| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Sep 2014 Location: Midland, Texas
Rep Power: 0 ![]() ![]() ![]() Thanks: 26
(Thread Starter) | Not Ranked : 0 score I REEEALLY need some help here on how to troubleshoot my car. Around the onset of the wintery weather I noticed a good amount of overboost from my car, I'm running Cobb's stage 1 and targeting 16.5 psi, before if i spiked at all it would be around 18 psi for a nano second and then correct into the 16's fairly quickly. Now I spike up to 20-22 on the same tune and hit fuel cut before i can even register what happened. ![]() I've been working with my WGDC and it seems to have held my boost to ~16.5 but only after it corrects a spike from 20-21 psi. It's really frustrating because it seems like nothing i do keeps the car from spiking. I tried reverting to other maps that i knew worked a few months ago and they have massive spikes now too, any gear, any rpm(over ~3000). At this point do i need to be looking for a physical issue under the hood? Or is there something in my tune that can be adjusted to limit spikes? Because like I said after the car corrects the spike i'm golden, until i shift and the spike happens again, corrects, rinse, repeat... I attached a log from the other night, i can post the map too if someone asks for it, i'm not sure if it's necessary. This issue has led to many late nights, and dozens of revisions to my ECU. So any help at all would be greatly appreciated. ![]() P.s. I may attempt making my BEC a little more aggressive all around to help cope (or maybe by not allowing it to compensate for underboosting so it doesn't throw me into the 20 psi range before the computer can stop itself), is this a good idea or am I just putting a band-aid on a stab wound?
__________________ Too much digital, not enough critical thinking, more physical reality. |
![]() Join Date: Mar 2011 Location: Dallas, Texas
| Not Ranked : 0 score Try lowering WGD 500 rpms earlier than the boost spike. If you look at your log, WGD is high before the spike, then has to adjust down... |
| The Following User Says Thank You to sheston For This Useful Post: | vincentspeed3gogh (12-18-2014) |
(Thread Starter) | Not Ranked : 0 score That' a good idea for this area in my table, but does that solve the issue that it happens when i WOT at any rpm? for example if im at 4.5k and I WOT i'll see the same spike.
| Not Ranked : 0 score Plot how your boost vs targets look. I'd guess they are high across the board? |
| The Following User Says Thank You to sheston For This Useful Post: | vincentspeed3gogh (12-24-2014) |
| Approved MSF Vendor ![]() Join Date: Jan 2012 Location: Maryland, USA
Rep Power: 884 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,286
| Not Ranked : 0 score Halve the left side of your LEC Coarse table and see if that helps.
__________________ --- 2011 Black Mica MS3 Tech --- ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following User Says Thank You to Mike@Stratified For This Useful Post: | vincentspeed3gogh (12-24-2014) |
Anyway, My targets actually look pretty good after the spike is corrected, on the datalog I attached you can see after the spike I stay within 1 psi or so of my target. The LEC coarse table is completely 0'd out, I'm on boost tune. Would you suggest working on my BEC fine table??
__________________ Too much digital, not enough critical thinking, more physical reality. Last edited by vincentspeed3gogh; 12-21-2014 at 05:44 PM. Reason: MSF Database - Automerged Doublepost | |
| Not Ranked : 0 score Either give the coarse table some authority or lower your wgdc base table in the area where your are spiking and/or just before it. Edit: Sorry, what I mean is that you need to lower your WGDC base table either way, but for a more flexible tune give the coarse and all the LEC tables some authority, aka hybrid tune. Sent while Stratified.
__________________ --- 2011 Black Mica MS3 Tech --- ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. Last edited by Mike@Stratified; 12-21-2014 at 06:41 PM. |
![]() Join Date: Nov 2010 Location: Columbus, GA
Rep Power: 4253 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,493
Groans: 307
Post up your map. Let's have a look see
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() | |
| The Following User Says Thank You to ms6mil For This Useful Post: | vincentspeed3gogh (12-24-2014) |
__________________ Too much digital, not enough critical thinking, more physical reality. | |
Groans: 307
| Not Ranked : 0 score BEC seems too aggressive on underside, WGDC are too high. Try lowering the WGDC across the RPM range like this.... Lower your BEC underside... And drop your Throttle Tables back down to 80% EDIT: Saved your map with some changes in the BEC, Throttle and WG tables...
