Like Tree32Likes
 Old 11-17-2011, 04:05 PM   #1
Cobb Tuning's Avatar
Posts: 1,192   (View Stats)
Default MAZDASPEED AccessPORT and AccessTUNER Get Big Updates
COBB Tuning is excited to announce new developments for the MAZDASPEED community. The COBB Tuning AccessPORT is the first OEM ECU tuning solution for the 2012 MAZDASPEED3, giving owners of the newest MAZDASPEED3 the same level of power and control enjoyed by previous model year owners. Our AccessTUNER software has also been updated to allow custom tuning by both professional tuners and DIY tuners alike. In addition, all of COBB Tuning has released a huge Off-The-Shelf calibration update, at no additional cost, that includes support for more intakes, improved post-shift performance, and boost targeting logic implemented on all model years of MAZDASPEED3 and MAZDASPEED6! Read on for more details about the work COBB Tuning is doing to make sure the AccessPORT is the most comprehensive tuning solution for MAZDASPEED performance enthusiasts.
2012 MAZDASPEED3 AccessPORT
The MAZDASPEED AccessPORT is now shipping with full 2012 MAZDASPEED3 support, preloaded with Off-The-Shelf maps to get new users up and running with the push of a button. All MAZDASPEED AccessPORTs (AP-MAZ-002) can be updated for free to support the 2012 MAZDASPEED3 with a simple firmware upgrade.
The 2012 MAZDASPEED3 AccessPORT will enable the same Boost Target Logic tuning released earlier this year, as well as have access to the massive database of free Off-The-Shelf maps with support for 13 different intake types and over 160 maps to choose from.
2012 MAZDASPEED3 AccessTUNER
Both AccessTUNER Race and AccessTUNER Pro tuning software packages have been updated to support the 2012 MAZDASPEED3. 2012 MAZDASPEED3 owners can bring their car to a professional tuner for a custom tune to maximize power output. Experienced self-tuners can download a free copy of AccessTUNER Race and make modifications to their own calibrations.
Both software packages have access to our database of Off-The-Shelf maps. These are great starting points for your custom tunes. Existing AccessTUNER users can update their existing software to the latest version following these Step-By-Step Software Update Instructions.
MAZDASPEED Off-The-Shelf Map Updates
All 1st and 2nd Gen MAZDASPEED3 and all MAZDASPEED6 maps have been updated to v2.10 and v2.00, respectively. Now all three platforms are tuned with Boost Target Logic for improved performance and consistency. Every platform now has free Off-The-Shelf maps for 13 different intake configurations, as well as maps for other common modifications, such as; turbo inlet hoses, intercoolers, downpipes and exhausts. Furthermore, these maps also include fixes to eliminate post-shift stutter and post-shift lean conditions some vehicles are experiencing. In all, over 160 maps are available for MAZDASPEED3’s and MAZDASPEED6’s, by far the largest selection of plug-and-play calibrations for the MAZDASPEED direct injection engine!
All AccessPORTs must be updated to firmware 1.6.5.0-2992 or later to utilize these new maps. Follow this Step-By-Step Firmware Update Guide to quickly and easily update the firmware on your AccessPORT. To see the latest maps available for your application, please visit the MAZDASPEED AccessPORT Map Database. Just follow this Step-By-Step Map Download and Transfer Guide to learn how to get a map from our database onto your ECU.
AccessPORT Firmware Update
In addition to 2012 MAZDASPEED3 support, the AP-MAZ-002 firmware receives several feature updates.
Monitors
  • HPFP Desired Pressure and HPFP Sensor Voltage monitors were added to 2007-2012 MAZDASPEED3 and 2006-2007 MAZDASPEED6
  • DI Fuel Pressure was renamed to HPFP Actual Pressure on 2007-2012 MAZDASPEED3 and 2006-2007 MAZDASPEED6
  • Accelerator Pedal Position was added to 2010-2012 MAZDASPEED3
  • The Boost Limit Cap now reads past the factory limit of 22.34psi on 2010-2012 MAZDASPEED3
AccessTUNER Software Updates
In addition to 2012 MAZDASPEED support, both AccessTUNER Race and AccessTUNER Pro receive several new features.
