 Old 02-02-2011, 01:09 PM   #1
Zak
Zak's Avatar
Posts: 84   (View Stats)
Zak is a glorious beacon of lightZak is a glorious beacon of lightZak is a glorious beacon of lightZak is a glorious beacon of lightZak is a glorious beacon of light
Default Need help with spike
Hi,
Sorry if this has already discuss, but as you seen on my log below, I always get a boost spike when I go WOT at 3000rpm.
Little spike +21psi then go down 18psi and target boost.
I've already reduced WG, load, boost target @ 3000rpm, but still get it
Thanks
Zak is offline   Reply With Quote
 Old 02-03-2011, 12:33 PM   #2
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
If you are tuning with the AP, then datalog with it. It offers much more than the dashhawk.
You are on the right track with lowering the above targets, so you may just need to lower them a bit more. Are you 'ramping' the rates up to be maxed at 3500rpm? Meaning lower the 2.5krpm range more than 3k setting, then up a bit at 3k, then maxed at 3.5k?
Are you doing it in both the OL and CL maps? Since the stock settings don't transition to open loop until way up in the RPM range, you need to be meticulous in changing all maps related to that range.
 Old 02-03-2011, 06:12 PM   #3
Kydizzle's Avatar
Posts: 505   (View Stats)
Kydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the worldKydizzle is the leader of the world
post a good ap log.. and list your mods.
2008 Silver MS3 GT - BNR S2, CP-E HPFP, CP-E Nano, Cobb FMIC, Cobb AP(E-85 Mix [FREEKTUNE]), GrimmSpeed EBCS, CNT Exhaust, Corksport DP, SU Test Pipe W/ Magnaflow HFC, Forge BPV v1, EGR Delete, AWR RMM, SU Shifter Bushing, CP-E Towplate, BC Coilovers, Cobb RSB, Motegi SP-10 HyperBlack(19lbs)
Kydizzle is offline   Reply With Quote
 Old 02-07-2011, 12:09 PM   #4
Zak
Zak's Avatar
Mods: bolt on with stock K04.
I'm using Ecuedit to tune my car. So I can send only send you log with dashhawk.
How about turbo dynamics table to avoid spike?
 Old 02-09-2011, 07:59 PM   #5
frivolous_rob's Avatar
Posts: 1,374   (View Stats)
frivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the worldfrivolous_rob is the leader of the world
Groaned at 44 Times in 17 Posts
I experience spike to 17psi and then steady 15 in 3,4,5 and then steady 17 in 6th. WOT after 3000 rpm. Mods = test pipe, nano and hypetech tune. With the tune its supposed to be holding 17psi but that rarely happens. any advise?
Choke me, I like it.
frivolous_rob is offline   Reply With Quote
2nd-3rd Boost spike LiEast MazdaSpeed 3/6 - ECU Computer Tuning 3 02-20-2014 07:34 PM
WTF is this spike? Jarods7920
Cobb ATR Support
1 12-14-2010 05:19 PM
Boost Spike Help koston33
Cobb ATR Support
5 12-01-2009 08:20 PM
Spike of KR only happens sometimes at WOT Lex MazdaSpeed 3 - Engine, Transmission & Driveline 26 07-08-2009 09:37 AM
Page generated in 0.26075 seconds with 24 queries
