Like Tree11Likes
 Old 08-22-2013, 08:46 AM   #1
ms6mil's Avatar
Posts: 4,972   (View Stats)
Groans: 307
Default Random Lean @ WOT
I had a decent map on for the last couple of days. I was trying to work out the dip in boost in the 5k RPM range, but other than that, it was running fine.
This morning, did a single log on the way to work and at around 4600 RPM my AFR's went from the 11.7(tgt) to 13's. Nothing on the map was changed from one day to the next. No change in fuel, or e85.
It is currently on boost tune, in the process of trying to collect the load info in all gears to put my hybrid tune back on.
Going to check for leaks, after work. Attached below is yesterdays(datalog3&5) and todays(log1) logs. Also attaching the VD
Curious as to why my car is being a bitch!
"Here am I. Send me!"
GT3076 - 393/380 3/9 e85
PTE5862 - TBD
 Old 08-22-2013, 01:02 PM   #2
ms6mil's Avatar
Groans: 307
I got rid of the boost oscillation, AFR's are fine now. I don't understand why this happened. Anyone have any ideas? (Checked for leaks), maybe a sensor going bad or Karma...
PTE5862 - TBD
 Old 08-25-2013, 11:31 PM   #3
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Did you change the value of the Injector Phasing Multiplier from 1.00?
If so, to what value?
www.tunedbynishan.com
rfinkle2 (01-16-2014)
 Old 01-13-2014, 05:55 PM   #4
ms6mil's Avatar
Groans: 307
First off I would like to apologize for resurrecting this thread, also for not replying.. I deployed shortly after and am now back home trying to get this car figured out.
At the time Injector scaling was as follows
~29% e85
Fast Forward to now.
Same settings, it was running fine, then the random lean @ WOT occurred again, this time a bit more often. After reading a few threads and talking to some other folks I did the following.
1. Leak test #1
2. Changed Inj. Scaling tables to account for summer/winter blend.
3. Changed Inj. Scaling back to OTS.
4. Ran out the remaining e85.
5. Removed Pump, cleaned thoroughly, to incl. spill valve. wasn't bad but wasn't great, pic's attached...
6. Boost Leak test #2
7. Full tank of 93, started and loaded a new map.
8. MAF/WOT calibration complete.. LTFT's +/-4
Was still having occasional occurrence of Lean during a pull.
9. Swapped out new NGK's gapped @ .026
10. Boost Leak test #3
11. Drove to AL Meet. AFR's were stable
12. Compression Test done 190/190/190/190
13. Did a log this morning and FUCK ME AFR went 11.9>12.1>13.1
14. Did a log on the way home and everything seemed better.
15. I have also done a smoke/vac test with nothing remarkable to note.
Attaching a couple of logs, and another screenshot of the the VD for reference..
Of note the most recent mod to go in is the Guardian Angel. Haven't tried removing yet. But this did happen prior to deployment before I even got the GA. What's really got me that even an OTS w/HTP maf scaled map that was working before is giving me same results.
Could this be an O2 sensor issue?
Any input is appreciated.
File Type: jpg FC8A7C38-2F74-4362-AB07-77D9A4CBF4CE_zpsdsoa2tyq.jpg (85.1 KB, 14 views)
File Type: jpg 7ED6CBB6-0818-43A3-A7E3-B5369A2276EC_zpskxyxzm44.jpg (107.9 KB, 14 views)
PTE5862 - TBD
 Old 01-13-2014, 06:00 PM   #5
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Try cleaning the MAF sensor?
ms6mil (01-13-2014)
 Old 01-13-2014, 06:02 PM   #6
ms6mil's Avatar
Groans: 307
sorry forgot that one, but yes that was done as well..
I'm hoping it's just something that obvious.
PTE5862 - TBD
The Following User Says Thank You to ms6mil For This Useful Post:
Agent_Orange (01-13-2014)
 Old 01-13-2014, 06:06 PM   #7
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
On phone, can't view logs, but did you go over load values of 2.5?
