| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Jul 2008 Location: West Des Moines, IA
Rep Power: 853 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
(Thread Starter) | Neutral : 0 score Posting my settings for the two main tables I've touched for MPG tuning. Ignition Tables> Ign Table - Max A, Ignition Tables> Ign Table - Max B, and Ignition Tables> Ign Table - Low Throttle/CL (No Knock) are all set the same on the low end of the spectrum (meaning from .31 Calculated Load, to .69 Calculated Load and from 500 RPM to 3000 RPM all match from each of those tables). Ignition Values here: [php]40.16 40.16 50.02 54.73 57.30 58.48 26.24 34.16 42.52 41.77 43.70 43.80 27.85 34.27 42.84 41.77 41.77 41.77 24.63 33.20 40.70 40.70 40.70 39.63 17.03 21.96 28.38 31.06 36.95 34.81 7.65 11.73 20.91 24.99 31.11 29.07 4.08 5.10 10.61 20.20 27.03 24.99[/php] Fuel Tables > Fuel OL/Part Throttle Commanded EQ (No Knock), Fuel Tables > Fuel OL Commanded EQ (Throttle Closed) Fuel Tables > Fuel OL/Part Throttle Commanded EQ (Unused), Fuel Tables > Fuel CL Commanded EQ (base) are all set similarly. Here's what I'm using for my fuel tables as of today: [php]14.700 14.700 17.000 17.000 17.000 17.000 16.175 15.350 14.700 15.000 15.000 17.000 17.000 17.000 17.000 16.175 15.350 14.700 15.000 15.000 17.000 17.000 17.000 17.000 16.175 15.350 14.700 15.000 15.000 17.000 17.000 17.000 17.000 16.175 15.350 14.700 15.000 15.000 17.000 17.000 17.000 17.000 16.175 15.350 14.700 15.000 15.000 17.000 17.000 17.000 17.000 16.175 15.350 14.700 15.000 15.000 17.000 17.000 17.000 17.000 16.175 15.350 14.700 15.000 15.000 17.000 17.000 17.000 17.000 16.142 15.284 14.568 15.000 15.000 17.000 17.000 17.000 17.000 16.112 15.225 14.450 15.000 15.000 17.000 17.000 17.000 17.000 15.329 14.808 14.318 14.700 14.700 14.700 14.700 14.700 14.700 14.531 14.362 14.185[/php] I had started a couple months ago with my ignition tuning using the OTS economy tune as my reference, but really didn't get much from that tune until I started messing with timing advance in low load situations. I started by logging several of my main commute routes to see where my cruise load cells were at, generally from .38 to .69, so I made most of my advance there in 1-2% changes. Still making changes from day to day and no knock yet. If you make too large of a change and go too far, you will get some surging during cruise though, so back off a degree or two if you get that. MPG went from 26 to 28-29 MPG with these changes. I started with fueling after talking with Will (Bucker) in shout this week. Logging actual AFR, ignition advance, and load, and was feeling for a similar surge to make sure I wasn't going too lean. I set AFR up to 17 in the low load tables, but had some start-up stumble the last few days, so I changed .25 and .31 at 500 and 1000 RPM back to 14.7, and interpolated .38 values to try to smooth out the start-up idle. Up to .75 and up to 3000 RPM I changed to 17:1 and interpolated around those to smooth out. MPG has jumped this week to 32+ and I'm 90+ miles into the second tank and it's holding true on 50/50 mix of driving. I write down my mileage every tank as it's filling and figure my MPG, not just the DIC. I can't wait to get a full tank on highway!!! EDIT: Updated fuel table code above to what I'm running as of now 03/14/2012 EDIT: FYI codes P0137, P0140, and P2096 will most likely come up and need to be unticked. Downstream O2 codes.