Monitors
The same monitor changes that were implemented in the firmware have also been implemented in AccessTUNER.
Tables
Many table changes were implemented on the 2007-2009 MAZDASPEED3, 2010-2012 MAZDASPEED3 and 2006-2007 MAZDASPEED6. Please see the MAZDASPEED AccessTUNER Release Notes for a full list of changes.
Diagnostic Trouble Codes
All Diagnostic Trouble Codes for each ECU type has been exposed and each has a toggle to enable/disable the DTC. For a full list in AccessTUNER, navigate to Edit > Advanced Parameters > DTC (Base).
Tuning Guide
The Tuning Guide has been revised to version 2.10, and includes the latest tuning strategies for Boost Target Tuning Logic and in-depth table descriptions.
Existing AccessTUNER users can update their existing software to the latest version following these Step-By-Step Software Update Instructions. If you do not have AccessTUNER Race, fill out the form AccessTUNER Race Request Form to receive a download link.
MAZDASPEED EXPERT GROUP
The Following 64 Users Say Thank You to Cobb Tuning For This Useful Post:
09Speed3Z (11-28-2011), 2008MS3H (11-17-2011), AegisKlein (11-17-2011), andrewpiro (11-28-2011), AZRushki (11-17-2011), AZSPEED3 (11-18-2011), b1iNkl82 (11-29-2011), BigJimMs3 (11-22-2011), BigjohnB20 (11-17-2011), Boost_creep (11-18-2011), BrianB6 (11-17-2011), cyber-ms3 (11-19-2011), Dano (11-17-2011), dead-zone (09-23-2012), djuosnteisn (11-21-2011), DONOTBUGME (11-17-2011), doubleflusher (11-22-2011), eppopipe (11-18-2011), evidence (11-18-2011), Fatguy729 (11-17-2011), Flaverre (11-19-2011), Fobio (11-17-2011), FORZDA 1 (11-18-2011), franz (11-17-2011), Frequentflyer (11-17-2011), h.h.sk1nny (11-18-2011), Hamilton69 (11-24-2011), i8urgti (11-21-2011), J-Liss (11-17-2011), josurr (11-17-2011), kabobulate (12-01-2011), kmac (11-18-2011), LatinKraze (11-18-2011), maaazda (11-30-2011), MattJackson86 (11-17-2011), MicaBlackMS6 (11-17-2011), MindCrimes (11-17-2011), MS6FL (11-18-2011), myt_tuf1 (11-17-2011), nickm757 (11-18-2011), NinjaT1985 (11-25-2011), niterydr (11-21-2011), obijack (11-22-2011), paulfitipauldi (11-29-2011), phate (11-17-2011), predapio (11-30-2011), racingred (11-17-2011), Raider (11-18-2011), rfinkle2 (11-17-2011), rigor (11-17-2011), Sid3wayS (11-17-2011), silvapain (11-17-2011), SJP0tato (11-18-2011), Speed3eak (11-24-2011), speed6253 (11-18-2011), SpeedCheese (11-30-2011), speedms6 (11-22-2011), superskaterxes (11-21-2011), super_pablo_ (11-18-2011), thehead (11-22-2011), Titanknight (11-20-2011), uncorked11 (11-17-2011), Vansquish (11-22-2011), wolly6973 (11-18-2011)
 Old 11-17-2011, 04:27 PM   #2
neofandango's Avatar
Posts: 124   (View Stats)
neofandango has a reputation beyond reputeneofandango has a reputation beyond reputeneofandango has a reputation beyond reputeneofandango has a reputation beyond reputeneofandango has a reputation beyond reputeneofandango has a reputation beyond reputeneofandango has a reputation beyond reputeneofandango has a reputation beyond reputeneofandango has a reputation beyond reputeneofandango has a reputation beyond reputeneofandango has a reputation beyond repute
Groaned at 16 Times in 5 Posts
Nice! I am excited to try it out!
neofandango is offline   Reply With Quote
 Old 11-17-2011, 04:32 PM   #3
J-Liss's Avatar
Posts: 1,949   (View Stats)
J-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the world
Groans: 81
Groaned at 30 Times in 25 Posts
<3 you cobb
2004 mazda 3-Daily
2008 mazda 6-Wife
2008.5 Mazdaspeed 3 totaled
1983- FB Rx-7 Soon to be boosted Carb epicness
Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler
J-Liss is offline   Reply With Quote
 Old 11-17-2011, 04:35 PM   #4
robry's Avatar
Posts: 862   (View Stats)
Groans: 27
Groaned at 9 Times in 7 Posts
win! already updated the AP and updated my custom tune.
