 Old 08-19-2019, 03:25 PM   #1
Deriksson's Avatar
Posts: 2   (View Stats)
Deriksson is an unknown quantity at this point
Default "low" boost issue
Hello, im kinda new to tuning and i got the AP stage 1 at the moment, i been testing for a while since ive read somewhere that the tune needs a few miles to take full effect?
Anyway i only managed to hit 14 psi boost levels and stage 1 98 octane says i should hit 16.5 peak boost. +- 1.5. Was hoping that someone could take a look at my log.
I have done a pressure test and couldnt find any leaks. Log is from a 3rd gear pull.
Should add the im all stock exept for an aftermarket BOV
Deriksson is offline   Reply With Quote
 Old 08-22-2019, 01:01 AM   #2
Deriksson's Avatar
Anyone?
 Old 08-22-2019, 05:37 AM   #3
Police - Grammarhead
Vansquish's Avatar
Cobb OTS tunes are garbage and ever since the V100-era tunes, I've never seen one hit boost targets.
 Old 10-03-2019, 08:56 PM   #4
The_big_dill's Avatar
Posts: 38   (View Stats)
The_big_dill has a spectacular aura aboutThe_big_dill has a spectacular aura about
Seems like your Short term fuel trims are quite high, are you not getting any codes?
Do you see the same limitations on the stock tune?
Did you recently replace the BPV?
The_big_dill is offline   Reply With Quote
Got a boost "flutter" issue meeker13 MazdaSpeed 3/6 - Big Turbo Builds 8 11-23-2010 08:16 PM
Solution to the "squeaky front sway bushings in cold" issue? Mifunego Mazdaspeed3/6 General Discussion 0 01-04-2009 09:47 AM
Page generated in 0.31261 seconds with 23 queries