__________________ _________________________________________ 2008.5 MS3 GT - Sold! 2011 Ford Flex LTD Ecoboost - Sold! 2013 Ford Focus SE - Sold! 1986 Porsche 944 Turbo - Sold! 2002 BMW M3 - Sold! 2014 Mustang GT 5.0 Track Pack 1974 GMC Super Custom 1500 built 350/TH400 3200 stall Last edited by bnoon; 03-16-2012 at 09:35 AM. |
| The Following 70 Users Say Thank You to bnoon For This Useful Post: | anavrinIV (03-07-2012), BAT-man (02-07-2013), BigK (11-04-2012), BigRedSpecial (03-07-2012), Boosted Beluga (12-28-2012), Boost_creep (03-07-2012), breakfasteatre (05-13-2012), Broxer (03-09-2012), Bucker (03-07-2012), chuckms6 (03-08-2012), Constantin (08-27-2012), CosmicArkie (03-27-2012), cyber-ms3 (12-05-2012), daafisch (03-07-2012), dark_matter (03-19-2012), davychronic (07-06-2015), Dust (03-12-2012), Easter Bunny (03-21-2012), Elusivellama (06-04-2012), El_Diablo (11-07-2012), Eric28243 (03-09-2012), f-castrillo (03-09-2012), flylike2kites (03-26-2016), Fobio (07-23-2012), Gr8Speed (03-07-2014), hartlch (05-05-2012), Hectik1 (03-19-2012), helmetface (03-07-2012), himurax13 (07-27-2012), HPFPUPGRADE (03-07-2012), ialewis (03-16-2016), Ingle (03-12-2012), JacksonMS30 (03-09-2012), jmhinkle (03-17-2012), josurr (04-11-2012), kritz (03-09-2012), Lex (03-07-2012), MAZ (04-06-2012), Menace1 (02-11-2013), Mistersix (03-07-2012), Mizzle (03-07-2012), MrPrime (02-08-2013), ms3blackmica (05-08-2013), MZR165 (04-12-2012), Nataphen (03-08-2012), Noddaford (04-26-2012), NoTraction (07-02-2012), obijack (04-06-2012), Pointless (11-15-2012), rghispanic88 (06-04-2012), Rich990 (05-14-2013), RichieRichness (03-16-2012), rigor (03-14-2012), robertof (02-09-2013), Sergeant_M (03-04-2014), Sneak (03-29-2012), SofaKingAwesome (03-08-2012), Speed3eak (06-03-2012), Speed_j23 (03-19-2012), Takinato (05-20-2012), thehead (03-08-2012), TiGraySpeed6 (03-07-2012), Tomas (03-18-2013), vtdone (09-19-2014), WhiteWidow (11-29-2013), wolly6973 (03-07-2012), xfeejayx (04-26-2012), xI Leveler Ix (04-10-2012), Yanahdi (08-14-2012), zpele (03-09-2012) |
| The Following User Says NO Thank You to bnoon For This Un-useful Post: | AzSpeedin (03-07-2012) |
![]() Join Date: Aug 2008 Location: Pittsburgh, PA
Rep Power: 637 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,048
| Not Ranked : 0 score Good info but UGH! Did you have to make the value's blue? Shit's killing my eyes. |
![]() Join Date: May 2011 Location: bo$ton, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,199
Groans: 219
| Not Ranked : 0 score LOL at the groan? @AzSpeedin I've been talking to people slowly for a while about this.. I have a 1200 mile(one way) trip coming up in May and I'd love to give some true economy tuning a go..
__________________ |
| The Following 2 Users Say Thank You to helmetface For This Useful Post: | Eric28243 (03-09-2012), Jonny Quest (04-11-2012) |
![]() Join Date: Sep 2011 Location: St. Johns, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,014
Groans: 56
| Not Ranked : 0 score What are you using for gas? Very much part throttle knock? I've been following @Bucker's thread but I'm still a little weary of trying it out.
