Like Tree48Likes
 Old 09-11-2012, 09:13 AM   #121
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Originally Posted by NavySVO View Post
@ms3blackmica can the 4th gear portion of the cal be done on a dyno? I only ask because:
A. I want to dyno the car for numbers, and I can then kill 2 birds with one stone, and
B. It aleviates trying to find an area around here where I can open up to that speed while logging, traffic and cops.
of course it can be done a dyno !
www.tunedbynishan.com
 Old 09-19-2012, 12:51 AM   #122
Nishan
@Pierre Loubser
how did that scalar work out for you ?
 Old 09-19-2012, 11:57 AM   #123
MizzyMS3's Avatar
Posts: 511   (View Stats)
MizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the worldMizzyMS3 is the leader of the world
This is great! Thank you for this!
2012 CWP MS3 w/ Tech Package
Cobb AP V3 Purple Drank Tuned (E33 mix) | HTP 3.5' Intake | eBay Catless DP | UR CBE | CX-Racing FMIC | Autotechs | Turbosmart Dual Port BOV | JBR Short Throw Shifter | JBR Stage 2 SSP | JBR 88 duro RMM | RallyArmor Mudflaps | Eibach pro kit + Koni Yellows + SPC Camber Arms | NGK step colder
MizzyMS3 is offline   Reply With Quote
The Following User Says Thank You to MizzyMS3 For This Useful Post:
ms3blackmica (09-19-2012)
 Old 09-19-2012, 12:26 PM   #124
Nishan
Not a problem.
If you have any other questions, feel free to ask.
 Old 09-19-2012, 12:35 PM   #125
UnknownSuperhero's Avatar
Posts: 2,462   (View Stats)
If this was covered before, I apologize. I am looking for a consensus.
1. What is the target # and what is an acceptable #. (for example, anything less than .08 etc. with 0 being ideal.) Also, is there a oh crap moment? (If it is above 10.0 do a maf cal right now kind of thing)
2. Is a + or - number prefered if there are LTFT values.
3. Do you believe revisions are necessary? If so at what interval.
4. If someone is doing a cal, starting with + numbers, next revision they are -, and the third revision they are back in the +, what is the best course of action?
Thanks a bunch in advance. This is a great tool!
 Old 09-19-2012, 12:53 PM   #126
Nishan
1. I am usually happy if the LTFT's are within 3-4%. 3-4% seems to be a good number between cold and warm weather changes. Although trims up to 6% aren't really an issue either. 10% really isnt an "OH CRAP" moment. My fuel trims will go to +10% when i put the AC on. This is normal. I'd say anything in the 20% range is an "oh shit i need to do a maf cal now" type of moment.
2. They can be + or - (absolute value). The ECU will either be pulling fuel out (-) or adding fuel in (+). As long as your within + or - 3%, you have a good maf calibration.
3. What exactly do you mean? It usually takes a couple revisions until your MAF cal is nice and tight. If you add any intake flow mods, you will have to revise.
4. This can happen a lot. For example, someone might have a 4.7% LTFT. Then they take 4.7% out, and now they have a LTFT of -3.9%. And then they try to add 3.9% and the same thing happens. This is usually the cause of not putting enough miles on the car before taking a maf cal log. Also some people like to only add as much as they need..For example, if your LTFT is +4.7%, some people might add only 4% to the maf breakpoint in order to bring the LTFT's around 0.7%. That is another way of going about it. Takes some time and practice. Also make sure you have no leaks.
UnknownSuperhero (09-19-2012)
 Old 09-19-2012, 12:53 PM   #127
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Target trim is 0%, you are correcting towards this value, based on the latest learned trims. Trims will change throughout the year, so I don't worry for anything less than 6 or 8%. If I see trims beyond those (after a good Cal), I know there are other issues (leaks).
Negative is probably preferred for the closed to open loop transition range. The thinking is the car will be biased rich as it transitions, thus being safer. It doesn't exactly work this way, but whatev, it's a good sentiment haha.
Revisions are usually only necessary when hard parts change. I tend to leave them as is so I can identify significant variances caused by other issues. Again, 1 proper Cal is typically all it takes. [If you dick with vtcs or repair issues, this may not be true].
If you're doing a MAF Cal right, you won't have revisions with significant variance after. If you see big swings, you're likely trying to tune around a leak.
