Closed Thread
 Old 03-13-2014, 04:58 AM   #161
pfp22972's Avatar
Posts: 820   (View Stats)
pfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the worldpfp22972 is the leader of the world
@snailD - No worries at all, good sir. APP changes can make a noticeable difference. The APP differences between your two sets were significant enough to make the two choices feel different even if the DBW tables were similar so I didn't really examine the two tables very closely. I still preferred the aggressive set and just started working with the APP tables to tone it down to my liking.
I do have one question, however. Bucker's ATR guide suggests changing all the 80 values in the DBW tables to 90. Have you tried that on these tables? I haven't tried that yet but I may this weekend. My car runs so well with your current DBW tables that I am hesitant to alter them.
BTW...I went to the Austin F1 race last year. It was so amazing! I will have to upload some of my videos. I so want to get my car on that track! I have had my car on Texas Motor Speedway, but only for charity and everyone had to stay below 30. I did do a ride along out there a few years ago. 170 around the turns there is a very weird sensation!
@El Beaner - Ah...XDA Developers! I used to spend so much time on that site back in the early Windows Mobile days.
Thanks again @snailD for all your work. If you do ever make it to DFW, I'll meet up with your and El Beaner.
2010 Celestial Blue Speed 3
- FREEKTUNED -
Cobb AP v2 - UR test pipe w/ resonator - UR CBE - CS BPV - CS TMIC
CS shifter bushings - CS RMM - CS TMM insert - CS brake pads - CS LED kit - Autotech Internals
JBR Tru 3" WP intake - JBR FSB and RSB - JBR IM+TB TIGs & TB Bypass - JBR boost tubes - JBR EGR Delete
Cobb springs - Koni Yellows - Centric high carbon rotors - Drag DR38 47+ wheels - Continental DW's
pfp22972 is offline
 Old 03-13-2014, 06:28 AM   #162
jrotaryb's Avatar
Posts: 416   (View Stats)
Let us know what you think.
This may be a stupid question, but I'll ask anyway - better safe than sorry!
I should still be able to use these tables without incident if my tuner is limiting the throttle plate in a few areas to control load, right? I don't want to screw up his map...
Thanks!
pedal2plastic.wordpress.com
The driving game blog
Cobb: AP, SRI & RMM
Corksport: TIP, TMIC, RP,SSP
Autotech Internals
Bilstein PSS Coilovers
SPC Rear Camber Arms
JBR RSB
Gram Lights 57F - 18x8.5 +45
Rfinkle2 tuned @21psi
jrotaryb is offline
 Old 03-13-2014, 06:44 AM   #163
pfp22972's Avatar
Thanks!
If Rfinkle is your tuner, as your signature suggests, he is one of the most knowledgeable people in this forum and should be able to answer that question.
I really like how my throttle behaves with the agressive DBW table, along with my own APP table. When I finally get an e-tune, I will be asking my tuner to incorporate these settings.
- FREEKTUNED -
pfp22972 is offline
 Old 03-13-2014, 07:12 AM   #164
El Beaner's Avatar
Posts: 4,262   (View Stats)
Wow, what a difference the new DBW tables made. From a stop to get going in first is much easier now and doesn't feel like it wants to take off on me. Much easier to control. Power is there in all the gears when you command it but no where near as soon as the aggressive tables.
I updated the Stage 1 OTS map along with the Stage 1 CS sri+tih map. Have 4 of each
SnailD relaxed
SnailD relaxed + pfp's APP
SnailD Aggressive
SnailD Aggressive + pfp's APP
Right now driving with Snails relaxed(post thread update) and and so far it is my favorite of all the iterations I've done(pre update).
So in regards to APP settings, the lower the figure the more you have to press to get it to respond, is that correct? Or is it the opposite - the lower the figure the less you have to press?