__________________ 2008.5 CWP: GTX 3071//Rapebuilt EM//Relentless pnp IM//JBR 3.5" WP//TurboXS DP/RP//TR8C/Cobb FMIC//GFS bpv//JBR 88/70/70a//Eibach Pro Kit//Koni Yellows//JBR RSB//RX8's Awaiting Install: DO Stage 2//3 Bar MAP//CPe Safeseals Winter Beater: 96 GMC K1500 5 speed 4x4 Needed: Driver mod [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to BigRedSpecial For This Useful Post: | Eric28243 (03-12-2012) |
| Banned ![]() Join Date: Feb 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 385
Groaned at 22 Times in 17 Posts
| Not Ranked : 0 score It works well, very well. Moving the MPG up to 18.5 is possible. We have seen gains as high as 8 MPG by doing this. EGT's are still in check and with some fine tuning you will be able to get the car running and starting with zero issues. Great info. |
![]() Join Date: Apr 2010 Location: Columbia, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,756
Groans: 97
| Not Ranked : 0 score Making changes now. Highway cruise on Saturday. |
| The Following User Says Thank You to ScarMS3 For This Useful Post: | Eric28243 (03-09-2012) |
![]() Join Date: Feb 2012 Location: San Bernardino, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12,954
| Not Ranked : 0 score I would be happy with the 26... As long I don't go in the teens I still jusitfy my purchase
__________________ 2010 velocity red mica ms3 AP/AT internals JBR 3.5" whale peen (non rubber for more feeling) JBR SSP/bushings JBR RMM JBR tigs/ egr delete/ coolant bypass JBR stage 2 OCC CS test pipe Turbosmart BPV (stocker currently on) SS lines/super blue/stoptech pads |
| The Following User Says Thank You to lilred For This Useful Post: | Eric28243 (03-09-2012) |
| Not Ranked : 0 score I'm interested in your research on this bnoon, so keep it coming. I'm all for anything that could advance the platform. |
| The Following User Says Thank You to Mistersix For This Useful Post: | Eric28243 (03-09-2012) |
![]() Join Date: Aug 2011 Location: Terrebonne Quebec
| Not Ranked : 0 score lol car-tooning |
| The Following User Says Thank You to gotspeed For This Useful Post: | Eric28243 (03-09-2012) |
Groans: 97
| Not Ranked : 0 score Bnoon are you cat less like bucker? And since I'm now running my stock down pipe how long until I melt it, will I be experiencing problems you think even if the exhaust gas temps are down like john says? |
![]() Join Date: Jul 2010 Location: Phenix City, Alabama
Rep Power: 2996 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16,814
Groans: 451
If I recall his explanation correctly, the reaction in the converter requires Hydrocarbons to work properly. Running exceptionally lean means all of the HC are consumed in the engine, and are not available for the Cat to use. I am not sure what the long term results would be, but if you blip the throttle every few minutes and dump some fuel, you should be good lol.
__________________ 330whp/381ft/lb No Nitrous Meh 403whp/451ft/lb Dry Shot | |
| The Following 4 Users Say Thank You to Bucker For This Useful Post: |
![]() Join Date: Nov 2010 Location: rockledge fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,125
| Not Ranked : 0 score This is awesome! I was thinking of making a thread like this because I'm doing the same thing. $4 a gallon its killing me! I'm only leaned out to 16-15.5 afr at cruise but I was getting a code for too lean afr target. However I'm seeing 32 mpg up from 27 in the city, and I'm not knocking or having driveability issues. your results let me know I can push it even further, thanks! tapatalkin to you
__________________ DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob Megan Racing Coilovers 13.7@ 96 w/1.8 60ft (SRI, AP) 13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's) ![]() |
| The Following User Says Thank You to chuckms6 For This Useful Post: | Eric28243 (03-09-2012) |
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
| Not Ranked : 0 score From the book I finally looked the information up in, running lean degrades the cats ability to process NOx, and running lean actually increases NOx output as well. You can get around it with CATs designed to run lean, or in one case the car was tuned to run slightly rich for 1-2 seconds every 2 minutes. Or just say fuck it and dump the NOx Not that I really care or that you will have a huge effect, but NOx is actually a precursor to smog and is known to cause respiratory illnesses like asthma. As opposed to CO2 which is plant food.