Edit: @Lex; just posted this: http://www.mazdaspeedforum.org/forum/foru....php?p=2412336
The Following 3 Users Say Thank You to SarcasticOne For This Useful Post:
atvfreek (01-13-2014), chaser27 (01-13-2014), ms6mil (01-13-2014)
 Old 01-13-2014, 06:12 PM   #8
ms6mil's Avatar
Groans: 307
Yes, and I thought about that too, but current map load tables are all beyond. 2.5. and I have hit beyond 2.5 with previous maps with no issues..
open to suggestions
EDIT: thanks for the link looking through the thread now
PTE5862 - TBD
 Old 01-13-2014, 06:19 PM   #9
atvfreek's Avatar
Posts: 7,787   (View Stats)
Yes, and I though about that too, but current map load tables are all beyond. 2.5. and I have hit beyond 2.5 with previous maps with no issues..
open to suggestions
What is your throttle requested load A,B and C tables set to?
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 3 Users Say Thank You to atvfreek For This Useful Post:
Agent_Orange (01-13-2014), ms6mil (01-13-2014), rfinkle2 (01-16-2014)
 Old 01-13-2014, 06:27 PM   #10
ms6mil's Avatar
Groans: 307
Currently OTS @ 3.0, Looking over Lex's thread about this very issue.
PTE5862 - TBD
 Old 01-16-2014, 10:32 AM   #11
ms6mil's Avatar
Groans: 307
Update:
I went out around 4am, I figured these cooler temps in the morning would help be replicate my 2.5 load a bit easier.
The changes were made according to @Lex; thread. AFR targets at loads higher than 2.50 ATR/ATP fix
As you can see in the logs attached the very moment it hits 2.5 load, it is still going lean then evens out by the end. As long as I stay under 2.5, AFR's are good.
Here's another VD just to reference the AFR's going lean compared to the log 3 which stayed under 2.5
I am not sure what I've missed, any input is appreciated. @atvfreek; any luck leaving the toggle unchecked
I'm going to try a boost only, hybrid and then load only map and try to toggle/untoggle the check box, also gonna try the increasing load limit a cunt hair.
@rfinkle2; @Mike@Stratified;
PTE5862 - TBD
Agent_Orange (01-16-2014)
 Old 01-16-2014, 10:55 AM   #12
I am not tuning anything that is experiencing this issue, but would you be willing to try scaling the load axis for the fueling tables?
If you do decide to, I have noticed that there is a chance that your ignition tables will be affected so please take a look @ those to make sure everything jives before flashing.
Agent_Orange (01-16-2014), atvfreek (01-16-2014), ms6mil (01-16-2014)
 Old 01-16-2014, 11:54 AM   #13
ms6mil's Avatar
Groans: 307
working on that right now, will post results later today. Thanks man.
PTE5862 - TBD
 Old 01-17-2014, 05:21 AM   #14
ms6mil's Avatar
Groans: 307
Well I have tried a few different ways and all results are the same. Once 2.5 hits, AFR's go lean. I can successfully limit load below 2.5 but the fact that I can't figure out why, when strictly boost tuning, this issue keeps popping up. what am I missing here?
These aren't as bad as before bust still see it go up to 12.4 in some spots
PTE5862 - TBD
 Old 01-17-2014, 07:02 AM   #15
Can you post a log that includes all calculated loads from your closed loop max load and redline when you get a chance?
Agent_Orange (01-17-2014), ms6mil (01-18-2014)
 Old 01-17-2014, 08:42 AM   #16
ms6mil's Avatar
Groans: 307
will do, gonna go grab some logs. muchas gracias
PTE5862 - TBD
rfinkle2 (01-17-2014)
 Old 01-17-2014, 02:11 PM   #17
ms6mil's Avatar
Groans: 307
per your request...
PTE5862 - TBD
The Following 2 Users Say Thank You to ms6mil For This Useful Post:
rfinkle2 (01-17-2014), SarcasticOne (01-17-2014)
 Old 01-17-2014, 02:33 PM   #18
If you would like to try this maf curve, it is for voltages 2.97 -5.0. You will need to do some smoothing in the closed loop / lower voltages.
Code:
105.05	106.61	108.98	112.13	116.02	119.40	124.50	130.25	136.62	143.56	151.04	159.03	167.50	176.41	185.73	192.97	202.91	213.17	223.71	234.49	245.49	256.65	267.96	279.38	290.87	302.40	311.05	322.56	334.02	345.38	356.63	367.71	378.60	389.27	399.67	409.78	419.56	426.66	435.77	444.47	452.71	460.45	467.67	474.32	480.39	485.82	490.59	493.71	497.23	499.99	501.97	503.11	503.40
Agent_Orange (01-17-2014), ms6mil (01-17-2014)
 Old 01-17-2014, 03:10 PM   #19
ms6mil's Avatar
Groans: 307
doing it now, thanks. Will post up results in a few..