The Following 2 Users Say Thank You to robry For This Useful Post:
Bucker (11-17-2011), rfinkle2 (11-18-2011)
 Old 11-17-2011, 05:30 PM   #5
ESB Jiu JItsu's Avatar
Posts: 492   (View Stats)
ESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the world
should be purchasing my cobb ap soon.....very excited to try out the Stage1+FUCAI+TIH 93
2006 Mazdaspeed6 GT Liquid Platinum Metallic
"because racecar!" " I love this $%&*ing car"
-Gram Lights 57C 18"x7.5/Cooper SR3-A 2254018/H&R Springs/SURE RMM/Diff Straps
-2.75 Blow Through MAF/Custom CXracing FMIC&BOV/Fujita SRI/AEM dryflow/PG TIP/SLS TP/Exhaust Delete/NGK LTR7IX11 plugs/ TB Coolant BP/Bat->Trunk Relocation/JBR egr delete
-TWM Stage 2 Short Shifter/JBR Weighted Shift Knob/TWM 4in Shifter Extender
-Emil Drilled/Slotted rotors/Hawk HP Pads/Clutch Pedal Mod/Shift Counter Weight Mod
-Custom Vented Hood/Custom Front Bumper/Emblem delete/Prosport Mech. boost gauge
ESB Jiu JItsu is offline   Reply With Quote
 Old 11-17-2011, 05:21 PM   #6
Driver
Fobio's Avatar
Posts: 2,479   (View Stats)
Groans: 44
are there any changes to the WGDC table/logic that requires a detune/retune?
-- Mario Andretti --
 Old 11-17-2011, 05:36 PM   #7
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
any change to the boost targeting logic to give it more "weight" for PID loop correction?
Load correction is almost instant and authoritative whereas boost targeting logic is a bit lazy at times especially with overrun conditions. I realize that we are trying to take an ECU that was born to follow load and teach it a new trick...which may take some time to perfect...just wanted to know if any changes in that area have been made.
thanks for all the hard work!
amoosenamedhank (11-18-2011), Nliiitend1 (11-19-2011)
 Old 11-22-2011, 11:44 AM   #8
Trail of Fail
Dano's Avatar
@David@COBB
since targeting is the current topic of this thread I'll quote my question posted earlier.
can we fix existing issues before we more forward trying to resolve new issues?
it would be nice to get BT logic to actually address overrun conditions like load targeting does. currently you need to cut DC down drastically to get the ECU to follow boost targets which just means the ECU isn't targeting anything and the tuner is manually getting it to target.
djuosnteisn (11-22-2011)
 Old 11-22-2011, 11:56 AM   #9
@David@COBB
I have exposed all the controls that command WGDC when in Boost Based tuning - so there isn't really any other tables or values at play. If you are having overboosting type issues, the best thing you can do is give a larger weight to the overboost side of the WGDC Boost Error comp, and adjusting your WGDC's to start a bit lower.
At this point, it is a refinement of the tune that will give your desired operation.
-David@COBB
good guess but unfortunately that doesn't work.
you could be in the 7kpa overrun with a corresponding value of -0.44 and absolutely no correction is applied.
That's not how these tables work. If it hits a value beyond the bounds of the axes, it will use the closest value on that side of the axes.
