  • 1 Post By Lex
 Old 09-01-2012, 11:04 PM   #1
AlecLarson's Avatar
Posts: 52   (View Stats)
AlecLarson has a reputation beyond reputeAlecLarson has a reputation beyond reputeAlecLarson has a reputation beyond reputeAlecLarson has a reputation beyond reputeAlecLarson has a reputation beyond reputeAlecLarson has a reputation beyond reputeAlecLarson has a reputation beyond reputeAlecLarson has a reputation beyond reputeAlecLarson has a reputation beyond reputeAlecLarson has a reputation beyond reputeAlecLarson has a reputation beyond repute
Groaned at 8 Times in 1 Post
Default Knock, Looks Terrible
Check it out, I have no idea what to look for. I know that I felt a bit of hesitation or something fishy when I was logging this, it was quite humid as well. Would upgrading to one step colder plugs help this or does it look catastrophic? Cobb OTS stage 2 SF, TIH map.
-Thanks
AlecLarson is offline   Reply With Quote
 Old 09-01-2012, 11:07 PM   #2
The car is running a little lean for my tastes. Also what is the overall timing? You should definitely be logging that.
Is this also a common occurrence or did it happen in that 1 log?
dead-zone likes this.
 Old 09-01-2012, 11:12 PM   #3
AlecLarson's Avatar
That was the first time I felt anything like that, didnt feel it after that one log either. I'll have to add back in the overal timing in the datalog, I have no idea. Bad gas maybe?
How does my fuel pressure look?
Last edited by AlecLarson; 09-01-2012 at 11:12 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-01-2012, 11:14 PM   #4
Fuel pressure looks fine. When asking for help also give more information such as what your mods are as well as what map you're running etc.
 Old 09-01-2012, 11:17 PM   #5
AlecLarson's Avatar
I should have put my mods in my sig by now. Cobb sri/tih, dp, tp, resonators removed, bpv, stock hpfp (i know, i know, I'm watching it closely). Just running the ots stage 2 SF/TIH map.
 Old 09-02-2012, 03:23 PM   #6
x09MS3GT's Avatar
Posts: 409   (View Stats)
x09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the world
Groaned at 92 Times in 11 Posts
Your AFR's went lean as fuck after your flat foot shift. If you notice you started climbing into the high 12's almost 13:1 AFRs which undoubtedly cause the KR onset which only got higher with the car leaning out further.
I know theres a couple dudes around here that have been trying to tune out this lean condition from flat foot shifting, but, the thread kinda died. I cant remember where it went.
I just dont do it. Haha.
--Cobb Sri--Cobb Tip--Cobb Airbox--Cobb Fmic--Cobb Bpv--Cobb Turbo-back----Cobb V3 Ap--Cobb Rmm--Jbr Pmm--Jbr Tmm--Cobb Sts----6510's--Autotech's--KW V2'S--Jbr Fsb--Jbr Rsb--STOPTECH Sport Kit--E30 FREEKTuned --
x09MS3GT is offline   Reply With Quote
 Old 09-02-2012, 06:37 PM   #7
AlecLarson's Avatar
Interesting, I have noticed this does only happen when I flat floot shift and at the same time. Yeah, it would be nice if it could be tuned properly to not run so lean during ffs.
Knock Knock Knock..Whose There? (<===total noob) thomas_cory2000 MazdaSpeed 3/6 - ECU Computer Tuning 158 06-12-2014 11:57 PM
Terrible Gas Mileage - Please Help DRS211 CX-7 > Issues & Troubleshooting 43 09-16-2013 08:30 PM
Terrible response with BNR S3! EmPeEs6 MazdaSpeed 3/6 - Big Turbo Builds 17 07-16-2012 05:52 PM
Terrible Radio reception dcphantom MazdaSpeed 3/6 - Car Audio & Electronics 4 06-04-2009 07:31 PM
Low knock, good boost, but terrible AFR's kgb MazdaSpeed 3/6 - ECU Computer Tuning 1 11-26-2008 10:15 PM
Page generated in 0.27577 seconds with 23 queries