-06 MS6
-Corn fed 07 MS3 - Sold
The Following 5 Users Say Thank You to phate For This Useful Post:
Micha (01-04-2015), ms3blackmica (09-19-2012), rfinkle2 (09-19-2012), SLOWHATCH (10-01-2013), UnknownSuperhero (09-19-2012)
 Old 10-04-2012, 03:17 AM   #128
Nishan
UPDATE:
I cleaned up the original post as it was a bit messy. It is much cleaner now.
I also editied the original post with instructions and an example on how to scale your MAF curve for a larger sized intake, as it seems many people are upgrading and want to know how to adjust their MAF curve for this.
Cheers
EDIT: @Raider, Can you update the OP of this thread that was placed in the KB section? I wanted to edit it myself but i do not have access to do so. All you have to update is the text at the beginning of the OP with the text you see in this thread. Thanks
802MS3 (10-04-2012)
 Old 10-08-2012, 06:06 AM   #129
done
ms3blackmica (10-11-2012), SLOWHATCH (10-01-2013)
 Old 12-18-2012, 02:43 PM   #130
Island mazda's Avatar
Posts: 59   (View Stats)
Island mazda is infamous around these partsIsland mazda is infamous around these partsIsland mazda is infamous around these partsIsland mazda is infamous around these partsIsland mazda is infamous around these partsIsland mazda is infamous around these partsIsland mazda is infamous around these parts
@Haltech,
Thank you for doing that ! However please stay tuned, as i will be uploading one last youtube video for WOT Maf Calibrations shortly and you can add that to the zip file
by not doing that u thnk it can make my car run rich and when i hit 4k rpm it kind of work better
Island mazda is offline   Reply With Quote
 Old 12-18-2012, 02:43 PM   #131
Nishan
what?
yes you need to perform a OL-WOT MAF Calibration if you are not hitting targets provided you have no leaks.
 Old 12-18-2012, 03:12 PM   #132
When I accelerate my car really burn Rich and black smoke comes out when I check the spark plug they are really really black
 Old 12-18-2012, 03:43 PM   #133
Nishan
what is your AFR when this happens?
I hope you know that black smoke out of a DISI is pretty normal
DSIT995 likes this.
 Old 12-18-2012, 03:55 PM   #134
I have an aem afr and it goes to 17 to 18 then it stops to read 3 dots and red light
 Old 12-18-2012, 05:13 PM   #135
Nishan
I really hope your aux wideband is wrong.
you need to fix your car.
judging by the other posts you have made in other threads, you say you have a gt40 turbo?
did you install a larger intake and not scale the maf ?
 Old 12-18-2012, 05:53 PM   #136
Yes I do and I cp piston,front mount intercooler and 3" intake ...the car won't even go a hill
I don't even self know how to scale it? I order a cobb it should be here 2marrow
Last edited by Island mazda; 12-18-2012 at 05:53 PM. Reason: MSF Database - Automerged Doublepost
 Old 12-18-2012, 06:56 PM   #137
jdmage_mx5's Avatar
Posts: 1,877   (View Stats)
Crap dude, stop where you are at and sell your car....or put it back to stock. I'm no expert but I'm not sure you are ready for any mods. LOL.
The Following 2 Users Say Thank You to jdmage_mx5 For This Useful Post:
bstover17 (12-19-2012), SLOWHATCH (10-01-2013)
 Old 12-18-2012, 07:00 PM   #138
I don't blame u I ready to do that shit.. I should of never sell my fucking Evo ....
 Old 12-18-2012, 09:35 PM   #139
dantes5823's Avatar
Posts: 6,576   (View Stats)
dantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the worlddantes5823 is the leader of the world
Groaned at 52 Times in 48 Posts
Posts full part list.
dantes5823 is offline   Reply With Quote
The Following User Says Thank You to dantes5823 For This Useful Post:
ms3blackmica (12-18-2012)
 Old 12-18-2012, 09:51 PM   #140
Nishan
so you installed a BT and a 3" intake with no AP?
stop driving car until you get AP
 Old 12-19-2012, 12:53 AM   #141
What's an ap?
The Following User Says NO Thank You to Island mazda For This Un-useful Post:
Raider (12-19-2012)
 Old 12-19-2012, 01:00 AM   #142
GODspeed7's Avatar
Posts: 3,456   (View Stats)
What's an ap?
@Raider; please kill it with fire!
Stop posting, stop driving your car, stop touching your car, and for the love of god please read the damn forum before you blow your car up!
Tapatalk LIKE A BOSS!