Edit: just viewing the curve on this, if this addresses the lean afrs at the point of 2.5 load, what is likely to be seen if load remains under 2.5 throughout WOT? About to go get some more logs now just curious what is to be expected..
Thanks again
PTE5862 - TBD
 Old 01-17-2014, 04:14 PM   #20
I saw that you were targeting 11.7 afr's, so it is just a corrected curve based on your fuel targets.
 Old 01-18-2014, 09:40 AM   #21
ms6mil's Avatar
Groans: 307
Took some logs last night. I don't know what to make of this load I'm hitting now. Assuming its due to the maf cal being a bit off, and its relation to calculating load?
What I don't understand is, I did the tips suggested by @Lex; for the 2.5 load issue, why is it still happening? I've haven't seen an issue like this until this past August, when I started seeing the random spikes in AFR's @ 2.5 load
In reference to the MAF cal, I had been using Lex's MAF calibrations for bigger intakes for the HTP 3.5" so I'm curious as to the remarkable difference in the curve between the two. Historically I haven't had to make too many changes after loading the HTP scale from that thread, attaching a side by side to view the difference in in g/s in relation to the maf voltage.
I'm probably just geeking out over this, but would like to find the source of my problem.
I appreciate any insight on this from you pro's.
PTE5862 - TBD
rfinkle2 (01-18-2014)
 Old 01-18-2014, 11:28 AM   #22
Correct, but now the afr's are correct (or @ least closer).
Multiplying the stage 0 fuel curve to get a base maf curve is absolutely a good starting point, but the base maf curve is almost a perfect 3rd order polynomial.
In the real world, maf curves are not perfect in shape due to hardware configuration and a million and 1 variables.
Any time you change the maf curve, you will see a change in calculated load... In this instance, your load was short a few 10ths because your maf cal was a touch off..
Speculation on my part, but the latest version of ATR (as atvfreek mentioned) must be less forgiving in terms of phantom open loop trimming.
One thing of note:
If you correct the maf curve using a 3rd or 4th order curve, there is a chance you will run into a portion that curves back on itself, so you will want to make sure that your corrected curve makes sense in terms of flow before flashing.
Agent_Orange (01-18-2014), chaser27 (01-18-2014), ms3blackmica (01-20-2014), ms6mil (01-18-2014)
 Old 01-18-2014, 11:35 AM   #23
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
ms6mil (01-18-2014)
 Old 01-18-2014, 11:35 AM   #24
Mono!
ms6mil (01-18-2014)
 Old 01-18-2014, 11:54 AM   #25
ms6mil's Avatar
Groans: 307
One thing of note:
Got it! thanks again, gonna make some adjustments now and go grab some more logs.
PTE5862 - TBD
 Old 01-18-2014, 12:17 PM   #26
chaser27's Avatar
Posts: 1,276   (View Stats)
Groans: 42
I'm curious to see what will happen if you don't hit 2.5 loads after adjusting your MAF curve to correct the issue.
Coming at ya with all 297/359
ECU: self-tuned
RADAR: Passport Escort 9500ci
The Following User Says Thank You to chaser27 For This Useful Post:
ms6mil (01-18-2014)
 Old 01-18-2014, 03:32 PM   #27
ms6mil's Avatar
Groans: 307
Update: Went out and logged after corrections to the MAF.... AFR's are much better. Load is now reaching.... well you'll see.
I had @leeroy38; in the car so he can see these loads I was hitting.
So at this point my load and g/s are more than I have ever seen. Until I understand what is going on I'm gonna load limit the car to under 2.5 and read some more. Once again I appreciate the help so far..
Gonna go do some more logs. had to lay low for a bit. cops almost had me earlier
PTE5862 - TBD
 Old 01-18-2014, 03:45 PM   #28
My $ says they will be dead on.
Agent_Orange (01-18-2014), chaser27 (01-18-2014), ms6mil (01-18-2014)
 Old 01-18-2014, 04:01 PM   #29
chaser27's Avatar
Groans: 42
I wasn't doubting you Haha that's why you're a tuner and I'm not. I'm trying to figure out how all this shit works
Sent from the lead
ECU: self-tuned
The Following 3 Users Say Thank You to chaser27 For This Useful Post:
Agent_Orange (01-18-2014), ms6mil (01-18-2014), rfinkle2 (01-18-2014)
 Old 01-18-2014, 04:03 PM   #30
Groans: 665
Fly by night tuning! FTW!
rfinkle2 and ms3blackmica like this.