SOLD 2012 LSM Tech - 11/17/17
El Beaner is offline
 Old 03-13-2014, 07:23 AM   #165
pfp22972's Avatar
SnailD relaxed
SnailD Aggressive
I looked at my excel sheet. I copied snailD's relaxed APP table and multiplied it by .09, reducing the values throughout the range. This made my APP table more sensitive than his relaxed set, but not as hyper as his aggressive set. So, in my mind, reducing the values across the board would give quicker pedal response. Increasing the values would require more pedal pressure to acheive the same responses.
- FREEKTUNED -
pfp22972 is offline
 Old 03-13-2014, 08:30 AM   #166
pfp22972's Avatar
SnailD relaxed
SnailD Aggressive
I personally like the way my engine acts with the agressive DBW tables, but i do like the very light pedal application required with the agressive APP tables. The OTS and snailD's relaxed APP tables required too much pedal pressure for me .So, I left the DBW table alone and began to work solely on the APP tables.
This might make the APP tables easier to understand. If you were to make a graph using 1 - 20 (representing the 20 cells of APP values) on the Y axis, and 0 - 100 (representing the amount of pedal pressure applied) on the X axis, it would look just like the movement of the gas pedal on the car. You could, in theory, start with larger values in the first few cells and arc them toward 100 through the remainder of the cells so that your pedal requires more initial pressure to acheive the desired pedal pressure results. Or, lower initial values for more sudden pedal response. Once you are satisfied, you can load the values into your APP tables and see how it feels.
I hope this helps.
- FREEKTUNED -
pfp22972 is offline
 Old 03-13-2014, 08:38 AM   #167
swsmailman's Avatar
Posts: 1,118   (View Stats)
Ok, sweet, I think I am finally not confused and I am about to update the Map that I have with this on it.
Thanks for all the work everyone.
2013 Liquid Silver MazdaSpeed
swsmailman is offline
 Old 03-13-2014, 08:58 AM   #168
jrotaryb's Avatar
I PM'd him earlier
Cobb: AP, SRI & RMM
Autotech Internals
JBR RSB
jrotaryb is offline
 Old 03-13-2014, 09:10 AM   #169
pfp22972's Avatar
I PM'd him earlier
If you could let me know what he thinks I would appreciate it.
Sent from somewhere...but not here.
- FREEKTUNED -
pfp22972 is offline
 Old 03-13-2014, 09:22 AM   #170
jrotaryb's Avatar
Sure thing - I'm sure the poor guy has a full inbox...the price you pay for being as smart/generous of a guy as Rob is.
Cobb: AP, SRI & RMM
Autotech Internals
JBR RSB
jrotaryb is offline
 Old 03-13-2014, 09:34 AM   #171
pfp22972's Avatar
That, my friend, is a very true statement.
- FREEKTUNED -
pfp22972 is offline
 Old 03-13-2014, 10:09 AM   #172
snailD's Avatar
Posts: 3,039   (View Stats)
Thanks!
if you leave the cells in the 1.5-2.0 load region the same as your tuner has it things wont change. copy and past the whole file over into DBW A, then go into dbw B and copy 1.5-2.0 load cells and paste them into at at 1.5 load back in A. then blend them with interpolation vertical (highlight and right click). now copy that whole table and paste it into B and C
snailD is offline
 Old 03-13-2014, 08:50 PM   #173
El Beaner's Avatar
Ran a 4th gear log today using SnailD's relaxed throttle tables/APP
Can anyone tell me if they see anything wrong - I saw a little KR at the beginning and then around 5k rpm but not sure if that was attributed to the road or another issue.
 Old 03-13-2014, 09:11 PM   #174
iammike's Avatar
Posts: 1,415   (View Stats)
Color me completely confused still. I had copied all the tables, aggressive and mile, to Google Docs after Snail made the corrections awhile back.
I just went back and grabbed them again to make sure I had the correct ones. The mild tables in the OP currently did not match what I had for aggressive or mild previously. The ones in the OP at the moment, for example, have an APP table that lands in between the aggressive and the mild I had copied before.