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
| The Following 7 Users Say Thank You to Ziggo For This Useful Post: | Boost_creep (03-08-2012), djuosnteisn (03-11-2012), Easter Bunny (03-21-2012), Eric28243 (03-09-2012), Mizzle (09-02-2012), Nataphen (03-08-2012), Pointless (11-15-2012) |
Groans: 97
| Not Ranked : 0 score Gotta say I'm already slightly disappointed, could be because I just flashed the tune and it's learning still, but I still drop from completely full to below the top bar at around the same mileage, maybe a little sooner. |
![]() Join Date: Apr 2010 Location: Forney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,098
| Not Ranked : 0 score Don't they make some sort of "lean burning" cats that would allow us to do this without creating more NOx? EDIT: I just googled and found this one. I'm doing some more reading right now. http://www.gassavers.org/showthread.php?t=10666 Even better: http://www.physorg.com/news102868231.html I'm finding that the Mercedes BlueTEC diesels and VW TDI cars have these, but I have no idea how they would work on our cars being gas motors and performance driven. The VW/Audi FSI 2.0 motors have a clean-burning system with these cats as well. http://www.audiworld.com/news/02/fsi/content3.shtml This is probably the main reason that the Golf GTI is rated at 24mpg city while the MS3 is rated at 18mpg city. I think that this is a worthwhile subject to look into. I drive 160+ miles a day, so cutting down on trips to the gas pump would be great. 30+mpg in the MS6 would be like getting a raise, LOL.
__________________ 06 BM MS6=stock (totaled) 06 WWP MS6=suspension only (sold) 93 RX-7=single turbo swap, 300whp@8psi, 2600lbs (sold) Wife's 10 MS3=bolt-ons & tune, 13.6 best ET (sold) 13 5.0 Wife's 13 Focus ST Last edited by Nataphen; 03-08-2012 at 07:36 PM. |
Groans: 451
| Not Ranked : 0 score Just another note, don't go thinking we can run ultra lean just because of DI... Read: MAZDA: SKYACTIV-G | ENGINE | SKYACTIV TECHNOLOGY Look at that awesome piston, lol.
The MFG's cannot go lean because of air standards. Think about it this way... you can get a full size diesel truck to get 30 + MPG that weighs 5,000 lbs. When we start to figure out GDI, you are going to see cars getting 40 to 50 MPG. | |
| Not Ranked : 0 score Looks like a fat man's belly button. @Ziggo How much more NOx would running lean on a catted car produce than running normally on a catless car? I'd guess that it wouldn't produce as much, but you'll know more than me for sure. Last edited by Nataphen; 03-09-2012 at 02:32 PM. |
| The Following User Says Thank You to Nataphen For This Useful Post: | Eric28243 (03-09-2012) |
![]() Join Date: Oct 2009 Location: DFW - TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,477
| Not Ranked : 0 score how did you know what my belly button looks like?
__________________ 2016 - WRX -Cobb AP - Perrin Shift Stop - Perrin Trans Mount - Whiteline Positive Shift Bushings 2006 - MS6 - Dead RIP [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to BrianB6 For This Useful Post: | Nataphen (03-08-2012) |
| Not Ranked : 0 score Are the sky-actives actually lean burn motors though? They mention stratified charge, so maybe they are, but in those cases you are talking about extremely lean burn, like 20+ AFR. I thought they just EGR'd the shit out of em so that most of the cylinder volume was inert.
| Not Ranked : 0 score Seeing that VW/Audi is running 22:1 from the factory helps me to not worry as much about the long term affects on the engine and internals. I doubt that they have anything dramatically different as far as materials. |
| The Following User Says Thank You to Nataphen For This Useful Post: | Bucker (03-08-2012) |
| Not Ranked : 0 score so i increased cruise afrs to about 17-16:1 and added two degrees of timing then went about 150 miles today. in the city and on a rural highway (60mpg at 2400 rpm in 6th) i got about 33 mpg. on the interstate (80mph at 3100 in 6th) i got 27 mpg. the mixed total for the day was 28mpg. diesel final drive for 5-6th would be awesome...
| Not Ranked : 0 score I disagree. I rather like the way that these cars are built to have usable torque in all gears. I'll sacrifice a few mpg for that. It's the same argument that used to come up about 03-04 Cobra 6-speeds vs. GM 6-speeds, it just depends on your opinion. What would you say was your normal mpg before the adjustments, because I can get 28 now if I drive correctly. Before and after gains are really what would be beneficial for this. BTW, increasing timing in any table other than global max probably isn't going to do much, if anything, for the car in CL cruising. Would anything beyond 60* be a good idea? Last edited by Nataphen; 03-09-2012 at 05:30 AM. |
![]() | | #24 | ![]() |
Groans: 451
| Not Ranked : 0 score I still haven't seen any changes in my logged timing by increasing the timing tables in ATR. It pretty much does what it wants.
| The Following 3 Users Say Thank You to Bucker For This Useful Post: |
![]() | | #25 | ![]() |
Have you tried zeroing out the comp/low octane tables? Some sort of compensation is going on for sure as the logged values aren't what are in the low/high tables at all.
