 Old 04-04-2013, 09:49 PM   #1
6262ms3's Avatar
Posts: 103   (View Stats)
6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute6262ms3 has a reputation beyond repute
Default KR at WOT issue
Apr 2 13 log.csv
Running Stage1 CS 91 map, mods are CS short ram and CS TMIC. LTFT and fuel pressure looks good but AFR is a bit lean and getting too much KR. This log was on 94 octane as I thought maybe I had junk 91 gas in my area, it did drop the KR from before but not nearly enough.
Any recommendations on where I should start looking to solve the problem? I read the sticky on KR and searched a bunch of other posts but I haven't seen exactly the same issues I'm having. If I needed an MAF Cal wouldn't my LTFT also be out of whack?
Thanks in advance, I've switched to the Safe Map CS 91 for now.
'07 MS3. Cosmic Blue, CPE 60-duro rmm, Cobb Accessport, Corksport sri, Corksport tmic, TWM shifter base bushings, JBR adjustable short shift plate, Koni FSD-4045 Struts, RX-8 Rims.
6262ms3 is offline   Reply With Quote
 Old 04-04-2013, 09:55 PM   #2
jseams's Avatar
Posts: 1,414   (View Stats)
jseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the world
Originally Posted by 6262ms3 View Post
Attachment 101691
Does this "safe" map show KR too?
Honestly, it looks like mechanical noise to me... and holy shit, that's not a little lean. That's a lot lean for a pump gas map.
Hmm, the more I look at it the more I'm not sure. lol
CRMetallic 2019 Mercedes C43 AMG
SOLD MNBlue 2012 S4 Prestige... a few mods
SOLD IB 2015 3.8 Gencoupe Ultimate
BLOWED UP DIB 2014 Mustang 5.0... a few mods
SOLD - LS 2012 MS3
Cobb AP//SF//CAB
Autotech HPFP
Corksport TMIC//BPV//TIP//BTbs
JBR 88a RMM
Sure M3 TP
OBX CBE
Tanabe NF210's
ADVAN RG-D 18x8 +38
Freektuned 50/50 E85
jseams is offline   Reply With Quote
 Old 04-05-2013, 09:01 AM   #3
LuvWagon's Avatar
Posts: 34   (View Stats)
LuvWagon is just really niceLuvWagon is just really niceLuvWagon is just really niceLuvWagon is just really nice
Groaned at 16 Times in 8 Posts
Looks like the same issue as me, i just posted my datalog if you wanna compare. Im running stage 1+ SF+TIH. but your definitely lean. I would do a maf cal. Maybe you could try the itv22 plugs (one step colder) but i dont think you really have the mods for that yet
LuvWagon is offline   Reply With Quote
 Old 04-05-2013, 09:50 AM   #4
Keko's Avatar
Posts: 1,455   (View Stats)
Groans: 107
Groaned at 9 Times in 9 Posts
Definitely too lean, start off with a MAF cal and go from there. You can't look at LTFT during a WOT run. LTFT is only used in closed loop. Do some searching on how to do a MAF cal
Also, the timing seems pretty high for a 91 map. Are you sure you flashed the 91 version? I would double check that. I don't think any of my 91 maps have had timing that high, even on my current e-tune.
2012 MS3
Stratified 91
 Old 04-06-2013, 08:18 AM   #5
6262ms3's Avatar
Thanks everyone, I'll do an MAF Cal. Gotta put some more miles on the safe map first.
:: new issue :: :: Gusto :: MazdaSpeed 6 - Engine, Transmission & Driveline 10 09-14-2009 10:00 PM
Page generated in 0.26673 seconds with 24 queries
