Like Tree11Likes
 Old 07-16-2012, 11:11 PM   #41
Alpha's Avatar
Posts: 3,711   (View Stats)
Sumbish... I think my goals just went from 420 AWHP to 520 AWHP.
DJ FTW!!!
PS - F&*K meth.
The Following 3 Users Say Thank You to Alpha For This Useful Post:
djuosnteisn (07-17-2012), doubleflusher (07-17-2012), SarcasticOne (07-17-2012)
 Old 07-17-2012, 09:11 AM   #42
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
When your built... there's no reason not to now.
Clean install Chris.
Has anyone else installed? I've failed at the tuning video so far... but will seriously make it happen soon. It's very straight forward... and only one way of approaching it. I'm sure once more people start running this kit, alternative approaches will pop up (namely you ziggo, haha).
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
Alpha (07-17-2012), bcmurphy87 (07-17-2012), doubleflusher (07-17-2012)
 Old 07-17-2012, 09:30 AM   #43
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
I'm still working on getting that damn lid off. My tranny mount fiasco set me back a couple of days for getting that tool. I have to order it since no one carries it
The Following User Says Thank You to TWOptSL0W For This Useful Post:
 Old 07-17-2012, 09:32 AM   #44
Captain
Have chris send you the SST. He's done at this point.
And crazy no autozone has that tool..... oh well.
www.permtuning.com
 Old 07-17-2012, 09:37 AM   #45
TWOptSL0W's Avatar
Groans: 125
Whats Chris's name?
 Old 07-17-2012, 09:44 AM   #46
Captain
bcmurphy.
www.permtuning.com
 Old 07-17-2012, 10:15 AM   #47
Ziggo's Avatar
Posts: 3,843   (View Stats)
My approach was supposed to be even more simple.
The real baller setup is going to be a PI setup like pablo.
Zigatapatalka
Ask Me About My:
 Old 07-17-2012, 10:23 AM   #48
Captain
Zigatapatalka
I still have my doubts on how well a PI setup will perform with this controller... since this controller is predominantly batch fire. The 4 inj version has 2 fuel maps, and i think it fires the inj's in pairs i think... so you can probably help minimize the phase difference between cylinders by using map A injs for cylinders 1 & 3, and map B for 4 & 2... or something like that. But even then, it'd be difficult to correlate which pulse is from which cylinder... in order to prevent spraying a closed valve.
The fifth port seems to be working pretty good IMO. And it's much less complicated.
www.permtuning.com
bcmurphy87 (07-19-2012), doubleflusher (07-17-2012), Ziggo (07-17-2012)
 Old 07-17-2012, 10:38 AM   #49
Ziggo's Avatar
I never heard that spraying on a closed valve was bad for power except for here. From my learnin' it is a fuel efficiency/emissions concern. Spraying only when the valve is open helps mixing and atomization when flow rates are low like idle and low throttle, neither of which we care about here.
Consider this: PI setups are routinely run to 80-90% duty cycle, and are only not run higher due to concerns over damaging the injectors.
The intake valves are open for ~220* out of 720* so if you were to only spray on open valves you wouldn't run your duty cycle above ~30%, if you run to 90% 2/3 of your fuel is being sprayed on a closed valve.
Food for thought.
Zigatapatalka
Ask Me About My:
The Following 8 Users Say Thank You to Ziggo For This Useful Post:
Dano (07-17-2012), djuosnteisn (07-17-2012), doubleflusher (07-17-2012), InFeXIoN (07-22-2012), Micha (05-31-2014), phate (12-23-2012), pzr2874 (07-19-2012), uncorked11 (09-04-2012)
 Old 07-17-2012, 11:16 AM   #50
Captain
I have considered that. My only concern is that some cylinders will be sprayed with an open valve, while others are sprayed with a closed valve... and 2 in between.
I just don't have any solid feel on what kind of cylinder to cylinder variation it would introduce.
www.permtuning.com
 Old 07-17-2012, 11:34 AM   #51
J-Liss's Avatar
Posts: 1,949   (View Stats)
J-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the world
Groans: 81
Groaned at 30 Times in 25 Posts
1,0000000 says PTP steals the idea, PATENT THIS BEYOTCH
2004 mazda 3-Daily
2008 mazda 6-Wife
2008.5 Mazdaspeed 3 totaled
1983- FB Rx-7 Soon to be boosted Carb epicness
Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler
J-Liss is offline   Reply With Quote
The Following 3 Users Say Thank You to J-Liss For This Useful Post:
bcmurphy87 (07-17-2012), djuosnteisn (07-17-2012), Easter Bunny (07-17-2012)
 Old 07-17-2012, 11:37 AM   #52
Ziggo's Avatar
Ford already has a patent on using PI in tandem with DI for high load fueling. I looked into it ~2 years ago.