Oh well, going to toss the new OP mild on the car tomorrow and see how it feels.
Mike
iammike is offline
 Old 03-13-2014, 09:54 PM   #175
El Beaner's Avatar
Yeah the app table he used to have in page 2 for the relaxed model was quite different from what it was before. It works great though. I enjoyed it today.
 Old 03-13-2014, 09:55 PM   #176
iammike's Avatar
Well I'll be giving it a spin tomorrow. I really enjoyed what I had from him before as the mild build. Gonna try this one though. Who knows.
Mike
iammike is offline
 Old 03-14-2014, 02:11 AM   #177
The Nut's Avatar
Posts: 1,571   (View Stats)
Noticed that too.
2012 BLACK MICA w/TECH
91 & Corn diagnostics by:
The Nut is offline
 Old 03-14-2014, 08:13 AM   #178
BAT-man's Avatar
Posts: 719   (View Stats)
BAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the world
Groaned at 29 Times in 14 Posts
I toned down the "soft" map in the first page, and it's better now, but still find myself boosting all over the place. I'm not sure what affects this phenomena more - the APP or the DWB table.... I agree with the APP being a completely linear function, more or less like a normal throttle body would be, so perhaps it's the DWB table that needs to be even more tuned down.
TBH, I'm more worried about heel-and-toeing than regular driving around, as the throttle is much harder to modulate when you're working the brakes with the same foot, and a very progressive throttle could make for a diaper-bound experience.
I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems.
"... if u can't find' em - grind 'em"
- old Chinese proverb
http://www.mazdamotorsports.com/
BAT-man is offline
 Old 03-14-2014, 08:23 AM   #179
El Beaner's Avatar
I wonder if anyone has tried just updating the APP on a stock OTS map and seeing what the difference was. Would it have much if any affect?
After looking at my 4th gear log more, I notice that my pedal poistion is 60% and I am at WOT (throttle position - 76% already) Not sure if that could pose issues. Once I get my intake, I am going to do a Freek OTS tune and hopefully it has ok throttle response.
 Old 03-14-2014, 08:40 AM   #180
pfp22972's Avatar
Have you tried smoothing out your boost target tables? This helped the way my boost hits. It still hits hard but not as violently.
First, I would suggest using snailD's relaxed DBW table. It is supposed to be similar to stock without the "wall." Second, I would take snailD's relaxed APP table, put it in excel, and multiply the entire table by 1.5, except for 0 and 100. Or, perhaps just multiply against the first 5 or 6 cell. This should result in a need for more pedal pressure to accelerate, either through the full range or just initially. You can experiment with the multiplier to get your desired feel. That's what I did.
- FREEKTUNED -
pfp22972 is offline
 Old 03-14-2014, 08:42 AM   #181
snailD's Avatar
if you like the cobb values you should just run them. i made these mostly for myself and figured i would share. these arent better than the stock/cobb values unless you like them more, its just a different throttle feel.
the app is like a percentage of the dbw. if u stopped the app at 10% the car wouldnt go anywhere because the ecu would say the pedal is only at 10% when it was really wide open. the dbw table is what is actually telling the tb what to do, the app is the direct pedal to dbw relationship
snailD is offline
 Old 03-14-2014, 08:53 AM   #182
El Beaner's Avatar
Quick question, on your relaxed DBW table, I was looking it over and the numbers are always increasing from left to right and then down except one spot.
5th row down, it goes 3.96 for columns 1-4, then 4.08, then 4.20 then back to 4.00 for columns 7-10 and then start of row 6 is 4.5
Not sure if that is intentional or something that should not be there - on your aggressive table it happens more throughout in the first 7 rows as well.
 Old 03-14-2014, 08:58 AM   #183
pfp22972's Avatar
You posted the original table so long ago. It's interesting how it a has become big topic again.
