter when making max power. Heck, you can keep jacking up the Load targets until the motor blows and you'll not know what manifold pressure it took to blow unless you happen to be logging at the time. IMO, Load tuning is great for emissions and if you want to consistently limit the power output, but "big power" is made with manifold pressure to get the air into and through the motor.
![]() | | #31 | ![]() |
| Not Ranked : 0 score With your beaner3, sure, within reason, but with the stocker (I should have qualified my comment to apply to the stock turbo) there's so much heat it doesn't matter. This car likes to make power (by power, I mean hp and tq together) between 3.5 and 5K - tuning above that is in the "fine" tune area for sure to me. Of course, this is for a DD perspective. Most DD people aren't interested in using holes in the block as a tune indicator You could run meth, and just blow the turbo instead of the whole motor ... my comments are sans meth.I prefer load tuning because I like using the ecu's brain power to manage boost. Trouble is, that brain has been corrupted by the factory in ways I don't like, that are still unexposed to us. So the boost toggle to me isn't "boost tuning" it's the "anti-factory load tune." I don't know what you mean by limiting power. We're just moving air through a cylinder here, how you control that air is just a detail. If one guy tunes for 18psi boost at 6K and another guy tunes with load to give the same boost at same rpm, they're making the same power at 6K. If they did this in dead of winter, come summer the load tuned guy would be making more boost. Reverse the seasons and the result is reversed. That's a good thing to me, but the bugger is in the details. like always, and the factory tuning doesn't get those details right for me.
| The Following 5 Users Say Thank You to fjames For This Useful Post: | Dano (12-07-2010), DSIT995 (12-07-2010), Fobio (12-08-2010), FORZDA 1 (12-07-2010), FreeFlyFreak (12-07-2010) |
![]() | | #32 | ![]() |
| Not Ranked : 0 score No problem, just pokin' ya. ![]() As for the Load based tuning, it certainly gives the tuner (OEMs especially) much finer control over the power output than the much simpler (but admittedly coarser) boost based tuning. In the old(er) days an EBC was the hot setup rather than fiddling with WG springs/preload.
| The Following User Says Thank You to FORZDA 1 For This Useful Post: | fjames (12-07-2010) |
![]() | | #33 | ![]() |
| Not Ranked : 0 score Couldn't you blend boost tuning with the IAT comp tables to get the best of both worlds as far as keeping load in check in cold weather? ya know applying Christian's approach to your maps. I think this would be a great approach if it works as intended. Of course you still lose gear based tuning unless the Boost comp tables do anything and I do like my gear based load tuning but think I would like gear based boost tuning better if we could get that to work. I think boost tuning would be both easier for the tuner and ECU. Trying to input load targets that match the natural rise in load through the RPM range is much harder to do than inputing target PSI. This naturally induces boost occiliations if you don't match the commanded load rise with RPM and PSI. so many new things to play with
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 |
| The Following 2 Users Say Thank You to Dano For This Useful Post: | djuosnteisn (12-07-2010), FreeFlyFreak (12-07-2010) |
![]() | | #34 | ![]() |
I never thought it was trouble matching load through the rpm range, unless months of tedious, time consuming logging is trouble I never went for max load in the midrange though. I just kept increasing until the WGDC got out of line, or the increased boost produced diminishing results. I still think the culprit is still to be revealed to us, but working with what we've got, the boost toggle seems the way to go. I'm real curious to log, and should probably lay off hammering it until I do. Next week maybe.Speaking of new stuff, I'm surprised you guys haven't tried setting the "BATvECT Comp % used" ignition table to 1.0. My car has never met mapped spark really, and now we know why - it knocks it down first thing according to the new help file. I set mine to .89 in the 6K column, because it's obvious that table is in tune with the stock ignition table where the 5.5K column is king - i.e. artificially high compared to others. If I was into spark tuning, that would be the first thing I did, so you're starting with half a clean slate with your map spark values (the other half is still dirty, with the "subtractive" table that follows.)
| The Following 2 Users Say Thank You to fjames For This Useful Post: | Dano (12-07-2010), FreeFlyFreak (12-07-2010) |
![]() | | #35 | ![]() |
| Not Ranked : 0 score I'm honored to be worthy of a poke Would have appreciated some lube though.
| The Following User Says Thank You to fjames For This Useful Post: | FORZDA 1 (12-07-2010) |
![]() | | #36 | ![]() |
| Not Ranked : 0 score on IGN so you are saying you took the .70 value out of 6K and input .89...I was just working on my IGN advance and noticed in my logs that once I hit 6K I don't hit IGN targets anymore...ureka! And a value of 1.0 effectively negates that whole table just like we do with ABS load tables setting to 2.50?
![]() | | #37 | ![]() |
__________________ ![]() | ||
![]() | | #38 | ![]() |
| Not Ranked : 0 score hahah I have too much work to do with boost/load targeting to mess around too much with timing...there are plenty of other guys just itching to give it a go.
![]() | | #39 | ![]() |
| aspiring turbo guru ![]() Join Date: Dec 2008 Location: Minnesota
Rep Power: 241 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 245
i may work on fracking around with it (Dano, you've done this?), but for now i flashed a 1.06 map in the hope that it'll keep my AFR's healthy.
__________________ 01.5 S4 6MT Stage 3 02 S6 6MT swap 93 S4 project [sold - 90 Miata - summer/project car, turbo w/ goodies, DIYPNP, springs/struts, etc.] [sold - 08 MS3 GT - intake/downpipe/tuning/fuel pump/TMIC/springs/struts/etc.] | |
| The Following User Says Thank You to 08_ms3_gt For This Useful Post: | djuosnteisn (12-08-2010) |
![]() | | #40 | ![]() |
| Not Ranked : 0 score Sounds like your MAF cal is off just a bit.
| The Following 2 Users Say Thank You to FORZDA 1 For This Useful Post: | 08_ms3_gt (12-07-2010), djuosnteisn (12-08-2010) |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/initial-details-into-how-boost-based-tuning-66400/ | ||||
| Does Boost Dynamics (Boost Based Tuning) do anything? - Page 2 - Mazda 6 Forums : Mazda 6 / Mazda Atenza Forum | This thread | Pingback | 04-12-2011 06:14 PM | |
| Volkswagen releases initial pics, details on all-new Caddy | Haltech | Automotive News | 0 | 07-22-2010 04:50 PM |
| Initial Impressions of Grimmspeed Boost Solenoid | tbot | MazdaSpeed 3/6 - ECU Computer Tuning | 44 | 04-14-2010 04:45 PM |
| Please educate me on a few details of how the turbo on this car works... | Smokehouse | MazdaSpeed 3 - Engine, Transmission & Driveline | 28 | 01-02-2009 04:05 PM |
