| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Jan 2010 Location: Denver, Colorado
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 174
__________________ Mile High. Silver genwon MS3. BNR S3, HTP 3" intake, 3 bar MAP with bit-wise harness, Grimmspeed 3 port ebc, AP with e-85 self tune, Autotech internals, CX racing FMIC, ST coilovers, gutted test, res deletes, turbo XS BPV, TRZ RMM, Jbarone SSP, Jbarone PMM, Moddiction anvil SK, Ultragauge, e-bay oil CC, some ebay drilled rotors, 10k hid kit, washered stock SS, 5MM spacers, Enkei Imola, and other shit i'm forgetting... Daily driver- Piece of shit 1998 Chevrolet S-10 LS. |
(Thread Starter) | Not Ranked : 0 score No one?
![]() Join Date: Apr 2010 Location: Columbia, SC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,756
Groans: 97
| Not Ranked : 0 score impatient asian. log looks good, seems like you should be pushing more air, and by that i mean your maf hits like 221 and tops out...but maybe thats your altitude... it could be that you need to pull a little timing at that spot...it hits 9 degrees and knocks and drops back to 8 and starts climbing again. could be the plugs or crappy gas, bats look good fuel pressure looks good and you seem to be hitting 11.8 which i assume is what you are targeting...all in all seems alright maybe just a revision on timing. could have been something banging in the engine compartment...i believe @phate would suggest a few gallons of e85 in the tank to see if that takes care of the knock, if it goes away its really knock if its still there then it is engine compartment crap banging around...my engine noise was around 3 to 3.5 and was due to the intercooler shroud tapping, which i fixed by putting some rubber between the intercooler and the shroud. just a few things to look at. Last edited by ScarMS3; 03-29-2012 at 07:44 PM. Reason: MSF Database - Automerged Doublepost |
| The Following 3 Users Say Thank You to ScarMS3 For This Useful Post: |
__________________ Mile High. Silver genwon MS3. BNR S3, HTP 3" intake, 3 bar MAP with bit-wise harness, Grimmspeed 3 port ebc, AP with e-85 self tune, Autotech internals, CX racing FMIC, ST coilovers, gutted test, res deletes, turbo XS BPV, TRZ RMM, Jbarone SSP, Jbarone PMM, Moddiction anvil SK, Ultragauge, e-bay oil CC, some ebay drilled rotors, 10k hid kit, washered stock SS, 5MM spacers, Enkei Imola, and other shit i'm forgetting... Daily driver- Piece of shit 1998 Chevrolet S-10 LS. | |
![]() Join Date: Feb 2009 Location: Chambersburg, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,921
Groans: 338
| Not Ranked : 0 score <225g/s and <4.2V??? I can piss out more air out of my peepee. Like stated throw some eth in the tank to see if it gets rid of knock. Get more flow mods.
__________________ Current: N54 135i DCI, DP's, Exhaust, FMIC 12.3@122 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Tial QR BPV, SURE TIG's, ITV24's, CP-E Stage 2 RMM, Medefail Tranny mount, 18x8 245/40's 390whp/400wtq 12.8@114 Sold |
(Thread Starter) | Not Ranked : 0 score I think this damn altitude plays a roll......you are correct though, i need a DP..........
Groans: 338
| Not Ranked : 0 score Aw I see colorado...elevation ftl.
| The Following User Says Thank You to 86AmishMs3 For This Useful Post: | ARES28 (03-29-2012) |
Groans: 97
| Not Ranked : 0 score The dropping is the scaling on your kr settings, you can decrease the time it takes for it to climb down by adjusting a value in atr. It's in bucker's guide, decay rate to 150, that way it's easier to identify where the event actually occurs. Also make sure you change max detection up to redline aka 6700. |
| The Following User Says Thank You to ScarMS3 For This Useful Post: | ARES28 (03-30-2012) |
| The Following User Says Thank You to ARES28 For This Useful Post: | ScarMS3 (03-30-2012) |
| First datalog after attempt at abilor tuning | SamInAustinTX | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 02-15-2012 01:03 PM |
| 1st attempt at vd | tooslow10 | 2010 MS3 - ECU Computer Tuning | 5 | 01-13-2012 05:25 AM |
| Drivers attempt at E85 | driver311 | MazdaSpeed 3/6 - Big Turbo Builds | 448 | 09-29-2011 07:21 AM |
| My Photography Attempt... CWP MS3 | typeshluder | Members Rides Gallery | 5 | 07-18-2010 09:58 PM |