- FREEKTUNED -
pfp22972 is offline
 Old 03-14-2014, 09:03 AM   #184
El Beaner's Avatar
My fault lol - I started messing around with ATR and another DFW NATOR mentioned this thread and well, here we are.
 Old 03-14-2014, 09:10 AM   #185
pfp22972's Avatar
I think it has more to do with all the great help provided in this forum has given people more confidence it tinkering with ATR rather than relying on others.
- FREEKTUNED -
pfp22972 is offline
 Old 03-14-2014, 02:21 PM   #186
BAT-man's Avatar
Thumbs up
Oh no no, the COBB map looked like a very odd mountain range, the top of which resembled a plane crash aftermath. That stuff was whack.
I like your maps and I'm just saying I will need to adjust them a bit for my driving style. You did great work and now folks can use a great base to adapt into their maps and adjust as necessary. Many many thanks, btw.
BAT-man is offline
 Old 03-14-2014, 04:01 PM   #187
iammike's Avatar
Ok, so I do like the "new" mild APP tables a little more. Gives a little more pep right at tip in then acts just like it used to.
Mike
iammike is offline
 Old 03-14-2014, 07:01 PM   #188
BAT-man's Avatar
So, not for nothing but here is my version of snailD's "relaxed" DBW Table, a bit smoothed out:
Code:
0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00	0.00
1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00	1.00
1.50	1.50	1.50	1.50	1.50	1.75	2.00	2.00	2.00	2.00	2.00	2.00	2.00	2.00	2.00
2.25	2.25	2.25	2.25	2.50	3.00	3.00	3.00	3.00	3.00	3.00	3.00	3.00	3.00	3.00
3.25	3.25	3.25	3.25	3.50	4.00	4.00	4.00	4.00	4.00	4.00	4.00	4.00	4.00	4.00
4.50	4.50	4.50	4.50	4.75	5.25	5.25	5.25	5.25	5.25	5.25	5.25	5.25	5.25	5.25
5.75	5.75	5.75	5.75	6.25	6.75	6.75	6.75	6.75	6.75	6.75	6.75	6.75	6.75	6.75
6.75	6.75	6.75	6.75	7.25	8.25	8.25	8.25	8.25	8.25	8.25	8.25	8.25	8.25	8.25
8.25	8.25	8.25	8.25	8.75	9.75	9.75	9.75	9.75	9.75	9.75	9.75	9.75	9.75	9.75
10.00	10.00	10.00	10.00	10.50	11.50	11.50	11.50	11.50	11.50	11.50	11.50	11.50	11.50	11.50
11.50	11.50	11.50	11.50	12.50	13.00	13.00	13.00	13.00	13.00	13.00	13.00	13.00	13.00	13.00
13.50	13.50	13.50	13.50	14.50	15.00	15.00	15.00	15.00	15.00	15.00	15.00	15.00	15.00	15.00
15.50	15.50	15.50	15.50	16.00	16.75	16.75	16.75	16.75	16.75	16.75	16.75	16.75	16.75	16.75
17.50	17.50	17.50	17.50	18.00	19.00	19.00	19.00	19.00	19.00	19.00	19.00	19.00	19.00	19.00
21.00	21.00	21.00	21.00	21.50	22.50	22.50	22.50	22.50	22.50	22.50	22.50	22.50	22.50	22.50
25.00	25.00	25.00	25.00	26.25	27.00	27.00	27.00	27.00	27.00	27.00	27.00	27.00	27.00	27.00
29.50	29.50	29.50	29.50	31.00	32.00	32.00	32.00	32.00	32.00	32.00	32.00	32.00	32.00	32.00
34.50	34.50	34.50	34.50	36.00	37.00	37.00	37.00	37.00	37.00	37.00	37.00	37.00	37.00	37.00
39.50	39.50	39.50	39.50	41.00	42.00	42.00	42.00	42.00	42.00	42.00	42.00	42.00	42.00	42.00
44.50	44.50	44.50	44.50	46.00	47.50	47.50	47.50	47.50	47.50	47.50	47.50	47.50	47.50	47.50
49.50	49.50	49.50	49.50	51.50	53.00	53.00	53.00	53.00	53.00	53.00	53.00	53.00	53.00	53.00
