 Old 04-17-2009, 09:42 AM   #1
Thermonuclear Skeet
FantasmoNegro's Avatar
Posts: 2,810   (View Stats)
FantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the worldFantasmoNegro is the leader of the world
Groans: 188
Groaned at 333 Times in 222 Posts
Default MS6 Issues
Alright my freind is having issues. He has a 2007 Speed6 that seems to be giving him shit today. On his way to work his car felt like it was dead, like it was running NA. He doesn't have any engine mods done to it so I doubt there is loose clamps or anything of that sort. He said it did it in all gears as well, it just felt like it would never come up on boost. What could be wrong with it?
If you hit boost cut does the car go into limp mode?
If it does, why would a completely unmodded car boost cut?
Could it have an AP tune on it? If it does how could you tell if you don't have an AP? How could you flash it back to stock? Any help is appreciated. He is going to reset the computer when he gets off of work.
FantasmoNegro is offline   Reply With Quote
 Old 04-17-2009, 10:25 AM   #2
johnnyspeed6's Avatar
Posts: 1,364   (View Stats)
johnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the worldjohnnyspeed6 is the leader of the world
Groaned at 16 Times in 14 Posts
Sounds like a dicked up waste gate that is staying open and not letting the turbo spool ... make sense ?
2008 HG Bullitt Mustang. Long Tube headers, SCT tuner,MGW short throw, FRPP hot rod cams high flow cats, charge motion plate delete
johnnyspeed6 is offline   Reply With Quote
 Old 04-17-2009, 10:40 AM   #3
Thermonuclear Skeet
Groans: 188
That is what I was thinking too, or something like the vac line to the WG coming loose or something along those lines.
He bought the car used and doesn't know if it was moddedmuch or not. It does have aftermarket wheels and a rear motor mount. So the likely hood of this thing having mods removed is there. It has a stock airbox looks completely stock in the engine bay.
 Old 04-17-2009, 11:24 AM   #4
mdogg's Avatar
Posts: 841   (View Stats)
mdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the worldmdogg is the leader of the world
Groans: 86
Groaned at 36 Times in 25 Posts
the line coming off the WG would lead to VERY HIGH BOOST (actuator CLOSED) - not no/low boost.
just ask StreetUnitMark all about that
L76-powered
mdogg is offline   Reply With Quote
 Old 04-17-2009, 11:42 AM   #5
Thermonuclear Skeet
Groans: 188
Thats right. My bad.
 Old 04-17-2009, 04:51 PM   #6
SharkDiver's Avatar
Posts: 969   (View Stats)
SharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the world
There could still be loose clamps even tho the car is stock.I would check all the clamps and hose for problems including the turbo inlet clamp just to rule that out.Did he check his intake filter?maybe its super dirtly and not flowing well or was it a hot day?Maybe he was just heat soaked with that tmic.Other then that stuff I dont know..Thats a good idea to reset the ecu and see how things go after that tho.
Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more
http://videos.streetfire.net/profile/SharkDiver.htm
http://www.youtube.com/user/sharkdiverjohn
SharkDiver is offline   Reply With Quote
New Shoutbox issues smakdown61 Website Help/Feedback 6 01-23-2009 09:22 AM
Still having issues with this site. Help!! jmhinkle Website Help/Feedback 5 11-03-2008 05:31 PM
AP MAP issues bioevolve MazdaSpeed 3/6 - ECU Computer Tuning 8 06-16-2008 05:41 PM
A/C Issues DAC17 Mazdaspeed3/6 General Discussion 3 06-10-2008 04:39 PM
Page generated in 0.27872 seconds with 23 queries
