 Old 03-05-2012, 09:24 AM   #1
radioflyer's Avatar
Posts: 729   (View Stats)
radioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the worldradioflyer is the leader of the world
Groaned at 22 Times in 12 Posts
Default KR when letting off throttle
Can anyone confirm if this is normal? I will get an average of .35 to .7 depending on how quickly i let up off of the pedal, sometimes even 1.0 and if I really let off from like 75% to 0% I've seen it go higher.
On a possibly related topic, I think I may have the loose timing chain issue which I'm not sure if this would cause this or not. (This engine is stock except for SRI and TIH + AP w/ stage 1 map and MAF cal). This engine is brand new (re-manufactured) and was installed by mazda like 10k miles ago, but I do get an intermittent clicking which doesn't appear to be the pulleys.
Does any one have a a video of what the loose pulley tensioner sounds like for comparison? I keep hearing a clicking at idle (not too bad) but I would like something to reference so I know if I should stock out and head to the dealer to get the chain replaced. Thanks in advance.
radioflyer is offline   Reply With Quote
 Old 03-05-2012, 09:25 AM   #2
Boost Addict's Avatar
Posts: 1,327   (View Stats)
Boost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the worldBoost Addict is the leader of the world
Take off your oil cap and you can reach down in there and feel if the chain is loose.
2008.5 BM MS3 // Cobb AP V3// JBR 3.5" WP Full Intake // CXRacing Piping/Godspeed Core // CNT 3" Catted Downpipe // Custom 3" CBE // KMD v2.1 Fuel Pump Internals // Turbosmart Dual Port BOV // Airlift Suspension // Corksport Skid Plate // JBR 88Duro Dogbone RMM // JBR SSP // SURE AGS Knob // Denso ITV22 // STACK Boost Gauge // DDM 6k Low HID's // CP-e Towplate // 15% Tint // 18x10 Blitz Type 03
FREEKTUNE
Boost Addict is offline   Reply With Quote
The Following User Says Thank You to Boost Addict For This Useful Post:
radioflyer (03-05-2012)
 Old 03-05-2012, 09:43 AM   #3
KR when letting off is just noise - documented well on here in a thread called KR Explained.
atvfreek (03-05-2012), helmetface (03-05-2012), radioflyer (03-05-2012)
 Old 03-05-2012, 09:55 AM   #4
Ckmazdaspeed3's Avatar
Posts: 2,077   (View Stats)
Groans: 134
I get 8 all the time at part throttle and letting off.
Ckmazdaspeed3 is offline   Reply With Quote
The Following User Says Thank You to Ckmazdaspeed3 For This Useful Post:
 Old 03-05-2012, 10:33 AM   #5
radioflyer's Avatar
Whew, sigh of relief. Now I guess can actually step on it on my drive home today.
The Following User Says Thank You to radioflyer For This Useful Post:
kgb (03-06-2012)
 Old 03-06-2012, 10:39 AM   #6
kgb
kgb's Avatar
Posts: 808   (View Stats)
Groans: 88
In before boom.....
j/k....
FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs
WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s
AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI
MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute
JAM SESSION........US Amps (in Series w/ Stock Amp) using
OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back)
RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors
- Acne Rear Bumper LED Reflectors
Recirculation sound after letting off gas is gone! aanguia1 Gen2 MS3 General Discussion 40 09-30-2011 11:00 AM
OL/part throttle at what percent throttle? MS3Zoom24
Cobb ATR Support
4 10-31-2009 02:37 PM
Letting a map settle in?? GQ_WhiteMS3
Cobb ATR Support
20 05-24-2009 06:05 AM
Page generated in 0.26527 seconds with 24 queries