2012 Mazdaspeed3 Black Mica
The Following 3 Users Say Thank You to GODspeed7 For This Useful Post:
CamSpeed360 (12-19-2012), ms3blackmica (12-19-2012), SLOWHATCH (10-01-2013)
 Old 12-19-2012, 04:30 AM   #143
What a great help.... I thought this site was to help ppl not to dis anyone but its all good just because am from the virgin island
 Old 12-19-2012, 05:53 AM   #144
GODspeed7's Avatar
Ok I'll be nice. AP is cobb accessport. BT is big turbo. These are called acronyms. They are letters that represent a word. Also known as an abbreviation. There is a whole thread donated to these acronyms. But you need to read the welcome email as well as all the other threads you can. Ok?
The Following 4 Users Say Thank You to GODspeed7 For This Useful Post:
CamSpeed360 (12-19-2012), ms3blackmica (12-19-2012), rfinkle2 (02-08-2013), SLOWHATCH (10-01-2013)
 Old 12-19-2012, 06:44 AM   #145
What's an ap?
I am going to groan you. I" do not care who you are, where you are from. You were sent a welcome PM with important links. We have a knowledgebase, with a "start here". That was answered in there.
Please go to the KB and read up.
Micha (01-04-2015), ms3blackmica (12-19-2012), SLOWHATCH (10-01-2013)
 Old 12-19-2012, 09:25 AM   #146
Nishan
you need to help yourself first
dantes5823 (12-19-2012)
 Old 01-21-2013, 08:16 AM   #147
T_Bishop's Avatar
Posts: 1   (View Stats)
T_Bishop can only hope to improve
Groaned at 6 Times in 1 Post
This is a great tutorial but I'm a real noob when it comes to tuning. I really want to get my maf calibration done but I just know I will screw it up. If I send you my logs could you fix them up for me? I would be willing to paypal you some money for your time.
T_Bishop is offline   Reply With Quote
 Old 01-21-2013, 08:25 AM   #148
magicka's Avatar
Posts: 520   (View Stats)
MAF cal is easy, but if you're concerned, go here for help.
2009 CWP MS3 GT
The Following User Says Thank You to magicka For This Useful Post:
ms3blackmica (01-21-2013)
 Old 02-05-2013, 04:25 PM   #149
Tommy's Avatar
Posts: 2,309   (View Stats)
Tommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the worldTommy is the leader of the world
Groans: 155
Groaned at 44 Times in 37 Posts
Thanks!
Tommy is offline   Reply With Quote
The Following User Says Thank You to Tommy For This Useful Post:
ms3blackmica (02-05-2013)
 Old 02-24-2013, 08:48 PM   #150
BJSpeed3's Avatar
Posts: 88   (View Stats)
BJSpeed3 has disabled reputation
Default Question about MAF Calibration
Hello,
I recently received my Cobb AP, and decided to download the SURE stage 1 OTS map off of the cobb website. I am currently only running a SURE Aeros V2, and SideWinder TIH. After watching your very well done videos, I have been attempting to achieve a MAF calibration with some confusion. Once I completed the log just as you do in your video and look at my data, I am seeing something quite different under my LTFT column. My LTFT are showing 7.03 throughout the duration of the log until hitting 80 g/s when the LTFT turns to 0. Any idea what I am doing wrong? I only have about 80 miles on this map, is that enough for a log? Thank you so much for any assistance you may be able to offer.
Thanks again,
BJSpeed3 is offline   Reply With Quote
 Old 02-24-2013, 11:58 PM   #151
Nishan
Originally Posted by BJSpeed3 View Post
Hello,
Thanks again,
Take another MAF Cal log with STFT added for more data to analyze.
 Old 02-26-2013, 03:50 PM   #152
BJSpeed3's Avatar
Hello,
Thanks again for your help, I really appreciate it. Here is another log I just took including a few more types of data. If anything else is needed I will gladly do another log today.
 Old 02-26-2013, 04:40 PM   #153
udntknw's Avatar
Posts: 1,062   (View Stats)
Groaned at 9 Times in 7 Posts
I may be wrong, it's kind of hard to read that on my phone. But it appears you are hitting your breakpoints and the ltfts are changing as they should.
just tap it in
**Old Motor**
Best trap speed - 112mph
**New Motor**
Best trap speed - 112.5
 Old 04-05-2013, 08:54 PM   #154
Linus2600's Avatar
Posts: 12   (View Stats)
Linus2600 will become famous soon enough
Hey guys. I just received my AP, so I'm trying to learn a bit here. I have a 2012 MS3 and just installed my GFB BoV and CS Stage II SRI and I want to flash the OTS Stage1+CS+TIH 93 tune and start putting on the miles for the mafcal. I have already adjusted the breakpoints as OP suggested and before I get started had a few questions...