-David@COBB
Last edited by Cobb Tuning; 11-22-2011 at 11:56 AM. Reason: MSF Database - Automerged Doublepost
The Following 7 Users Say Thank You to Cobb Tuning For This Useful Post:
Dano (11-22-2011), djuosnteisn (11-22-2011), evidence (11-22-2011), J-Liss (11-22-2011), MattJackson86 (11-22-2011), SJP0tato (11-22-2011), wolly6973 (11-29-2011)
 Old 11-22-2011, 12:13 PM   #10
Trail of Fail
Dano's Avatar
-David@COBB
-David@COBB
I guess I am missing something then. the boost error is ramping up through and past each BEC value yet WGDC is not being altered at all or just very little.
so if I am running 1psi over target [7kpa] the ECU should cut .44 out of DC at each loop iteration yes/no?. I realize this iteration may take quite a few cells esp on a 2010 ECU but even 1K RPM later the DC isn't reduced by .44 if at all.
I'll try some exaggerated values in the overrun portion of BEC...I am talking like -1.xx and see what's what because the -0.xx values do nothing to alter DC on a OE boost control system.
This just to see if the ECU even cares LOL..then if it works I'll dial it in to reduce oscillation.
thanks for the response David!
edit: I would like to add that with some cars my example above does work and DC is cut as the error increases but on some cars and even sometimes on the same car it does not.
djuosnteisn (11-22-2011), MattJackson86 (11-22-2011), rfinkle2 (11-22-2011), wolly6973 (11-29-2011)
 Old 11-17-2011, 05:33 PM   #11
greg08's Avatar
Posts: 480   (View Stats)
greg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond repute
Groaned at 22 Times in 15 Posts
cant seem to update
greg08 is offline   Reply With Quote
 Old 11-17-2011, 05:37 PM   #12
J-Liss's Avatar
Groans: 81
i would love for the Launch control feature to be like a REAL LC.
2004 mazda 3-Daily
2008 mazda 6-Wife
 Old 11-17-2011, 05:46 PM   #13
Fatguy729's Avatar
Posts: 1,685   (View Stats)
Groans: 82
I have been waiting for a base BOOST TUNE for my MS6 since I got it!!! Can't wait to implement abilor's guide now!!!!
Thanks COBB for not forgetting us MS6's!!!!!!!!
TRADED : 07 MS3 GT Silver... fully bolted w/K04
CURRENT : 06 MS6 GT Silver....
KMD V2.something ~ Cobb AP ~ SURE SRI ~ Cobb TIH ~ Forge V1 BPV ~ SLS TP ~ SURE Torq R6
Fatguy729 is offline   Reply With Quote
The Following 2 Users Say Thank You to Fatguy729 For This Useful Post:
Flaverre (11-19-2011), speed6253 (11-18-2011)
 Old 11-17-2011, 05:48 PM   #14
Jake_MS3's Avatar
Posts: 859   (View Stats)
Jake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the worldJake_MS3 is the leader of the world
This is awesome! Thanks Cobb!
Sent from my iPhone 4 using Tapatalk
2009 Mazdaspeed 3
Jake_MS3 is offline   Reply With Quote
 Old 11-17-2011, 05:51 PM   #15
chuckms6's Avatar
Posts: 1,618   (View Stats)
chuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the worldchuckms6 is the leader of the world
awesome i can finally remove speed limiter!
also, has this update fixed the occasional connection error while logging?
finally where can i find the release notes?
thanks for a great product btw
DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's
SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob
Megan Racing Coilovers
13.7@ 96 w/1.8 60ft (SRI, AP)
13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's)
chuckms6 is offline   Reply With Quote
 Old 11-17-2011, 05:52 PM   #16
greg08's Avatar
how do i convert old maps to new format?
 Old 11-17-2011, 06:17 PM   #17
chuckms6's Avatar
update atr, open old map in atr, save then upload to ap
 Old 11-17-2011, 06:04 PM   #18
jw_speed3's Avatar
Posts: 409   (View Stats)
jw_speed3 has a reputation beyond reputejw_speed3 has a reputation beyond reputejw_speed3 has a reputation beyond reputejw_speed3 has a reputation beyond reputejw_speed3 has a reputation beyond reputejw_speed3 has a reputation beyond reputejw_speed3 has a reputation beyond reputejw_speed3 has a reputation beyond reputejw_speed3 has a reputation beyond reputejw_speed3 has a reputation beyond reputejw_speed3 has a reputation beyond repute
Awesome, now i just need some $$
jw_speed3 is offline   Reply With Quote
 Old 11-17-2011, 06:11 PM   #19
MattJackson86's Avatar
Posts: 1,407   (View Stats)
MattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the world
Sounds like for the Gen1 MS3's nothing major has changed. More DTC options but nothing that should change how the tune performs.