__________________ _________________________________________ 2008.5 MS3 GT - Sold! 2011 Ford Flex LTD Ecoboost - Sold! 2013 Ford Focus SE - Sold! 1986 Porsche 944 Turbo - Sold! 2002 BMW M3 - Sold! 2014 Mustang GT 5.0 Track Pack 1974 GMC Super Custom 1500 built 350/TH400 3200 stall | ||
| The Following 4 Users Say Thank You to bnoon For This Useful Post: |
![]() | | #26 | ![]() |
Groans: 451
| The Following User Says Thank You to Bucker For This Useful Post: | Eric28243 (03-09-2012) |
![]() | | #27 | ![]() |
My mpg was approximately 27 city, 31 rural highway and 25 interstate, so improvements everywhere but really evident in the city. A lot of people say the low load timing table has no impact but I mess with it anyway. I wouldn't figure the ecu world mess with timing during acceleration unless there was knock, but I could be wrong. tapatalkin to you
__________________ DIY SRI, DIY WAIC, VCTS Mod, Gutted Stock DP, Cobb AP, SURE TIG, KMD Internals, Denso ITV22's SURE Dreadnaught, DSS Left Rear Axle, Custom in car SSP, JBR SSP, Powered by Max Shift Knob Megan Racing Coilovers 13.7@ 96 w/1.8 60ft (SRI, AP) 13.4@ 102 w/1.9 60ft (SRI,AP,WAIC,TIG, Internals, ITV22's) ![]() | |
![]() | | #28 | ![]() |
![]() Join Date: Jun 2009 Location: Denver Colorado
Rep Power: 2697 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,601
| Not Ranked : 0 score Any chance you could post some pics of your tabels and graphs? Did you leave it rough or did you interpolate everything to where its smooth all the way across?
__________________ 2008 MGM MS3 GT - HTA3586- - P.E.R.M Twisted Top Mount - - P.E.R.M. Fifth/Sixth Port Injection - - P.E.R.M. Tuning - |
| The Following User Says Thank You to JacksonMS30 For This Useful Post: | Eric28243 (03-09-2012) |
![]() | | #29 | ![]() |
__________________ _________________________________________ 2008.5 MS3 GT - Sold! 2011 Ford Flex LTD Ecoboost - Sold! 2013 Ford Focus SE - Sold! 1986 Porsche 944 Turbo - Sold! 2002 BMW M3 - Sold! 2014 Mustang GT 5.0 Track Pack 1974 GMC Super Custom 1500 built 350/TH400 3200 stall Last edited by bnoon; 03-09-2012 at 11:19 AM. Reason: MSF Database - Automerged Doublepost | ||
![]() | | #30 | ![]() |
__________________ 2008 MGM MS3 GT - HTA3586- - P.E.R.M Twisted Top Mount - - P.E.R.M. Fifth/Sixth Port Injection - - P.E.R.M. Tuning - | |
![]() | | #31 | ![]() |
(Thread Starter) | Not Ranked : 0 score My ignition is kinda all over the place, but yeah, it doesn't seem to matter as much YET. We need to get requested ignition to mean something first though, stay tuned for more on that after we try zeroing out some ignition compensation tables to get requested to = logged. Pay more attention to the AFR tables for now.
![]() | | #32 | ![]() |
tapatalkin to you
![]() | | #33 | ![]() |
| Not Ranked : 0 score @bnoon I was asking chuckms6. I saw your info, and thanks again for the research. |
![]() | | #34 | ![]() |
![]() | | #35 | ![]() |
![]() Join Date: May 2011 Location: Durham, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,224
| Not Ranked : 0 score Subbed cuzz leat mileage. You guys kick ass and the more I can brag about the mileage of this car vs power, the better.