Zigatapatalka
Ask Me About My:
djuosnteisn (07-17-2012), J-Liss (07-17-2012)
 Old 07-17-2012, 11:38 AM   #53
Ziggo's Avatar
Would have to re-read to see if they made it general enough to cover TBI.
Zigatapatalka
Ask Me About My:
 Old 07-17-2012, 11:39 AM   #54
J-Liss's Avatar
Groans: 81
^ so nice he posted it twice.
cant he patent his design though? but i guess it would be pointless since it would need to be identical to even stir trouble.
2004 mazda 3-Daily
2008 mazda 6-Wife
The Following User Says Thank You to J-Liss For This Useful Post:
 Old 07-17-2012, 11:44 AM   #55
Ziggo's Avatar
This wouldn't slow me down in the least, but with the TBI up and running I probably won't be messing with PI till 2014 at the earliest. Too many Miatas running around with batch injection for it to bother me.
Zigatapatalka
Ask Me About My:
 Old 07-17-2012, 11:51 AM   #56
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
Zigatapatalka
I believe Toyota also used both PI and DI.
 Old 07-17-2012, 12:02 PM   #57
are the valves for any particular cylinder closed for long enough to really matter? since this setup is only for high rpm, how much fuel would really be sprayed into the runner while the valve is closed?
 Old 07-17-2012, 12:08 PM   #58
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Toyota/Lexus has been on this for a while now with the IS and GS 350's 2GR-FSE engine
Quote from an engine of the year award thingy-
Regarding the Best New Technology winner, the Lexus IS 350 is powered by a 306-hp, 3.5-litre, 24-valve, dual overhead cam V6 engine that features a unique fuel injection system. This system combines direct fuel injection - delivering fuel to the combustion chamber - and port fuel injection - delivering fuel to the intake ports. Fuel distribution is controlled via the two types of injection according to driving conditions:
When the engine is running under low or medium loads at lower speeds, both systems are used to create a homogeneous air-fuel mixture. This stabilizes combustion, improves fuel efficiency, and reduces exhaust emissions. When the engine is running under heavy load, it automatically converts to a direct injection-only system. By controlling the timing and duration of fuel being injected directly to the combustion chamber, the combustion efficiency of each charge is maximized. It also allows the engine to operate at a higher compression ratio, thereby improving engine output and performance, by reducing the tendency of the compressed mixture to ignite prematurely.
White paper with more than you'd likely want to know....
-darn link keeps wanting to imbed the white paper, not just give me a link....
Code:
http://www.scribd.com/doc/75062860/Toyota-2GR-FSE-GDI-PFI-Engine-Paper
340hp / 371tq
 Old 07-17-2012, 01:41 PM   #59
bcmurphy87's Avatar
Posts: 1,435   (View Stats)
Whats Chris's name?
hit me with a pm and you will have it sir
06 Speed6 GT- Sold
The Following 2 Users Say Thank You to bcmurphy87 For This Useful Post:
djuosnteisn (07-17-2012), TWOptSL0W (07-17-2012)
 Old 07-17-2012, 01:57 PM   #60
Captain
Psssshhh... those clowns got it backwards. Supposed to say "PI engaged when pushing the DI well beyond it's design intentions".
Seriously though, it's funny that they use DI only during high load.
www.permtuning.com
Easter Bunny (07-17-2012), Ziggo (07-17-2012)
 Old 07-17-2012, 03:24 PM   #61
TWOptSL0W's Avatar
Groans: 125
thanks, but i got that kit from autozone and the cap came off right away...pumps are swapped
The Following 2 Users Say Thank You to TWOptSL0W For This Useful Post:
 Old 07-17-2012, 03:57 PM   #62
J-Liss's Avatar
Groans: 81
^ explain yourself sir
2004 mazda 3-Daily
2008 mazda 6-Wife
 Old 07-17-2012, 04:05 PM   #63
TWOptSL0W's Avatar
Groans: 125
Went and just gave the auto-zone rental a try and it got it out after a fresh coat of penetrating oil. The core charge was 90 but you get it back when you return it. Also came with a bronze punch and sand filled hammer that I'm sure help to loosen it up.
Attachment 66937
Attachment 66938
this kit got the cap right off
the kit from autozone that chris got
Last edited by TWOptSL0W; 07-17-2012 at 04:05 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-18-2012, 12:22 AM   #64
bcmurphy87's Avatar
so who needs the sst tool now lol
06 Speed6 GT- Sold
The Following User Says Thank You to bcmurphy87 For This Useful Post:
djuosnteisn (07-18-2012)
 Old 07-18-2012, 08:10 AM   #65
Captain
Me i guess, hahaha. I have a local who's waiting on a filter sock and then needs to swap itfp's.
