 Old 05-17-2019, 08:33 PM   #1
EtOculusDei's Avatar
Posts: 21   (View Stats)
EtOculusDei has a spectacular aura aboutEtOculusDei has a spectacular aura aboutEtOculusDei has a spectacular aura about
Default New owner, first log
Hey all, so I had the opportunity to get a 4th gear pull today, logging with the AP.
I was hoping anyone with a good mind about them could take a look at the numbers and spot any glaring concerns.
2008 MS3 on 93 Octane - 86k
Cobb AP 1 +SF OTS tune
Cobb TIP
Cobb SRI
AutoTech Internals
Damond RMM
Damond Short Shift Plate
EtOculusDei is offline   Reply With Quote
 Old 05-18-2019, 02:24 PM   #2
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
Looks decent. There's a little knock retard, check that your spark plugs are in good shape and gapped 0.026-0.028", and make sure you're using good fuel.
Get used to regularly monitoring your car, look up how to read and interpret these datalogs to hopefully spot problems. here's a very basic reference from Cobb http://accessecu.com/support/docs/su...0Guidance.html
94 M
MS6
IS350
Page generated in 0.22603 seconds with 22 queries