Sound about right? Want to make sure I am not missing something key here.
Great work Cobb though. Any updates are always appreciated.
GTX3071 - SURE 3.25" Full3 Aeros - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Cobb EBCS - ITV22 at .025 - 3 Bar MAP
Bitwise Motorsports http://www.bitwise-motorsports.com -
Mazdaspeed 3 BAR MAP Harness, Torque Plugins for Android, and 3-Port EBCS (coming soon!)
MattJackson86 is offline   Reply With Quote
 Old 11-17-2011, 06:30 PM   #20
greg08's Avatar
aint workin lol
 Old 11-17-2011, 06:31 PM   #21
Lots of DTC options now. Any reason that there seems to be quite a few turned off by default? All I need is the EGR code....
Also seems as though the precision of some of the values has increased. Many of my AFR tables went from 11.300 to 11.295. Also noticed the speed limiter can be bumped up to 250.0 instead of the previous max of 186.
 Old 11-17-2011, 08:10 PM   #22
Those DTC's are the ones programmed into the ECU but not turned on. Some of them vary by region - Australia, Europe, Japan, etc...
-David@COBB
The Following User Says Thank You to Cobb Tuning For This Useful Post:
 Old 11-17-2011, 06:37 PM   #23
Fatguy729's Avatar
Groans: 82
perhaps I can direct some attention to Sure intake v1 or v2???
 Old 11-17-2011, 06:41 PM   #24
greg08's Avatar
didnt work
 Old 11-17-2011, 07:25 PM   #25
chuckms6's Avatar
didnt work
did you update the firmware on the accessport as well? i may have wrongly assumed you did already
 Old 11-17-2011, 07:43 PM   #26
greg08's Avatar
how do i do that lol
 Old 11-17-2011, 08:13 PM   #27
chuckms6's Avatar
connect your ap, open accessport manager, click the update tab(should have a caution arrow now) click update firmware
 Old 11-17-2011, 09:10 PM   #28
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
hmmm i see the wgdc has been toned down a ton. has anyone run the ots and seen how kr and stuff is?
 Old 11-18-2011, 02:10 AM   #29
ms6forthewin's Avatar
Posts: 525   (View Stats)
ms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the worldms6forthewin is the leader of the world
I just loaded the stage 2 sftih+ic 91 map. I was getting mass PT KR wtf... went up to 7 i was tripping balls (Didn't even go in to boost) = ="
help???
-2014 Evo X GSR
-2007 MAZDASPEED 6 (SOLD)
BNR S3// ALL-SUPPORTING MODS
ms6forthewin is offline   Reply With Quote
The Following User Says Thank You to ms6forthewin For This Useful Post:
skeeter149 (11-18-2011)
The Following User Says NO Thank You to ms6forthewin For This Un-useful Post:
manelscout4life (11-18-2011)
 Old 11-18-2011, 09:25 AM   #30
koukizenki's Avatar
Posts: 60   (View Stats)
koukizenki has much to be proud ofkoukizenki has much to be proud ofkoukizenki has much to be proud ofkoukizenki has much to be proud ofkoukizenki has much to be proud ofkoukizenki has much to be proud ofkoukizenki has much to be proud ofkoukizenki has much to be proud of
I'm running a custom stage1+cs intake/tip v.200 tune... To use the v.210 do I need to customize that from scratch or is there a way to copy from my old tune?
-2011 Speed3 w/ Tech Package-
Cobb AP (Custom Tune) - CS SRI/TIP - JBR 80 Duro RMM - JBR Knob
koukizenki is offline   Reply With Quote
 Old 11-18-2011, 09:32 AM   #31
SRTie4k's Avatar
Posts: 1,715   (View Stats)
It would be easiest to just open two instances of ATR, one with your custom map loaded, the other with the V2.10 map, then step through each table to see what has been changed (while ignoring those tables you customized).
