 Old 11-18-2008, 08:39 AM   #1
ElBartoRex's Avatar
Posts: 1,186   (View Stats)
ElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the world
Default The MS3 AccessPORT and Check Engine Lights
I used to have a Subaru WRX with a Cobb AccessPORT and I know that Cobb programmed their OTS maps so that the catalyst inefficiency codes would not show up.
I have been trying to find out, to no avail so far, if this is also the case with the MS3.
So of you have a high-flow or catless exhaust on your Mazdaspeed3 and you load one of Cobbs OTS maps, will it eliminate the P0421 'catalyst efficiency below threshhold, bank 1' check engine code?
I would like to know this before I purchase an AP.
thanks in advance!
ElBartoRex is offline   Reply With Quote
 Old 11-18-2008, 10:24 AM   #2
christian said they have not found out how to do this yet
ElBartoRex (11-18-2008)
 Old 11-18-2008, 10:25 AM   #3
Cobb Tuning's Avatar
Posts: 1,192   (View Stats)
Not at the moment. That functionality will be added into the upcoming software upgrades.
MAZDASPEED EXPERT GROUP
The Following User Says Thank You to Cobb Tuning For This Useful Post:
 Old 11-18-2008, 12:09 PM   #4
ElBartoRex's Avatar
interesting, thanks for the quick answer guys
PLEASE HELP! Trouble with engine light and check oil! spd6rcr08 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 10-01-2008 10:00 AM
Check engine light??? supergoose MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 07-20-2008 07:42 AM
Removing Engine Valve Cover, Belt-Driven Transmission, Battery Sulphation, Replacing Dashboard Lights, Buying Tires For Haltech Automotive News 0 07-10-2008 11:10 AM
Removing Engine Valve Cover, Belt-Driven Transmission, Battery Sulphation, Replacing Dashboard Lights, Buying Tires For Haltech Automotive News 0 06-10-2008 02:12 AM
Page generated in 0.24643 seconds with 22 queries