1. Even though I selected an OTS tune designed for my intake i assume I will still need to scale the MAF curve, is this correct?
2. If it is correct I am using the formula provided and coming up with
(x^2)/(s^2) where s^2 is equal to the stock MAF Diameter Squared
s^2 = 66.5^2 = 4422.25
Corksport SRI = x
x = 67.82
x^2 = 4599.55
so...
4599.55 / 4422.25 = 1.04
and then ill multiply all the cells in the MAF table using the 1.04?
Does that seem right?
3. Do I do that adjustment prior to getting some miles on the ECU?
4. I'm holding AFR's between 11.4 and 11.6 with the BoV Venting 100% is it
recommended to stop that now? I have heard both positive and negative things about this.
Thanks in advance, I'd rather get it right the first time and thank you OP for the great videos and guides it is really appreciated
Linus2600 is offline   Reply With Quote
 Old 04-05-2013, 09:08 PM   #155
Jeremy3eb's Avatar
Posts: 359   (View Stats)
Jeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the world
Hey, I used this tutorial awhile ago but just wanted to stop in and say thanks for your work putting this together!
Jeremy3eb is offline   Reply With Quote
 Old 04-05-2013, 10:47 PM   #156
aldekei's Avatar
Posts: 831   (View Stats)
aldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the worldaldekei is the leader of the world
If you have an OTS for that intake, the you don't need to scale. That will cause all sorts of issues.
Perform the MAF cal as documented and be happy. You will never get it perfect, so don't stress over the last 2% or so.
As far as running 100% vta... I wouldn't, unless you pick up a Guardian Angel. You are going to run rich at shift and likely leak under vacuum. This will eventually lead to carbon build up around the O2 sensor and a $300+ part to replace.
tapawhat
HTP 3" MAF and Turbo Inlet in Candy Blue over Chrome Smoke
CP-E Downpipe /w Custom Cat | Corksport Catback Exhaust
Beachshoer Intake Manifold P/P /w VTCS Delete
Sure Shortcut | Sure Anchors | Sure 1/8 TIG
Cobb AP | Cobb FMIC | Cobb Sport Springs
ATP GT3071R /w Stratified Boost Dial
Stratified Automotive Guardian Angel
Go Fast Bits Respons (100% VTA)
Autotech Internals
I tune myself, bitches
aldekei is offline   Reply With Quote
The Following User Says Thank You to aldekei For This Useful Post:
Linus2600 (04-06-2013)
 Old 04-06-2013, 09:58 AM   #157
Linus2600's Avatar
Thanks for the input, just flashed it so now its time to start getting some miles on the car. I guess ill set the BoV back to 50/50 or rull recirc. The GA looks cool but internals are next so that little luxary will have to wait. I appreciate the input man, logs to come.
 Old 04-06-2013, 11:45 AM   #158
dot584's Avatar
Posts: 426   (View Stats)
dot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the worlddot584 is the leader of the world
Just go full recirc, you will still be able to hear the psssh if you have an intake and without any tuning problems. Win win.
Sent from my Incredible 2 using Tapatalk 2
CP-E TIP and Cai - Corksport 3" catless DP - Magnaflow CBE - KMD fuel pump internals - Cobb AP - Fat Cat Motorsports Coilovers!
dot584 is offline   Reply With Quote
 Old 04-09-2013, 08:43 AM   #159
Linus2600's Avatar
Ok so did my first MAF Cal and must have fucked up the math somewhere, 30 miles later i threw a p0300(random misfire) and reverted bak to the OTS map with my ltft from +10/-8.
Logged about 80 miles yesterday, redid the calibration and after first attempt im at -2.3/+1.8 consistanly...Gonna drive another 75 miles or so and re log.
One more question, if my ltft is sitting at 0.0 on my AP when im on the throttle (about 30 miles in) thats good right? Im assuming that means my ecu does not feel that it has to do any adjustments, is that correct?
Thank you again for the time
 Old 04-09-2013, 09:27 AM   #160
aldekei's Avatar
That really depends on what you mean by "on the throttle". If WOT, then you will always see 0, this is where the second half of calibration comes in.
As to the code: That can be caused by a number of things. Did you feel a stutter or loss of power? Did the code come on under partial throttle while cruising?
