 Old 06-24-2011, 11:15 PM   #1
volodya84's Avatar
Posts: 1,552   (View Stats)
volodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the worldvolodya84 is the leader of the world
Groans: 42
Default LTFTs at WOT
I have LTFTs at WOT of 15, anyone know wtf it means?? Is my shit going to blow up??
Corksport TMIC // Denso ITV22s .028" // COBB SRI // Corksport TIP // Forge V1 BPV // COBB AP // JBR SSP // TWM Bushings // Prosport Boost Gauge // CS Interior LED kit
"ban post whoring brownies"
Forge v1
volodya84 is offline   Reply With Quote
The Following User Says Thank You to volodya84 For This Useful Post:
kmac (06-24-2011)
 Old 06-24-2011, 11:29 PM   #2
kmac's Avatar
Posts: 1,792   (View Stats)
What's your afr
 Old 06-25-2011, 02:08 AM   #3
WorstEpEver's Avatar
Posts: 418   (View Stats)
WorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the worldWorstEpEver is the leader of the world
Check for leaks, then calibrate your MAF
How-To NATOR A Boost Leak Tester for $15
HOW TO CALIBRATE YOUR MAF! With An Example
09 MGM Sport
AP (MIA ) / Internals / TMIC / CAI / TIH / Downpipe / CBE / Short shifter / RMM / RSB
WorstEpEver is offline   Reply With Quote
 Old 06-25-2011, 09:07 AM   #4
Abilor's Avatar
Location: LOUISIANA!! Football, Guns, Cars, Crawfish, and Beer
Posts: 839   (View Stats)
Abilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the worldAbilor is the leader of the world
Originally Posted by WorstEpEver View Post
This wouldn't address WOT LTFT, only commanded AFR in OL.
Volodya84, do you have logs of this? It suggests you might not be entering open loop early enough. any other spots with LTFTs like that?
Traded
Abilor is offline   Reply With Quote
 Old 06-25-2011, 09:12 AM   #5
volodya84's Avatar
Groans: 42
the log is in my thread titled installed corksport tmic and itv22s
Sent from my SPH-D700 using Tapatalk
Forge v1
 Old 06-25-2011, 09:18 AM   #6
volodya84's Avatar
Groans: 42
see the thing is that this i happening in a cobb boost tuning map im testing for the cobb forums.
Forge v1
 Old 06-25-2011, 10:11 AM   #7
Abilor's Avatar
Is it one of those beta maps? Could be an error bro. Was it doing it before/consistently? I think one guy his AFR was 40.
Traded
 Old 06-25-2011, 07:27 PM   #8
volodya84's Avatar
Groans: 42
it is a beta map. previously right after intalling my tmic and itv22s I flashed the regular ots stage 1+ sf 93 v 106 map and drove on it a little, and the ltfts at idle were 9 but under any throttle they were 0
Forge v1
 Old 06-25-2011, 11:15 PM   #9
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
In your closed loop fuel tables... reduce CL MAX Load table C to 1.2 or so. Log your calc load, and compare it to this table. You want the max cl table C values to be lower than what you're logging for calc load at those rpms. GL
Abilor (06-26-2011)
 Old 06-26-2011, 10:09 AM   #10
Abilor's Avatar
Exactly, an LTFT of 15 under what is crazy. Try what's mentioned above me, but 9 at idle suggests MAF cal is in order.
Traded
Discussion on how bypass valves can affect LTFTs. Sacrilicious MazdaSpeed 3/6 - Turbo Induction 155 01-04-2016 05:50 PM
Negative LTFTs at idle. Tokay444 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 34 05-28-2011 08:09 PM
COBB Intake V2 and LTFTs Stan-O MazdaSpeed 3/6 - ECU Computer Tuning 23 03-26-2009 03:11 PM
ltfts affected by diff maps??? spnkr21 MazdaSpeed 3/6 - ECU Computer Tuning 4 03-16-2009 09:07 AM
LTFTs and Winter MidwestSpeed3 MazdaSpeed 3/6 - ECU Computer Tuning 6 11-12-2008 09:34 AM
Page generated in 0.32292 seconds with 24 queries