54.50	54.50	54.50	54.50	56.50	58.50	58.50	58.50	58.50	58.50	58.50	58.50	58.50	58.50	58.50
59.00	59.00	59.00	59.00	61.50	64.00	64.00	64.00	64.00	64.00	64.00	64.00	64.00	64.00	64.00
64.00	64.00	64.00	64.00	66.50	69.00	69.00	69.00	69.00	69.00	69.00	69.00	69.00	69.00	69.00
69.00	69.00	69.00	69.00	71.00	73.00	73.00	73.00	73.00	73.00	73.00	73.00	73.00	73.00	73.00
72.50	72.50	72.50	72.50	74.50	76.00	76.00	76.00	76.00	76.00	76.00	76.00	76.00	76.00	76.00
74.00	74.00	74.00	74.00	76.00	78.00	78.00	78.00	78.00	78.00	78.00	78.00	78.00	78.00	78.00
74.00	74.00	74.00	74.00	77.00	79.00	79.00	79.00	79.00	79.00	79.00	79.00	79.00	79.00	79.00
74.00	74.00	74.00	74.00	77.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00	80.00
I left the APP tables alone for now, as I'm not exactly sure I need to change them.
I've played with the boost tables a bit of course, to make sure my WGDC isn't ramping up too quickly.
One thing I noticed was the APP Translation - Speed Comp table. For some reason, even the stock map has it set up so that it targets a multiple of the requested boost, based on speed and throttle position, up to 130% at low APP (up and down is APP, left to right is speed in mph, 0 to 49):
Code:
1.30	1.30	1.30	1.30	1.30	1.30	1.30	1.30	1.30	1.30	1.30	1.30	1.30	1.30	1.30
1.20	1.20	1.20	1.20	1.20	1.20	1.20	1.20	1.20	1.20	1.20	1.20	1.20	1.20	1.20
1.10	1.10	1.10	1.10	1.10	1.10	1.10	1.10	1.10	1.10	1.10	1.10	1.10	1.10	1.10
Does anyone know why? Was this made for spoolup?
Below is DBW table graph pic:
BAT-man is offline
 Old 03-14-2014, 07:44 PM   #189
El Beaner's Avatar
Code:
Code:
EDIT: Sorry I don't know how to post proper tables.
Fixes so people can copy and paste. All you have to do is use the word code in brackets.
 Old 03-15-2014, 02:07 PM   #190
jambisgone696's Avatar
Posts: 93   (View Stats)
jambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond reputejambisgone696 has a reputation beyond repute
@snailD loaded it in my speed6 this afternoon and love it!!!!!
Thanks again!!!!
Mazdaspeed 6 2007 Velocity Red
//Cobb AP//CS SRI-TIP//Forge BPV V2//CS Boost/recirc.hoses//Magnaflow CB//Custom Testpipe//CS OCC//EGR delete//CS RMM+TMM Insert//TurbineTech diff.bushing//CS Mudflap//CS Short shift//CS SS clutch line//Oilfilter convertion//OEM Blockheater..lol//
//Custom vent Boost gauge//6000k Foglight//AUX input//
Next://CP-E safe seal//JBR IM Thermal gasket//CS hpfp//
jambisgone696 is offline
 Old 03-16-2014, 06:49 AM   #191
BAT-man's Avatar
Is anyone experiencing more KR with the throttle map update, or did I just get a really bad tank of gas? I know it doesn't make sense, since all it is, is opening the throttle more or less aggressively but... No other changes except this were made, so I gotta ask. Feel free to flame =\
BAT-man is offline
 Old 03-16-2014, 06:53 AM   #192
pfp22972's Avatar
My car is running very well. No KRs. I am using the aggressive DBW tables with a modified version of the relaxed APP tables.