The Following 3 Users Say Thank You to Agent_Orange For This Useful Post:
ms3blackmica (01-20-2014), ms6mil (01-18-2014), rfinkle2 (01-18-2014)
 Old 01-18-2014, 05:01 PM   #31
Sent from the lead
I absolutely didn't mean to discourage you in any way.
To adjust open loop fueling, (all fueling after the ecu has passed what closed loop max load you choose), you use: air fuel ratio logged / desired air fuel ratio.
To create an maf curve for a larger diameter maf housing, you multiply the area of the maf sensor housing by the % difference over the stock diameter.
Because the stock diameter maf curve that is often multiplied against is not always the shape of the maf curve that your car follows, the shape of the curve needs to be changed to hit fueling targets.
If you look @ many of the areas of the OTS curve posted above, and the curve that was a bit closer to targets, you'll see some areas are actually very similar in terms of voltage per grams/ second.
Not bad for a fly by night, non-engineer tuner huh?
Agent_Orange likes this.
Agent_Orange (01-18-2014), ms6mil (01-20-2014)
 Old 01-18-2014, 05:10 PM   #32
chaser27's Avatar
Groans: 42
None offense taken. I have my OL MAF curve dialed in. It just acted really weird when I hit 2.5 load this morning. Maybe it's a gen pu thing? Idk. I posted another log after it warmed up outside in the other thread.
Sent from the lead
ECU: self-tuned
The Following 2 Users Say Thank You to chaser27 For This Useful Post:
ms6mil (01-20-2014), rfinkle2 (01-18-2014)
 Old 01-18-2014, 05:30 PM   #33
ms6mil's Avatar
Groans: 307
Sent from the lead
I don't think its just a genpu thing. Back in August I was, or so I thought, pretty much dialed in as well. (except to the one lean log) if you look at the beginning of the thread you can see the car was running great, never seeing a load above 2.5.
Then I deployed came back in the Winter. ran the same map, and because of the cooler temps started seeing higher loads. +2.5 loads brought on the erattic AFR's. Some seem to be seeing AFR's go rich, others, myself included are seeing them go lean. This was an anomaly that I'm sure could be explained eventually, but seems to be under control now. (thanks to @rfinkle2
PTE5862 - TBD
The Following 3 Users Say Thank You to ms6mil For This Useful Post:
Agent_Orange (01-18-2014), chaser27 (01-18-2014), rfinkle2 (01-18-2014)
 Old 01-18-2014, 05:39 PM   #34
chaser27's Avatar
Groans: 42
Then I deployed came back in the Winter. ran the same map, and because of the cooler temps started seeing higher loads. +2.5 loads brought on the erattic AFR's. Some seem to be seeing AFR's go rich, others, myself included are seeing them go lean. This was an anomaly that I'm sure could be explained, but seems to be under control now. (thanks to @rfinkle2
But what did you end up doing Rob? You recalibrated that spot in your MAF curve using the log where you hit 2.5+? I did another log today. Hit 2.42 or so and everything looked great.
Sent from the lead
ECU: self-tuned
 Old 01-18-2014, 05:57 PM   #35
Sent from the lead
I think the general consensus is that in past versions of ATR, there was a phantom open loop trim that must've had the ability to correct the fuel curve by a larger %.
Some guys seem to have trouble @ 2.3 load, some 2.5, We'll figure it out in time.
This is just my opinion, but if correcting the maf curve works, that is what we have available to us @ this moment... until we can get Cobb to confirm that there was a change made or reveal something about the trims that we don't currently know about.
@chaser27; I edited the the entire open loop fuel curve using excel.
