Like Tree3Likes
 Old 08-24-2009, 06:59 PM   #1
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,156   (View Stats)
Groans: 754
I just got my Denso ITV 22 plugs, they appear to be gapped to 0.028 with one at 0.030 so I tightened that one up to 0.028 also.
I will be running an ATR modified Stage 1+ map.
Cobb says:
"Our data has shown that the factory spark plug temperature range (6) and gap (~.034”) are
sufficient for stock boost levels and normal driving conditions. Although, operating the car with higher
than stock boost levels or with the calibrations that are on the AccessPORT, require that a spark plug
gap of .026” - .028” (6.6 – 7.1mm) be used on a 1-step colder temperature plug. Denso currently offers
this spark plug as part # ITV22 (please be sure to verify each plug is properly gapped before installing
them). Our experience has shown that operating your turbo-charged engine at higher than stock boost levels requires that your spark plugs be replaced at around 15,000 mile intervals."
So what gap are you guys running the Denso ITV22 at??
Give answer as gap, and map you run.
Suspension:
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f9/spark-plug-database-colder-than-stock-stage-5691/
Loss of power on any MAP - Page 6 - COBB Forums This thread Refback 05-22-2008 01:14 PM
Loss of power on any MAP - Page 6 - COBB Forums This thread Refback 05-22-2008 06:57 AM
Loss of power on any MAP - Page 6 - COBB Forums This thread Refback 05-22-2008 03:39 AM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 6 - Engine, Transmission & Driveline 41 05-05-2016 08:49 AM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 3 - Engine, Transmission & Driveline 205 09-22-2015 06:52 PM
Spark Plug Gap khaydin
Cobb Access Port/Maps
5 12-01-2008 10:17 PM
HKS spark plugs installed *2 steps colder than stock whoosh@Realtune MazdaSpeed 3 - Engine, Transmission & Driveline 17 10-02-2008 02:15 PM
Spark plug gap Jesse MS3GT MazdaSpeed 3 - Engine, Transmission & Driveline 6 03-16-2008 04:53 PM
Page generated in 0.25834 seconds with 21 queries
