 Old 05-21-2013, 11:44 AM   #1
snailD's Avatar
Posts: 3,039   (View Stats)
Default SnailD's Throttle Table Fix
So i actually did this a while ago, but have since put them on several cars and everyone has loved the difference in throttle response. These tables have been refined too many times to count at this point. Basically my goal was to get a more linear feel like a DBC setup without the dead spot in the middle of the pedal. Feel free to copy and paste these tables into your map, or not. I figured i'd post them up for those that disliked the stock and cobb tables too. THESE ARE DEFINITELY A BIT MORE AGGRESSIVE
DBW TABLE A,B,C
Code:
0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00
1.50	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	2.00	2.00
1.70	1.50	1.50	1.50	1.80	2.00	2.00	2.00	2.00	2.00	2.00	2.00	2.00	3.50	3.50
1.90	2.50	2.60	2.60	2.90	3.30	3.00	2.60	3.00	3.00	3.00	4.00	4.00	5.00	5.00
2.10	3.50	4.40	4.40	4.60	4.90	4.60	4.50	3.90	4.50	4.50	5.50	6.00	7.00	7.00
2.30	4.00	5.00	5.70	6.10	6.50	6.40	6.20	6.00	6.70	7.00	7.00	7.60	8.10	8.10
3.50	5.50	6.50	7.30	6.80	8.20	7.80	7.60	7.60	8.20	8.40	8.90	9.90	9.60	9.60
7.00	7.00	7.00	7.00	10.40	10.40	10.40	10.40	10.40	10.40	10.40	10.40	10.40	10.40	10.40
9.00	9.00	9.00	9.00	11.00	12.00	12.00	12.00	12.00	12.00	12.00	12.00	12.00	12.00	12.00
11.00	11.00	11.00	11.00	12.00	14.00	13.00	13.00	13.00	13.00	13.00	13.00	13.00	13.00	13.00
12.00	13.00	13.00	13.00	13.00	16.00	16.00	16.00	16.00	16.00	16.00	16.00	16.00	16.00	16.00
15.00	15.00	15.00	15.00	16.00	17.00	18.00	18.00	18.00	18.00	18.00	18.00	18.00	18.00	18.00
16.83	17.50	16.83	17.50	17.83	21.50	19.83	20.50	19.83	20.50	19.83	20.50	19.83	20.50	19.83
19.68	20.46	19.68	20.46	20.68	22.46	21.68	22.46	21.68	22.46	21.68	22.46	21.68	22.46	21.68
21.79	22.67	22.12	23.00	22.62	26.92	26.21	26.92	26.21	26.92	26.21	26.92	26.21	26.92	25.26
26.90	27.88	27.57	28.55	28.57	30.38	29.73	30.38	29.73	30.38	29.73	30.38	29.73	30.38	28.14
32.01	33.09	33.01	34.09	34.51	36.84	36.26	36.84	36.26	36.84	36.26	36.84	36.26	36.84	34.01
37.12	38.31	38.45	39.64	40.45	43.31	42.79	43.31	42.79	43.31	42.79	43.31	42.79	43.31	39.89
42.23	43.52	43.90	45.18	46.40	49.77	49.31	49.77	49.31	49.77	49.31	49.77	49.31	49.77	45.76
47.34	48.73	49.34	50.73	52.34	56.23	55.84	56.23	55.84	56.23	55.84	56.23	55.84	56.23	51.64
52.45	53.94	54.78	56.28	58.28	62.69	62.37	62.69	62.37	62.69	62.37	62.69	62.37	62.69	57.51
57.56	59.15	60.23	61.82	64.23	69.15	68.89	69.15	68.89	69.15	68.89	69.15	68.89	69.15	63.39
62.67	64.36	65.67	67.36	70.17	75.61	75.42	75.61	75.42	75.61	75.42	75.61	75.42	75.61	69.26
67.78	69.58	71.11	72.91	76.11	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	75.14
72.89	74.79	76.56	78.46	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00
78.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00
GEN 2 1st Gear APP
Code:
0.00	1.69	2.25	4.12	6.77	10.95	14.37	17.40	19.85	24.75	29.65	34.55	40.00	45.00	50.00	60.00	70.00	80.00	90.00	100.00
GEN 1 1st Gear APP
Code:
0.00	1.72	2.08	2.77	4.30	6.77	10.45	13.15	15.55	17.66	19.78	21.89	24.00	26.00	28.00	30.00	35.00	40.00	45.00	50.00	55.00	60.00	65.00	70.00	75.00	80.00	85.00	87.50	90.00	95.00	100.00
SPEED 6 1st Gear APP
Code:
0.00	1.72	2.08	2.77	4.30	6.77	10.45	13.15	15.55	17.66	19.78	21.89	24.00	26.00	28.00	30.00	35.00	40.00	45.00	50.00	55.00	60.00	65.00	70.00	75.00	80.00	82.50	85.00	90.00	95.00	100.00
Gen 2 APP 2-6
Code:
0.00	2.50	5.00	7.50	10.00	12.50	15.00	17.50	20.00	25.00	30.00	35.00	40.00	45.00	50.00	60.00	70.00	80.00	90.00	100.00
Gen 1 APP 2-6
Code:
0.00	2.00	4.00	6.00	8.00	10.00	12.00	14.00	16.00	18.00	20.00	22.00	24.00	26.00	28.00	30.00	35.00	40.00	45.00	50.00	55.00	60.00	65.00	70.00	75.00	80.00	85.00	87.50	90.00	95.00	100.00
Speed 6 APP 2-6
Code:
0.00	2.00	4.00	6.00	8.00	10.00	12.00	14.00	16.00	18.00	20.00	22.00	24.00	26.00	28.00	30.00	35.00	40.00	45.00	50.00	55.00	60.00	65.00	70.00	75.00	80.00	82.50	85.00	90.00	95.00	100.00
LESS AGGRESSIVE TABLE
Here is a table i did for someone looking for a similar feel to stock, without the dead spot in the pedal. Much better for auto-x and racing, VERY smooth and linear throttle feel.