- FREEKTUNED -
pfp22972 is offline
 Old 03-16-2014, 01:57 PM   #193
snailD's Avatar
once again this will have zero effect on kr, it merely changes throttle input. so it may have you drive slightly different which could be putting more load on the motor in certain ranges but that is purely speculative
snailD is offline
 Old 03-16-2014, 06:53 PM   #194
BAT-man's Avatar
Yeh.... I figured. I'm grasping at straws here, gonna have to revisit all maps and check sensors.
BAT-man is offline
 Old 03-19-2014, 09:30 AM   #195
El Beaner's Avatar
Well to test I switched to the stock OTS Cobb CS SRI+TIH map for yesterday. Now the load situation could be teh cause of it cause with your throttle I am definitely building boost much faster than the stock OTS map.
Driving to and from work, same route and similar driving habits, with your throttle table I would see KR in 1st and 2nd gear at times in the 1.5-2 range but that was just normal driving and a peak of 3.5 during a right hand turn(TCS and SWAS not disabled - could have been the cause of the higher number). At WOT I would not see those KR numbers.
With the stock OTS map, highest KR I saw driving around was .89 and I did see a 1.69 while making a right hand turn in second gear(did not have TCS or SWAS disabled so both could have been the cause).
This probably won't matter either but highest boost I would see at WOT in 3rd/4th was around 16.2psi and with the stock OTS I hit 17.05psi today(which is a first for me seeing boost in the 17 range).
 Old 03-19-2014, 11:38 AM   #196
snailD's Avatar
yes that it all YOUR driving style, which may have changed due to the throttle tables being different
snailD is offline
 Old 07-06-2014, 05:37 PM   #197
torquemaniac's Avatar
Posts: 733   (View Stats)
Those DBW and APP tables are like ice cream in summer : soooooooo nice
I was a bit hesitant to play with the DBW and APP tables because my APP redaing are fucked (I have a reading of 31% at idle, and a max of 76% at WOT)...but I loaded this on my CX-7, and it feels like the beast came to life!!!
Just made a small change to the 1st gear APP table (its funny to see how wicked the CX-7 tuning is : gear 1-2-4-5-6 APP are all the same, but 3rd gear APP is a lot more softer)
2011 CX-7 AWD 2.3 turbo
torquemaniac is offline
 Old 12-11-2014, 04:30 PM   #198
portetra000's Avatar
Posts: 85   (View Stats)
portetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond reputeportetra000 has a reputation beyond repute
I know I'm stirring the old thread pot here but this should be a sticky in both the gen1 and 2 tuning forums. I'm currently running stage 2 cobb ots and had the same issues alot of other people had with that map underboosting like crazy. Im sure it had something to do with me bumping the wastegate table a bit but this throttle table fixed everything I hate about the stage 2 map in terms of mushiness.
@Raider;
2007 MS3/Black Mica/JBR 3.5 Aluminum Whale Penis/CP-E catted downpipe/JBR EBC/JBR EGR Blockoff/CX Racing BOV/Corksport cat back exhaust/Cobb lowering springs/AP Tuner/ Stage 2 -self tooned (E85 Stratafied Stage 2 tune for fun days)/JBR 88a RMM/shaved hatch/corksport mudflaps/Dip'd rims/aftermarket boom boom box
portetra000 is offline
 Old 12-12-2014, 07:01 AM   #199
Discuss: SnailD's Throttle Table Fix
Raider is offline
Closed Thread
SnailD's High Altitude OTS Maps snailD 2010 MS3 - ECU Computer Tuning 123 08-27-2019 09:43 PM
SnailD's Throttle Table Fix snailD 2010 MS3 - ECU Computer Tuning 250 11-16-2017 02:09 PM
Snaild on corn snailD 2010 MS3 - Dyno Sheets/Discussions 13 11-23-2012 10:58 PM
Page generated in 0.61782 seconds with 32 queries