The Following 6 Users Say Thank You to rfinkle2 For This Useful Post:
Agent_Orange (01-19-2014), atvfreek (01-18-2014), chaser27 (01-18-2014), ms3blackmica (01-19-2014), ms6mil (01-18-2014), TiGraySpeed6 (01-18-2014)
 Old 01-18-2014, 07:56 PM   #36
atvfreek's Avatar
I've got both cars situated that were going lean. It definitely has to do with OL trims saying FU over 2.5 load (could vary from car to car) Although the maf cal appears to be perfect due to Afr being spot on below 2.4 load. It could in fact be off by a few percent. One car was only off by 3% but that is the difference between 11.8 and 12.2.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 6 Users Say Thank You to atvfreek For This Useful Post:
Agent_Orange (01-19-2014), chaser27 (01-18-2014), ms3blackmica (01-19-2014), ms6mil (01-18-2014), rfinkle2 (01-18-2014), TiGraySpeed6 (01-18-2014)
 Old 01-18-2014, 08:05 PM   #37
ms6mil's Avatar
Groans: 307
Sent from the lead
Ha both Robs, yeah... pretty much what he said, I took his re-calibrated curve and made some normal WOT adjustments now AFR's are within limits. I'm gonna be posting up some more logs in the morning. Along with screenshots of LEC, &TRL X tables and anything else relevent. Thanks again Rob.
PTE5862 - TBD
atvfreek (01-18-2014), chaser27 (01-18-2014), rfinkle2 (01-19-2014)
 Old 01-19-2014, 02:22 PM   #38
chaser27's Avatar
Groans: 42
So just a little update. I corrected my MAF curve using the log where I went really rich and acted like there was a phantom OL fuel trim that disappears at 2.5 load. Dropping it to ~87% of where it was. (~10/11.4) Smoothed everything out and drove around for 50 miles or so to make sure my LTFT's were still in check before taking a 4th gear log.
AFR's were spot on just like @rfinkle2; said they would be
So if I'm able to move my MAF curve > 10% and AFR's stay good, I'm thinking there are definitely some OL fuel trims that we can't see working. Which to me means our current methodology for calibrating the OL MAF curve is wrong.
This won't really do anything if the ECU is trying to do the same thing.
However, you can see something peculiar about the tip-in, let-off points in the image attached. Before I scaled down my MAF curve by ~13%, during tip in the AFR's would go rich for a split second. and then when I let off they would go straight up to 29.95 or whatever.
After my adjustment, I'm seeing no real drop in AFRs on tip-in, but a moment of richness when I let off. This is leading me to believe that I've over corrected my MAF curve. I'm going to try scaling it back up a little and see if this is fixed.
Again, I'm the farthest from an expert on this subject so @Lex; @rfinkle2; @atvfreek; @superskaterxes; @phate; ,etc. feel free to offer your opinion.
ECU: self-tuned
ms6mil (01-19-2014), phate (01-19-2014)
 Old 01-19-2014, 02:24 PM   #39
chaser27's Avatar
Groans: 42
forgot to add this
ECU: self-tuned
ms6mil (01-19-2014)
 Old 01-25-2014, 12:02 PM   #40
@ms6mil;
It may be true that the OL fuel trims that we can't see are saying FU and going to 0 above 2.50 ... or that an altogether different fueling strategy is being used. We can assume the MAF curve is off in the upper RPM and we are scaling it to the correct values or the ECU is using a different set of targets and (like in the old days of using a piggyback) we are scaling the MAF curve to get the desired AFRs although they are not the actual targets.
We certainly don't know what exactly is going on since we don't have the visibility of all tables or the logic.
The strange "s" shape to the MAF curve is not representative of actual flow. Actually the fact that we have to add 8-10% to the MAF only in the upper ranges and LTFTs stay close to 0 in the lower ranges are a stronger indication that different fuel targets are used in the upper RPMs. Further the actual power numbers and fuel consumption we are seeing are not lining up with the "inflated" MAF values. In light of this, instead of having the s shaped MAF curve, I would scale the entire thing by the 8-10% needed in the high load area. The higher you go up the MAF curve the more likely you are to be above 2.50 load so there is no reason to flatten it out in the top end.
ms6mil (01-25-2014)
Random P0171 Code: System Too Lean (Bank 1) infeKteDx 2010 MS3 - Engine, Transmission & Driveline 91 09-28-2018 03:18 PM
Lean at WOT Jettster91 Mazdaspeed3/6 General Discussion 14 04-30-2013 03:51 AM
why am i so lean. massiespeed3 MazdaSpeed 3 - Engine, Transmission & Driveline 13 06-26-2010 02:53 PM
Dealers got lean; many plan to stay lean Haltech Automotive News 0 05-30-2010 10:10 PM
Lean at tip in... Jarods7920
Cobb ATR Support
11 09-01-2009 01:19 PM
Page generated in 0.63503 seconds with 29 queries