It's nice to know the vatozone unit works well.
www.permtuning.com
 Old 07-18-2012, 06:36 PM   #66
TWOptSL0W's Avatar
Groans: 125
dont forget to make yourself a new cap for the big hole you cut under the rear seat
and mark it with something sharp
The Following 6 Users Say Thank You to TWOptSL0W For This Useful Post:
Dano (07-19-2012), djuosnteisn (07-19-2012), Micha (05-31-2014), NJSPEED3 (10-12-2012), PapaSmurf (07-19-2012), Realgib3 (07-18-2012)
 Old 07-19-2012, 12:48 PM   #67
bcmurphy87's Avatar
i got lucky i cut slits bent it back, removed and bent metal back into place. added weather stripping over cuts and sealed back up lol
06 Speed6 GT- Sold
 Old 07-19-2012, 01:18 PM   #68
Captain
You have to remove WAY more material on the 3's than the 6's. The 6's are just a hair too small. The 3's pretty much just have a hole to access the line and connector.
www.permtuning.com
bcmurphy87 (07-19-2012), Dano (07-19-2012)
 Old 07-19-2012, 01:27 PM   #69
Trail of Fail
Dano's Avatar
or like this?
I need some art work
bcmurphy87 (07-19-2012), djuosnteisn (07-19-2012), NJSPEED3 (11-15-2012), TWOptSL0W (07-19-2012)
 Old 07-19-2012, 03:50 PM   #70
TWOptSL0W's Avatar
Groans: 125
or like this?
nah mines better <3
 Old 07-19-2012, 04:02 PM   #71
Trail of Fail
Dano's Avatar
nah mines better <3
because Nator NY graphic ? lol
I'll give you that.
 Old 07-19-2012, 04:09 PM   #72
Captain
Mine's just the old cover bolted back down, with a rag stuffed under it, hahahahahaha.
www.permtuning.com
bcmurphy87 (07-19-2012), Dano (07-19-2012), Easter Bunny (07-21-2012), TWOptSL0W (07-19-2012)
 Old 07-19-2012, 04:11 PM   #73
Trail of Fail
Dano's Avatar
a la' molotov cocktail style....nice!
djuosnteisn (07-19-2012), doubleflusher (07-23-2012), PapaSmurf (07-19-2012), TWOptSL0W (07-19-2012)
 Old 07-19-2012, 05:23 PM   #74
TWOptSL0W's Avatar
Groans: 125
I'll give you that.
no because Nator NJ lol
bahahahahahaha
Last edited by TWOptSL0W; 07-19-2012 at 05:23 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-19-2012, 05:29 PM   #75
Trail of Fail
Dano's Avatar
oopps...sorry about the "Y" my bad!
we all know Nator NJ is waaaaay better than Nator NY. Hell you guys will be the first into the 10s...
bwahhhhhhhhh
djuosnteisn (07-19-2012), TWOptSL0W (07-19-2012)
 Old 07-19-2012, 05:56 PM   #76
pzr2874's Avatar
Posts: 6,778   (View Stats)
Groans: 146
But wouldn't that just go back and forth ? 1-3/2-4 ?
The Following User Says Thank You to pzr2874 For This Useful Post:
djuosnteisn (07-20-2012)
 Old 07-20-2012, 10:41 AM   #77
Captain
Largely depends on how the SS controller is setup. In 4 stroke 4 cylinder mode, it fires every other trigger pulse, so once per crank rotation, or every other intake stroke. In 2 stroke 2 cylinder mode, it fires every trigger pulse, so twice per crank rotation, or once per intake stroke.... in which case i guess things would balance out just fine. 1 squirt per cycle means all cylinders receive equal "squirting", lol.
www.permtuning.com
pzr2874 (07-20-2012)
 Old 07-20-2012, 12:28 PM   #78
so whos gona be first to install this?
 Old 07-20-2012, 12:49 PM   #79
TWOptSL0W's Avatar
Groans: 125
as soon as my serial cable comes in, i can finish the install. aside from the pump, everything else should take about an hour
DJ, does the injector boss have to be parallel with the ground with the injectors spraying down? Can it be sideways or not exactly straight? im concerned about the fitment a bit
 Old 07-20-2012, 12:58 PM   #80
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
Because racecar
The Following User Says Thank You to forcedinduktion For This Useful Post:
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/rough-install-guide-5th-port-injection-kits-118264/
I have some turbo cores on their way! | SHO Forum This thread Refback 11-02-2015 04:56 PM
Because everyone in here is going to secretly watch F&F6 :D TURBLO*chat* - Page 59 - Club RSX Message Board This thread Refback 06-15-2013 06:55 AM
I have some turbo cores on their way! - SHOForum This thread Refback 11-20-2012 08:50 PM
Port Injection for 2012 Realgib3 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 29 12-19-2011 03:11 PM
Port Injection Question 6-Speed-6 MazdaSpeed 3 - Engine, Transmission & Driveline 9 07-16-2009 08:02 PM
port injection head cbspeed3 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 54 06-28-2009 10:39 AM
New kits with new parts from devilsown injection DevilsOwn MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 30 04-06-2009 11:50 PM
Page generated in 0.60368 seconds with 32 queries