 Old 11-18-2011, 09:43 AM   #32
koukizenki's Avatar
Oh so make the changes onto my custom tune instead of the ots v.210 tune?
 Old 11-18-2011, 11:09 AM   #33
SRTie4k's Avatar
That's what I'm going to do once I figure out where the changes to fix the post-shift lean conditions were made.
 Old 11-18-2011, 09:59 AM   #34
super_pablo_'s Avatar
Posts: 1,648   (View Stats)
great fucking news.
I havent even touched my AP for almost a year, since my last map was spot on and has been trouble free. Recently, I started getting post-shift sputter. I read in the OP that this was fixed somehow?... Ill be looking into the OTS maps to see if i can incorporate the fix into my tune.
Anyone wanna save me some time and help me figure out what is it that they changed on the maps to "fix" the post shift lean and rich conditions? Im at work so I wont be able to check this out till tonight.
Good timing cobb. Tomorrow theres a test n tune at my local drag strip!
 Old 11-18-2011, 10:27 AM   #35
Trail of Fail
Dano's Avatar
guys that are getting tuned by someone else, you might want to check with your tuner now and in the future before you apply any updates to AP or ATR.
Bucker (11-30-2011), h.h.sk1nny (11-18-2011)
 Old 11-18-2011, 11:38 AM   #36
Originally Posted by super_pablo_ View Post
great fucking news.
Initial findings here:
Ignition Timing Limit (Min) (Throttle Closed / Throttle Open / Low ECT)
I believe username khopwood also has a thread related to this issue.
Also, pg. 63 of 69 here:
http://www.accessecu.com/support/doc...MAZDASPEED.pdf
 Old 11-18-2011, 07:00 PM   #37
These were the tables that I too saw had changed. Mine are now -3 where before they were -13
The Following User Says NO Thank You to MattJackson86 For This Un-useful Post:
rfinkle2 (11-19-2011)
 Old 11-18-2011, 10:32 AM   #38
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
ATR doesnt want to download for me. It shows its downloading the helpfile but nothing else? Should I send a request for ATR threw COBB?
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
 Old 11-18-2011, 11:15 AM   #39
parallel thread here:
AccessPort and ATR updates today
 Old 11-18-2011, 06:32 PM   #40
Frequentflyer's Avatar
Posts: 1,959   (View Stats)
All the updates were successful for me.
I've been using ATR for about two years now and feel pretty comfortable street tweaking my own maps, but I decided to load up Cobb's new OTS Stage2+SF+TIH+IC 93 v210. The only thing I did was copy over my MAF tables from my most recent homebrewed map since I pretty much had my LTFT's nailed to +/-2%. I have to say that Cobb has come a long way with their OTS maps. This map runs very well on my car. Not perfect, but pretty strong. KR is minimal also. Part throttle is a little jerky when boost comes on and I'm not sure if that's the CL/OL transition, but other than that it's a pretty good starting point for people with similar mods. Looks like timing can be bumped up a bit on it though compared to what I have been running and they're AFR's a set a little more rich than the 11.7's I was targeting, but it's a good OTS map none-the-less. I did a few logs today, but accidentily hit the wrong button in AP Manager and deleted them off my AP.
The Following User Says Thank You to Frequentflyer For This Useful Post:
jracer (11-23-2011)
AccessPORT and AccessTUNER Updates and Bug Fixes for 2011 MS3 Cobb Tuning Cobb Tuning 0 07-20-2011 03:41 PM
AccessPORT and AccessTUNER Updates and Bug Fixes for 2011 MS3 Cobb Tuning 2010 MS3 - ECU Computer Tuning 0 07-20-2011 02:51 PM
MAZDASPEED3/6 AccessPORT and AccessTUNER Updates Now Available! Cobb Tuning
Cobb ATR Support
162 12-14-2010 12:34 AM
MAZDASPEED3/6 AccessPORT and AccessTUNER Updates Now Available! Cobb Tuning Cobb Tuning 6 12-03-2010 04:51 PM
Page generated in 0.72887 seconds with 41 queries
