 Old 03-20-2008, 06:46 PM   #1
winniep's Avatar
Posts: 333   (View Stats)
winniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the world
Default Link to trouble codes......
Well, I finally got my map clamp in and am in the process of getting it dialed in when out of no where I get a code. I actually went too far on the adjustment and need to bring it back down a bit so I'm hoping it is just some voltage code or something minor. Anyway the code is 0139. This code ring a bell? Anybody have a link to all of Mazdas trouble codes?
winniep is offline   Reply With Quote
 Old 03-20-2008, 06:48 PM   #2
See attached
SLS MS3 (03-21-2008)
 Old 03-20-2008, 07:22 PM   #3
winniep's Avatar
Thank you for that info! The only thing is that the P0139 code is not on that list
I searched around on the mazda247 forum and came up with it being for a catless DP? Is this correct? I have the Corksport DP and midpipe and thought that the CEL problem was fixed with the extension they gave me. Anyway, hopefully that's all this code amounts to and if that's the case, I'll just clear it and go on. Thanks again for that info and sticky Haltech!
Mazda OBD-II Trouble Codes Haltech MazdaSpeed 3/6 - ECU Computer Tuning 9 06-18-2019 05:12 PM
D-Link DUB-H7 7 Port USB 2.0 Hub $9.99AR Haltech Hot Deals Section 0 04-03-2008 12:20 PM
Turboxs FMIC trouble. Davidb MazdaSpeed 3/6 - Turbo Induction 4 04-03-2008 10:03 AM
D-Link Rangbooster G Router $39.99 Haltech Hot Deals Section 0 03-31-2008 06:50 AM
Page generated in 0.25284 seconds with 22 queries