As I recall, that code can be triggered by an imbalanced clutch as well, so it is really tough to troubleshoot. Google it, and try to run down what others have found. Worst case, stock out and take the car into a dealership.
tapawhat
Autotech Internals
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/maf-calibration-tutorial-121334/
Corksport Stage 1 Maps? : mazda This thread Refback 04-22-2015 06:19 AM
Cobb Access Port ordered... What map to start with? Help! ? Mazda MPS Owners Club This thread Refback 03-11-2015 04:41 PM
Versatune MAF logs ? Mazda MPS Owners Club This thread Refback 02-26-2015 01:11 PM
Sorry gents, MAF CAL ? Mazda MPS Owners Club This thread Refback 12-24-2014 06:33 AM
Self-tuning adventure! - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 10-09-2014 12:23 PM
Help With my Current Mods - AP and Chrome Molly This thread Refback 09-16-2014 09:48 PM
Ok to run 12.5:1 AFR @ WOT until E-tuned? This thread Refback 08-21-2014 12:49 PM
MPS Gen 2 - CEL P0172 - Bank 1 Rich This thread Refback 08-15-2014 05:51 PM
Cobb AP users - and fellow self mappers. This thread Refback 08-11-2014 09:29 AM
Versatune MAF logs This thread Refback 07-22-2014 10:55 PM
4th Gear WOT log This thread Pingback 07-05-2014 02:40 AM
MAF cal end result? This thread Refback 07-05-2014 12:02 AM
Versatune MAF logs This thread Refback 05-10-2014 04:45 AM
P0172 - Fuel System too rich This thread Refback 04-29-2014 11:41 PM
Versatune. This thread Refback 04-18-2014 02:10 PM
Lean at idle This thread Refback 04-16-2014 11:21 AM
Tearing into the MS6 first time, pics - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 03-20-2014 01:54 PM
Rok - build and boost my MZ3 2006 - Page 113 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 03-12-2014 06:16 AM
Cobb Access Port ordered... What map to start with? Help! This thread Refback 02-27-2014 02:39 PM
help on engine noise. no zzb for me please - Page 3 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 01-29-2014 09:17 PM
Newbie COBB User This thread Refback 01-20-2014 06:26 AM
Versatune. ? Mazda MPS Owners Club This thread Refback 01-02-2014 02:42 PM
Newbie COBB User ? Mazda MPS Owners Club This thread Refback 12-21-2013 08:12 AM
Cobb Access Port ordered... What map to start with? Help! ? Mazda MPS Owners Club This thread Refback 10-29-2013 11:25 AM
Cobb AP with Speedie TIP? - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 10-17-2013 05:28 PM
Versatune. ? Mazda MPS Owners Club This thread Refback 09-30-2013 09:24 AM
help on engine noise. no zzb for me please - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 08-12-2013 04:37 PM
VersaTuner: ????????, ??????????, ????? ?????? This thread Refback 08-07-2013 10:58 AM
maf calibration speed3 2010 - Mazda 3 Quebec This thread Refback 08-02-2013 05:30 PM
Help With my Current Mods - AP and Chrome Molly ? Mazda MPS Owners Club This thread Refback 07-14-2013 08:54 AM
performing a closed loop maf cal! - Page 5 This thread Refback 05-17-2013 06:41 AM
AFR issue... Injectors? - Page 6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 05-02-2013 11:55 AM
SweetLew's Sweet Tunes This thread Refback 04-28-2013 01:05 AM
COBB AccessPort This thread Refback 04-07-2013 12:22 PM
cobb maps pure boost v231 - Page 2 This thread Refback 01-27-2013 10:23 AM
Cobb AP users - and fellow self mappers. ? Mazda MPS Owners Club This thread Refback 01-10-2013 11:33 AM
My first AP log ? Mazda MPS Owners Club This thread Refback 12-28-2012 12:07 AM
BNR Tuning - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Refback 11-09-2012 06:02 AM
ltft -14.8 at idle This thread Refback 09-17-2012 12:21 PM
MAF Calibration gfather Mazdaspeed3/6 General Discussion 8 05-24-2012 09:09 PM
KR after MAF Calibration ms6mil MazdaSpeed 3/6 - ECU Computer Tuning 2 05-11-2012 11:20 PM
MAF calibration Xploder08 MazdaSpeed 3/6 - ECU Computer Tuning 1 04-25-2012 05:00 AM
Page generated in 0.64315 seconds with 38 queries
