| MazdaSpeed 3/6 - ECU Computer Tuning Have an ECU tuning issue? Do you want to discuss Mazdaspeed 3/6 tuning solutions? Up to date info on the latest! Piasini Reflash, Cobb Access Port, Xede, Procede, Standback, Superchips & others supported here! |
![]() Join Date: Dec 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
(Thread Starter) | Not Ranked : 0 score ive been having this issues since i got the car back after the engine build. i believe its related to the maf calibration. i have the 3.25 maf housing from cp-e and the flash for it. The Mass Air Meter flash. i already contacted cp-e about it and still waiting for there response. i had my car dynoed a week ago and the tuner told me that we were maxing out the maf. im not exactly sure how he diagnose it without looking at the maf volts. we were able to tune it out issue by using the maf & map table to add fuel to the car. i asked mark from SU about how he tuned his car via sb and he said that he was pulling a lot of fuel even on high rpms. Heres my current tune looks like also tried to lower the boost clip to 10 I showed it to mark and he said that something must be really wrong. also when we were tuning the car, seems like when it hits the target boost or when turbo spools up. afr goes lean. its like, accelerator pedal all the way to the floor then afr is like 11.5 afr and then afr will go lean for a quick sec then goes 11.5 again. it doesnt matter on what rpm you started the wot, car will do the same. another one is when i do a full throttle shift. car seems not to respond right away. its like, accelerator pedal all the way to the floor then shift. as soon as i get back to the throttle. car wont accelerate right away of the bat. its like ignoring your throttle input. it will respond after 1-3 sec. last is my ltft's are not really close to 0. its like -14to-16 at idle and -3to-7 at pt. i checked for boost leaks and there is none. also reset the ecu and cleaned the maf sensor and its still getting the same value. also checked the plugs and it looks ok. car doesnt cut on any situations stated above. probably because of the fuel cut flash. what do you guys think the issue is? im thinking maybe cp-e forgot the flash my ecu or didnt flash it right. i didnt have the chance yet to do a datalog the maf volts. is there anymore ways to tell my ecu is has been flashed?
__________________ |
![]() Join Date: Feb 2009 Location: All Over
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 284
Groans: 32
Groaned at 31 Times in 18 Posts
| Not Ranked : 0 score your using vista, that's your problem. sorry man, i have no idea what to say. i'll try to do some more research and get back to ya |
Groans: 78
| Not Ranked : 0 score i think most of those problems are being caused by your maf sensor not being calibrated correctly, once you get that straightened out you will be in much better shape.
| Not Ranked : 0 score John, have you fixed, or at least verified that your exh manifold isn't leaking at the head? It really looked like it was, and that could definitely contribute to the sluggish throttle.
| Fux Wit It ![]() ![]() Join Date: Mar 2008 Location: Li
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,795
Groans: 175
| Not Ranked : 0 score Welcome to the hunt for gremlins my friends
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous |
| Not Ranked : 0 score Hunting for gremlins is pointless if the hardware is out of whack.
Groans: 175
| Not Ranked : 0 score You say exhaust leak, he says Maf configuration. When you don't know what it is, its a Gremlin
Watch at 42 seconds, and how the smoke stops after the pull is finished. If it was just hot residue, then it would continue to burn after the pull.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
Groans: 175
__________________ ![]() Carry on citizens.... [CENTER]Pump Gas Champ 10.9 @ 12810.6 @ 129 E85 (IC coupler popped) 10.7 @ 133 auto 1G DSM 2013 C6 GS FBO and alotta Nitrous | |
| The Following User Says Thank You to Darksun280 For This Useful Post: | djuosnteisn (09-14-2009) |
![]() Join Date: Aug 2008 Location: Kahaluu, HI
| Not Ranked : 0 score John sorry bout that, seems a couple of my gremlins are missing (Lazy and grumpy), hope there not in your car, jk Yeah get the MAF recalibrated and wait for the CP-e to respond.