I only have the gen 2 APP done up but here it is. i'll update the OP when i make the others.
DBW A,B, and C.
Code:
1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00
1.50	1.50	1.50	1.50	1.63	1.75	2.00	2.00	2.00	2.00	2.00	2.00	2.00	2.00	2.00
2.34	2.34	2.34	2.34	2.47	2.60	2.60	2.60	2.60	2.60	2.60	2.60	2.60	2.60	2.60
3.96	3.96	3.96	3.96	4.08	4.20	4.00	4.00	4.00	4.00	4.00	4.00	4.00	4.00	4.00
4.50	4.50	4.50	4.50	4.80	5.10	5.20	5.20	5.20	5.20	5.20	5.20	5.20	5.20	5.20
5.85	5.85	5.85	5.85	6.26	6.67	6.84	6.84	6.84	6.84	6.84	6.84	6.84	6.84	6.84
6.30	6.30	6.30	6.30	6.97	7.64	8.28	8.28	8.28	8.28	8.28	8.28	8.28	8.28	8.28
8.10	8.10	8.10	8.10	8.71	9.31	9.63	9.63	9.63	9.63	9.63	9.63	9.63	9.63	9.63
9.90	9.90	9.90	9.90	10.59	11.27	11.54	11.54	11.54	11.54	11.54	11.54	11.54	11.54	11.54
11.70	11.70	11.70	11.70	12.57	13.45	13.90	13.90	13.90	13.90	13.90	13.90	13.90	13.90	13.90
13.50	13.50	13.50	13.50	14.45	15.40	15.80	15.80	15.80	15.80	15.80	15.80	15.80	15.80	15.80
15.15	15.15	15.15	15.15	16.41	17.67	18.50	18.50	18.50	18.50	18.50	18.50	18.50	18.50	18.50
17.71	17.71	17.71	17.71	19.15	20.59	21.50	21.50	21.50	21.50	21.50	21.50	21.50	21.50	21.50
20.91	20.91	20.91	20.91	21.65	23.39	24.65	24.65	24.65	24.65	24.65	24.65	24.65	24.65	24.65
24.81	24.81	24.81	24.81	26.25	27.68	27.80	27.80	27.80	27.80	27.80	27.80	27.80	27.80	27.80
29.71	29.71	29.71	29.71	31.11	32.51	32.00	32.00	32.00	32.00	32.00	32.00	32.00	32.00	32.00
34.60	34.60	34.60	34.60	36.41	38.22	38.00	38.00	38.00	38.00	38.00	38.00	38.00	38.00	38.00
39.51	39.51	39.51	39.51	41.73	43.95	44.00	44.00	44.00	44.00	44.00	44.00	44.00	44.00	44.00
44.41	44.41	44.41	44.41	47.04	49.67	50.00	50.00	50.00	50.00	50.00	50.00	50.00	50.00	50.00
49.30	49.30	49.30	49.30	52.35	55.39	56.00	56.00	56.00	56.00	56.00	56.00	56.00	56.00	56.00
54.21	54.21	54.21	54.21	57.79	61.37	62.50	62.50	62.50	62.50	62.50	62.50	62.50	62.50	62.50
59.10	59.10	59.10	59.10	63.22	67.33	69.00	69.00	69.00	69.00	69.00	69.00	69.00	69.00	69.00
64.00	64.00	64.00	64.00	68.65	73.31	75.50	75.50	75.50	75.50	75.50	75.50	75.50	75.50	75.50
68.90	68.90	68.90	68.90	74.09	79.28	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00
73.80	73.80	73.80	73.80	75.49	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00
73.80	73.80	73.80	73.80	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00
Gen 2 APP
Code:
0.00	1.70	2.70	4.75	7.50	10.50	13.55	16.39	19.26	25.00	30.00	35.00	40.00	45.00	50.00	60.00	70.00	80.00	90.00	100.00
snailD is offline
The Following 4 Users Say Thank You to snailD For This Useful Post:
Caldazar (09-26-2015), flylike2kites (03-12-2016), Micha (01-07-2015), The Nut (12-12-2014)
SnailD's High Altitude OTS Maps snailD 2010 MS3 - ECU Computer Tuning 123 08-27-2019 09:43 PM
SnailD's Throttle Table Fix snailD 2010 MS3 - ECU Computer Tuning 250 11-16-2017 02:09 PM
Snaild on corn snailD 2010 MS3 - Dyno Sheets/Discussions 13 11-23-2012 10:58 PM
Page generated in 0.65761 seconds with 43 queries