__________________ '08 Polar White Saturn SKY Redline - "The RAWRmobile" BorgWarner EFR 6758 + IWG Mani, forge v2 BPV, Energy Full Suspension Bushings, GMPP 3-Bars, Vibrant Racing Catted HiFlow Downpipe, WERKS Boost Tubes, Intake, Power-Steering Relocation Kit, Radiator Hoses, and Race FMIC, Koni Yellows + Eibach Pro-Kit's, RPi GT CBE, HP Tuner SquishyTooned on E40, RK Sport Rotors/Pads, DDMWorks 2-gauge Pillarpod and Armrest, Prosport HALO Electronic Wideband and Boost Gauges, Spec Stage 2+ Clutch + Fidanza Single-Mass FryWhee, XTUNERS Gauge Cluster, GM Roadster.com HID/LED Full Exterior and Interior Light Conversion Dyno: Uhh... fast as hell?'08.0 Cosmic Blue MS3 - "The Daily" STOCKED OUT (almost) COBB SRI/TIP - COBB AP SquishyTooned on E40 - COBB XLE BPV - HKS Hi-Power CBE - ITV22s - Corksport RMM Inserts - JBR Shifter Bushings and SSP - PTP Fuel Pump - PG + Treadstone - 35% Tint - ebaY Double-Penetrator - MS3 Vent Kit Install Dyno: 319 / 331CWP_MS3 is my mackdaddy |
![]() | | #36 | ![]() |
| Not Ranked : 0 score Some one needs to try 19.5 to 1, this should yield the greatest gains without any issues with EGT's. |
![]() | | #37 | ![]() |
![]() Join Date: Nov 2008 Location: Sanford/Orlando/Daytona Beach FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,682
Groans: 278
| Not Ranked : 0 score someone do it.
__________________ 2015 Mazda 6 Pioneer Z2 DVD/Nav :|: Hifonics 800/4 & 1100/1 :|: Kicker Solo Classic 15" |
![]() | | #38 | ![]() |
| Not Ranked : 0 score I'm about to take a 4 hour trip tonight, so I'll give it a shot. I'm just going to move CL exit up to a higher load and leave the timing tables to do their thing unless you guys think that it's going to make a difference to change them. I'll set all the low load points to 19.5:1 AFR. Any suggestions? I just set up my CL exit to 1.25 load, 19.5:1 up to 0.75@3500, and interpolated from 0.75-1.00 which goes back to OTS values. Good or bad? I'm going to be leaving in about 30 minutes, so I need to know if I should change something. Last edited by Nataphen; 03-09-2012 at 03:27 PM. |
![]() | | #39 | ![]() |
(Thread Starter) | Not Ranked : 0 score In reading the Cobb tuning help file I think we found why we don't get commanded ign values in our low load situations... Ign BAT vs ECT Comp. A-B Table Description - These are subtractive values (even though the number is positive) that are applied to the final ignition advance values after the initial look-up table values has been applied to the % Used multiplier. These values are subtracted from the final ignition calculation before the final ignition output is calculated. These tables are referenced by Coolant Temp. on the x-axis and by Boost Air Temp. on the y-axis. Table values are subtractive values applied to the ignition advance calculations. I zeroed out the effected tables for low load and will try to log it tomorrow to see if I can get the Ign Table - Low Throttle/CL (No Knock) values or at least close. Then I can add back in a safety margin and know what my Ign advance should be after all of the safety stuff is factored in. ![]() I'll go higher than where I'm at. I just want to get some more timing in there and learn what's effecting what before I go any leaner.
![]() | | #40 | ![]() |
Watch the total timing advance, you can get into some pretty serious pressure spikes during ignition event that could potentially cause some knock. I normally only adjust timing above 3k RPM to avoid any possibility of the pistons moving to slow. Hope this helps, and keep us posted. It will be great if we can get to 45 MPG yet still have full power! | |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/mpg-tooning-atr-107362/ | ||||
| COBB AccessPort | This thread | Refback | 02-14-2014 11:41 AM | |
| What do you make of this tuning? Lean AFRs • Mazda MPS Owners Club | This thread | Refback | 10-16-2012 11:35 AM | |
| Operation: Tighta*** tune | This thread | Pingback | 08-05-2012 09:20 PM | |
| Consommation Speed6 | This thread | Refback | 07-03-2012 02:45 PM | |
| Tooning Guinea Pig | Abilor | MazdaSpeed 3/6 - ECU Computer Tuning | 15 | 11-01-2011 11:10 PM |