__________________ 07 Black Mica with Sunroof" 11/17/11 ZZ-SB (Spun #4 Rod Bearing @97,643 miles) "I'm back Baby" says the almighty Bender CURRENT MODS: Cobb ATR self tune+JBR WP+FMIC+BNR S3+MI+IM+CP-e EXMAN: VDyno 351hp and 331tq BEST 1320: COBB AP S2+MSCAI2+FMIC-v1.03i Best ET on 2Nov08 13.6@98mph (yeah I missed 5th gear) |
Groans: 175
| Not Ranked : 0 score Well if you want to know if its maf related just lower the boost to 20 and slowly up it while monitoring your maf voltage.
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
| Not Ranked : 0 score thats from the valve cover breather, he only has a filter on there. mine smokes like that too, i need to move it down stream....
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
| The Following User Says Thank You to m4tic For This Useful Post: | djuosnteisn (09-14-2009) |
| Not Ranked : 0 score Hmmm, good call.
(Thread Starter) | Not Ranked : 0 score yeah the smoke is not comiing behind the head. its from the breather.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 145
| Not Ranked : 0 score It might be the MAF/filter assembly itself. From what you describe about sluggish response, there is turbulence generated by the sudden influx of air, and there is only about 1 inch from filter to MAF sensor, causing a lean spike aka absence of flow around the MAF sensor after dropping the hammer. A velocity stack or air straighteners might fix the problem.
__________________ All wagon, No traction |
(Thread Starter) | Not Ranked : 0 score i think ive found whats causing the problem. heres the logs. I floored it around 3500rpm 2nd-3rd gear pull 3rd look at the maf readings. wtf? over 500 grams of air coming in the maf? its causing the car go lean. i already cleaned the maf 2x and still same issue what do you guys think? is it a bad maf or still the maf calibrations causing it?
__________________ Last edited by johnac08; 09-14-2009 at 11:22 PM. |
Groans: 175
| Not Ranked : 0 score ![]() Don't worry my boy is almost done recalibrating your MAF as we speak. Shit looks rock solid. Anything else you want done while he's in there?
| The Following 2 Users Say Thank You to Darksun280 For This Useful Post: | djuosnteisn (09-15-2009), kgb (09-16-2009) |
![]() Join Date: Oct 2008 Location: Orlando/ Daytona Beach
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 219
| Not Ranked : 0 score hahaha
__________________ 09 CWP Speed3 GT- CP-e Nano, Speedie6 TIP, CP-e Catless Downpipe, ED FMIC w/ GodSpeed core, Devils Own Stage 2 Meth Injection Kit, KMD v2 fuel pump internals, HKS BPV, SU full motor mounts & shifter bushings, Cobb Springs, 1 res delete in cbe, HID Fogs, AutoMeter Cobalt boost gauge, Michi OCC, Denso 1 step colder plugs, MSD DH, COBB AccessPort V105 Stage 2+sf 93 fmic [Today 11:50 PM] aaronc7: i just measured mine, a little over 12 |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 194
| Not Ranked : 0 score rotflmao |
| Not Ranked : 0 score Hahahahahahaha. holy shit. John, your also getting very very close to 5V on your maf voltage too. Maybe it's time for a 3.5" intake. Or something is horribly wrong with the intake your currently using. I guess it's possible that your maxing out a 3.25" maf, but seems kinda unlikely.
| MAF issues | MS3Zoom24 | Cobb ATR Support | 3 | 08-03-2009 02:58 AM |
| I have a few issues | rtabagaboy | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 0 | 05-09-2009 11:43 AM |
| AP MAP issues | bioevolve | MazdaSpeed 3/6 - ECU Computer Tuning | 8 | 06-16-2008 05:41 PM |
| A/C Issues | DAC17 | Mazdaspeed3/6 General Discussion | 3 | 06-10-2008 04:39 PM |