__________________ "Here am I. Send me!" ____________________________________________ Columbus, GA 2006 MazdaSpeed 6 EBTEC Motor ¤ PTE 5862 ¤ Custom 3" Exhaust ¤ Bosch 3.5 Bar ¤ Custom 4" Intake ¤ CS Seals ¤ JBR EBCS ¤ Kozmic DP ¤ TurboSmart BOV ¤ Treadstone TR10 FMIC ¤ NGK's ¤ AT Internals ¤ 6th Port ¤ DO Meth ¤ CPE Exh Manifold ¤ Tial 44mm EWG ¤ JMF Manifold ¤ COBB AP ¤ 18x8 Tenzo Cuzco's ¤ H&R Coilovers ¤ Dual OCC ¤ Guardian Angel GT3076 - 393/380 3/9 e85 GT3076 - 426/400 E85/DO10 Meth PTE5862 - TBD ![]() Last edited by ms6mil; 12-22-2014 at 12:43 PM. |
| The Following User Says Thank You to ms6mil For This Useful Post: | vincentspeed3gogh (12-23-2014) |
Again, thank you thank you, I will update as soon as I have some results!
Groans: 307
| Not Ranked : 0 score If you've neutered the WGDC/BEC tables or zeroed them out and you are still overboosting then start looking into mechanical issues. Verify that the EBCS is all hooked up correctly.
http://www.mazdaspeedforum.org/forum/foru...6-22.25.42.jpg
__________________ Too much digital, not enough critical thinking, more physical reality. Last edited by vincentspeed3gogh; 12-23-2014 at 07:25 PM. Reason: forgot to post link | |
Groans: 307
| Not Ranked : 0 score Sounds/looks like it's time to replace that thing man.
| The Following 2 Users Say Thank You to ms6mil For This Useful Post: | Mike@Stratified (12-23-2014), vincentspeed3gogh (12-24-2014) |
(Thread Starter) | Not Ranked : 0 score UPDATE: Good news, I was poking around all of my lines, First I found that my TIP wasn't all the way down onto the turbo so i loosened the clamp and moved it down and re-tightened it and tested that. Still had unrestricted boost, so I crawled under the hood again next to my steaming hot heat shields and pulled my ebcs lines and checked them, low and behold there is a gaping hole in the wastegate line. I then took a generous amount of electrical tape and sealed it back up, test drove, and boost peaked at 11, which in this case is very good for me hahaha I realize these are temporary fixes, and i hate the way the other vacuum line has already been jerry-rigged. So I'm gonna save up for a new ebcs, and i get to work on Christmas so that extra money should help make that buy sooner rather than later. Thanks for your amazing help!!! I'm gonna hold on to the map you re-worked for me and start inching my WGDC back up slowly.
| The Following 2 Users Say Thank You to vincentspeed3gogh For This Useful Post: | Mike@Stratified (12-24-2014), ms6mil (12-24-2014) |
| Not Ranked : 0 score Glad you got it sorted out. I believe we have our EBCS in stock if you are in the market for one.
| The Following 3 Users Say Thank You to Mike@Stratified For This Useful Post: |
Groans: 307
(Thread Starter) | Not Ranked : 0 score Quick update, Just ran a datalog tonight after tuning my wgdc up a tad. Looks a little low on boost in the higher revs under 6k, but it is a work in progress. I'm still very happy with it. Let me know how it looks
Groans: 307
| Not Ranked : 0 score Log is all garbled, but the Vdyno looks better. As you said just start nudgin that WGDC table in the right direction. Did you get that cracked line or EBCS nipple sorted out.
| The Following User Says Thank You to ms6mil For This Useful Post: | vincentspeed3gogh (12-27-2014) |
Rep Power: 1237 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,288
Groans: 111
| Not Ranked : 0 score It looks fine, but with a broken nipple on your EBCS it's a matter of time before you run into a small bump and upset that hose and make it fall off. At that point you will be left with no boost control and may not even know it before it's too late. Now back to your log: if you had fuel pump internals I'd say it's fine. But load of above 1.90-1.95 with no fuel pump internals is not a good idea. At lines 35/36 in your log the fuel pump pressure drops into the 1500s which is not that bad, it's just a sign that it can go lower than that in some circumstances. So get an EBCS, fuel pump internals a TMIC, a larger intake, replace your second cat with a resonated pipe and welcome yourself in the 280+bhp club. Since you're in texas and if you want more power you should seriously think of a WMI kit for the hot summer days. WMI is good for more power as well as protection against cylinder heat accumulation.
| The Following User Says Thank You to mituc For This Useful Post: | vincentspeed3gogh (12-27-2014) |
![]() | | #24 | ![]() |
__________________ Too much digital, not enough critical thinking, more physical reality. Last edited by vincentspeed3gogh; 12-27-2014 at 02:31 AM. Reason: MSF Database - Automerged Doublepost | ||
| Not hitting boost targets, not boost leak | ADHDAdditiv | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 28 | 07-18-2014 02:18 PM |
| Not hitting Stage 2 boost targets (boost leak?) | Bubba Ho-Tep | 2010 MS3 - ECU Computer Tuning | 15 | 04-26-2012 08:25 PM |
| Help! MS6 Boost Fading In/Out. Boost Cut? Leak? | MS600RR | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 10 | 02-28-2012 08:48 AM |
| Boost Leak or Boost Cut? | Stealth01 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 14 | 12-09-2011 09:38 PM |
